주요 콘텐츠로 건너뛰기
Dell XPS 15 9575 Fan Replacement
Andre Williams
Andre Williams4 다른 기여자
최종 수정일 June 21, 2024
20 분
조정
This guide shows the process of how to replace the fan of the Dell XPS 15 9575.
Both fans on this device have covers that are integrated into the interconnect cable, so its removal will be necessary for the fan replacement. However, Step 5 of the guide details removing the pin connectors for this cable, and their removal isn’t necessary for a quick fan swap.
The fans are responsible for offsetting the heat produced by processing units of the laptop. This means it should be relatively easy to diagnose problems with the fans, as the device will produce excessive heat as a result. If your device is producing noticeably excessive heat on a regular basis, you should replace the fan sooner rather than later, as heat in excess has the potential to damage the components that produce it. A faulty fan could also be responsible for excessive noise, and users may choose to replace such a fan to reduce noise even if heat is not experienced.
Check out the Dell XPS 9575 Troubleshooting page for more help narrowing down your issues to the fan.
필요한 것
도구
더보기...
  1. Dell XPS 15 9575 Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Dell XPS 15 9575 Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Dell XPS 15 9575 Fan Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Fan Replacement, Interconnect Cable: 3 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement, Interconnect Cable: 3 단계, 이미지 2개 중 2개
    • Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Fan Replacement: 4 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Fan Replacement: 5 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
  6. Dell XPS 15 9575 Fan Replacement, Fan: 6 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement, Fan: 6 단계, 이미지 2개 중 2개
    • Use the Phillips 0 Screwdriver to carefully extract each of the four 3.2 mm screws.
  7. Dell XPS 15 9575 Fan Replacement: 7 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Confirm all four screws have been extracted from the fan.
    • Find the wire connecting the fan into the motherboard and use the plastic opening tool to push the wire out from the motherboard's port.
  8. Dell XPS 15 9575 Fan Replacement: 8 단계, 이미지 2개 중 1개 Dell XPS 15 9575 Fan Replacement: 8 단계, 이미지 2개 중 2개
    • The fan has been completely disconnected and is now safe to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andre Williams
회원 가입일: 09/20/19
457 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 1,268
