소개
Follow this guide to remove and replace a worn battery for the Pixel 3. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Heat an iOpener and apply it to the bottom of the phone for one minute.
When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
Remove the five Phillips screws securing the wireless charging coil:
Two 1.9 mm screws
Two 4.2 mm screws
One 4.3 mm screw
Remove the wireless charging coil.
Use the point of a spudger to pry up and disconnect the battery connector from its socket near the right edge of the phone.
Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard.
Slide the spudger along the crevice to pry up the tape from the battery side.
Carefully peel the tape from the battery and fold it out of the way.
Remove the battery.
Carefully pull and remove the small foam buffer block from the left edge of the battery and transfer it to your replacement part. If it begins to tear, use the flat end of a spudger to gently pry it off the battery.
Lay some double-sided tape in the phone's battery well. If you're using Tesa tape to reattach components, follow this guide.
Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
Peel away any tape liners to expose the adhesive.
Lay the battery on the adhesive and press firmly.
Disconnect the battery connector from its motherboard socket and resume re-assembly.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
다른 114명이 해당 안내서를 완성하였습니다.
댓글 33개
Removing the adhesive from the rear glass can be a tedious process. I got my best results by taking fine point tweezers and pulling the adhesive back slowly, trying to get it to come up altogether as much as possible before using IPA to remove any residue.
How do you put the adhesive back (or put new adhesive on) when putting the phone back together?
@bfferraro, it depends on the type of adhesive.
If you are using a pre-cut adhesive sheet, follow this guide.
If you have a custom-cut adhesive, follow this guide.
Hi mpc,
The tape does not need to be thick at all. You can use standard double-sided tape, or the fancier stretch-release adhesive.
