주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Anker Soundcore Space One Battery Replacement
필요한 것
    1. Anker Soundcore Space One Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Flip over the device so you can see the Soundcore symbol on the back two ear pieces.
      댓글 쓰기
    2. Anker Soundcore Space One Battery Replacement: 2 단계, 이미지 2개 중 1개 Anker Soundcore Space One Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Take a strong spudger (metal or plastic) and carefully insert it into the lining between the two back ear pieces.
      • Using a metal spudger (like the one pictured) can cut you if not used correctly. Please be mindful of where you insert it if you choose to use one
      • Removing the cover can take a couple of minutes. However, don't be aggressive while removing it, as you could damage the interior components under the back earpiece
      댓글 쓰기
    3. Anker Soundcore Space One Battery Replacement: 3 단계, 이미지 3개 중 1개 Anker Soundcore Space One Battery Replacement: 3 단계, 이미지 3개 중 2개 Anker Soundcore Space One Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Carefully remove the cover to reveal the battery.
      • Take a spudger and carefully lift the battery from the interior components.
      • Take care not to warp, bend, or puncture the battery.
      • The battery has a layer of adhesive under it. If necessary, use a hairdryer to lightly heat the battery to loosen the battery adhesive.
      댓글 쓰기
    4. Anker Soundcore Space One Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Lift out the battery.
      댓글 쓰기
    5. Anker Soundcore Space One Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Desolder the battery connections.
      댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Malcolm Hewlett
회원 가입일: 03/21/25
433 평판
안내서 4개를 작성함
UMass Dartmouth, Team 2-3, Botvin Spring 2025 UMass Dartmouth, Team 2-3, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S2G3
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 37
지난 30일: 199
전체 시간: 2,098
