주요 콘텐츠로 건너뛰기
Google Pixel 7a Rear Cover Replacement
필요한 것
  1. Google Pixel 7a Rear Cover Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1/2 Google Pixel 7a Rear Cover Replacement, Prepare your phone for disassembly: 1 단계, 이미지 2/2
    • Allow your battery to drain below 25% before starting this repair. A charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone and fully power it down.
  2. Google Pixel 7a Rear Cover Replacement, Soften the adhesive: 2 단계, 이미지 1/1
    • Apply a heated iOpener to the bottom edge of the rear cover for three minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover.
    • Only heat the phone enough so it's just hot to the touch. Extreme heat can damage the screen, rear cover, or battery.
  3. Google Pixel 7a Rear Cover Replacement, Secure an Anti-Clamp: 3 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Secure an Anti-Clamp: 3 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Secure an Anti-Clamp: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backward to unlock the Anti-Clamp's arms.
    • Slide the arms over the bottom edge of the phone, with one suction cup on the rear cover and one on the screen.
    • Squeeze the cups together to create suction.
  4. Google Pixel 7a Rear Cover Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Use the Anti-Clamp to create a gap: 4 단계, 이미지 3/3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  5. Google Pixel 7a Rear Cover Replacement, Insert an opening pick using the Anti-Clamp: 5 단계, 이미지 1/1
    • While the heat from an iOpener is sufficient to separate the rear cover, it might cool down while you set up the Anti-Clamp. Reheat the rear cover if you need more time to set it up.
    • Place an object under your phone so it rests level while between the Anti-Clamp's arms.
    • Wait one minute, or until the adhesive separates, for a gap to form along the bottom edge of the phone.
    • Insert an opening pick into the gap between the rear cover and the frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat with a hair dryer or heat gun if the rear cover cools down.
    • Remove the suction cups from the phone using their pull-tabs and set the Anti-Clamp aside.
  6. Google Pixel 7a Rear Cover Replacement, Insert an opening pick using a suction handle: 6 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Insert an opening pick using a suction handle: 6 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Insert an opening pick using a suction handle: 6 단계, 이미지 3/3
    • If you've already inserted an opening pick using the Anti-Clamp, skip this step.
    • Apply a suction handle to the center of the bottom edge of the rear cover.
    • Pull up on the suction handle with a strong, steady force until a gap forms between the rear cover and frame.
    • Insert the tip of an opening pick into the gap.
    • Remove the suction handle.
  7. Google Pixel 7a Rear Cover Replacement, Adhesive information: 7 단계, 이미지 1/2 Google Pixel 7a Rear Cover Replacement, Adhesive information: 7 단계, 이미지 2/2
    • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you slice the adhesive.
  8. Google Pixel 7a Rear Cover Replacement, Angle the opening pick: 8 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Angle the opening pick: 8 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Angle the opening pick: 8 단계, 이미지 3/3
    • Angle the opening pick upward so the tip faces away from the frame.
    • From here on, keep all opening picks angled upward while slicing until the rear cover is fully removed.
    • Slide your pick to the bottom left corner of the rear cover.
    • Leave this pick in place to prevent the adhesive from resealing.
  9. Google Pixel 7a Rear Cover Replacement, Separate the bottom edge adhesive: 9 단계, 이미지 1/2 Google Pixel 7a Rear Cover Replacement, Separate the bottom edge adhesive: 9 단계, 이미지 2/2
    • Insert a second opening pick in the bottom left corner.
    • Slide the new pick to the bottom right corner of the rear cover to separate the bottom edge adhesive.
  10. Google Pixel 7a Rear Cover Replacement, Soften the right edge adhesive: 10 단계, 이미지 1/1
    • Apply a heated iOpener to the right edge of the rear cover for two minutes.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to warm the rear cover. Remember to not overheat the phone.
  11. Google Pixel 7a Rear Cover Replacement, Separate the right edge adhesive: 11 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Separate the right edge adhesive: 11 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Separate the right edge adhesive: 11 단계, 이미지 3/3
    • Don't insert your pick deeper than 5 mm along the right edge to avoid damaging the wireless charging coil.
    • For a visual reference, you can measure 5 mm from the tip and mark your pick with a permanent marker.
