주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Core Assembly Removal
필요한 것
  1. Core Assembly Removal, Power down your watch: 1 단계, 이미지 2개 중 1개 Core Assembly Removal, Power down your watch: 1 단계, 이미지 2개 중 2개
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    댓글 쓰기
  2. Core Assembly Removal, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    댓글 쓰기
  3. Core Assembly Removal, Loosen the back cover adhesive: 3 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    댓글 쓰기
  4. Core Assembly Removal, Pry up the back cover assembly: 4 단계, 이미지 3개 중 1개 Core Assembly Removal, Pry up the back cover assembly: 4 단계, 이미지 3개 중 2개 Core Assembly Removal, Pry up the back cover assembly: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    댓글 쓰기
  5. Core Assembly Removal, Disconnect the sensor assembly cable: 5 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the sensor assembly cable: 5 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  6. Core Assembly Removal, Remove the back cover assembly: 6 단계, 이미지 3개 중 1개 Core Assembly Removal, Remove the back cover assembly: 6 단계, 이미지 3개 중 2개 Core Assembly Removal, Remove the back cover assembly: 6 단계, 이미지 3개 중 3개
    • Remove the back cover assembly.
    댓글 쓰기
  7. Core Assembly Removal, Disconnect the microphone cable: 7 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the microphone cable: 7 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
    댓글 쓰기
  8. Core Assembly Removal, Unfasten the core assembly: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
    댓글 쓰기
  9. Core Assembly Removal, Pry up the core assembly: 9 단계, 이미지 2개 중 1개 Core Assembly Removal, Pry up the core assembly: 9 단계, 이미지 2개 중 2개
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
    댓글 쓰기
  10. Core Assembly Removal, Swing open the core assembly: 10 단계, 이미지 3개 중 1개 Core Assembly Removal, Swing open the core assembly: 10 단계, 이미지 3개 중 2개 Core Assembly Removal, Swing open the core assembly: 10 단계, 이미지 3개 중 3개
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
    댓글 쓰기
  11. Core Assembly Removal, Disconnect the display cables: 11 단계, 이미지 3개 중 1개 Core Assembly Removal, Disconnect the display cables: 11 단계, 이미지 3개 중 2개 Core Assembly Removal, Disconnect the display cables: 11 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
    댓글 쓰기
  12. Core Assembly Removal, Remove the core assembly: 12 단계, 이미지 2개 중 1개 Core Assembly Removal, Remove the core assembly: 12 단계, 이미지 2개 중 2개
    • Remove the core assembly.
    댓글 쓰기
결론
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
261,768 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,535개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 29
전체 시간: 1,526
