주요 콘텐츠로 건너뛰기
Dell Inspiron 13 7378 Heat Sink Replacement
Javier Perez
Javier Perez6 다른 기여자
최종 수정일 May 23, 2023
15 - 30 분
조정
The Dell Inspiron 13 7378 is a widely used laptop model, however, it is not immune to technical issues. One of the most prevalent problems faced by this device is CPU overheating. To mitigate this issue, it is crucial to replace the cooling system and prevent any harm to the internal components of the laptop. This guide will provide you with step-by-step instructions on how to perform this maintenance procedure in a professional manner.
필요한 것
도구
더보기...
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: 2 단계, 이미지 2개 중 1개 Dell Inspiron 13 7378 Heat Sink Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: 3 단계, 이미지 3개 중 1개 Dell Inspiron 13 7378 Heat Sink Replacement: 3 단계, 이미지 3개 중 2개 Dell Inspiron 13 7378 Heat Sink Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: 4 단계, 이미지 1개 중 1개
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: 5 단계, 이미지 2개 중 1개 Dell Inspiron 13 7378 Heat Sink Replacement: 5 단계, 이미지 2개 중 2개
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: 6 단계, 이미지 1개 중 1개
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
결론
Replace the back cover to complete the process.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Javier Perez
회원 가입일: 02/08/22
277 평판
안내서 2개를 작성함
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 회원
GCC-SAKNEE-S22S1G3
5 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 19
전체 시간: 372