    • Insert a third opening pick in the bottom right corner of the rear cover.
    • Slide your pick up the right edge of the rear cover to separate its adhesive. Stop when you reach the camera bar.
  12. Google Pixel 7a Rear Cover Replacement, Soften the left edge adhesive: 12 단계, 이미지 1/1
    • Apply a heated iOpener to the left edge of the rear cover for two minutes.
  13. Google Pixel 7a Rear Cover Replacement, Separate the left edge adhesive: 13 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Separate the left edge adhesive: 13 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Separate the left edge adhesive: 13 단계, 이미지 3/3
    • Don't insert your pick deeper than 3 mm along the left edge to avoid damaging the wireless charging coil and rear cover foam pad.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Insert a fourth opening pick in the bottom left corner of the rear cover.
    • Slide your pick up the left edge of the rear cover to separate the adhesive. Stop when you reach the camera bar.
  14. Google Pixel 7a Rear Cover Replacement, Soften the top edge adhesive: 14 단계, 이미지 1/1
    • Apply a heated iOpener to the top edge of the rear cover for two minutes.
  15. Google Pixel 7a Rear Cover Replacement, Separate the antenna bracket adhesive: 15 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Separate the antenna bracket adhesive: 15 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Separate the antenna bracket adhesive: 15 단계, 이미지 3/3
    • There's a thick strip of adhesive along the antenna housing.
    • Insert a fifth opening pick in the top left corner of the rear cover between 8 mm and 10 mm (0.3–0.4 in) deep, or just over halfway between the tip of the pick and the iFixit logo.
    • If you can't insert the pick, start with the small gap near the camera bar from the previous pick.
    • Slide your pick halfway across the top edge to separate the antenna bracket adhesive. Stop at the halfway point along the top edge.
  16. Google Pixel 7a Rear Cover Replacement, Separate the remaining top edge adhesive: 16 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Separate the remaining top edge adhesive: 16 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Separate the remaining top edge adhesive: 16 단계, 이미지 3/3
    • Pull your opening pick out to a depth of 3 mm.
    • Slide your pick to the top right corner to slice the rest of the top edge adhesive.
    • Don't insert your pick deeper than 3 mm to avoid damaging the antenna housing graphite tape.
  17. Google Pixel 7a Rear Cover Replacement, Rotate your top edge opening picks: 17 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Rotate your top edge opening picks: 17 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Rotate your top edge opening picks: 17 단계, 이미지 3/3
    • Remember to angle your picks upward and away from the frame during this step.
    • Roll the top edge pick so its flat edge is under the rear cover.
    • Roll the picks on each side of the camera bar so their flat edges are under the camera bar.
  18. Google Pixel 7a Rear Cover Replacement, Pry up the camera bar: 18 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Pry up the camera bar: 18 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Pry up the camera bar: 18 단계, 이미지 3/3
    • There's a long strip of adhesive securing the rear cover below the camera bar.
    • Use the opening picks under the camera bar to pry the top edge of the rear cover from the frame.
    • Pry back and forth until the camera bar loosens.
    • Be careful not to bend the rear cover. Only pry enough to loosen the adhesive near the camera bar. If the adhesive feels stubborn, rotate the rear cover side-to-side to further loosen the adhesive.
  19. Google Pixel 7a Rear Cover Replacement, Finish separating the adhesive: 19 단계, 이미지 1/3 Google Pixel 7a Rear Cover Replacement, Finish separating the adhesive: 19 단계, 이미지 2/3 Google Pixel 7a Rear Cover Replacement, Finish separating the adhesive: 19 단계, 이미지 3/3
    • Slide the opening picks from the camera bar down the long edges of the rear cover to separate any adhesive that may have resealed.
  20. Google Pixel 7a Rear Cover Replacement, Remove the rear cover: 20 단계, 이미지 1/2 Google Pixel 7a Rear Cover Replacement, Remove the rear cover: 20 단계, 이미지 2/2
    • Remove the rear cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your rear cover.
결론
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
다른 2명이 해당 안내서를 완성하였습니다.
Clay Eickemeyer
회원 가입일: 09/19/22
67,291 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,420개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 85
30일 전: 445
전체 시간: 3,464
