주요 콘텐츠로 건너뛰기
Google Pixel Watch Screen Replacement
필요한 것
  1. Google Pixel Watch Screen Replacement, Remove the watch band: 1 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Remove the watch band: 1 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Remove the watch band: 1 단계, 이미지 3개 중 3개
    • Before starting repairs, turn off your watch and take it off the charger.
    • Remove the watch band by pressing the band release button and sliding the band over the button while pulling it away from the watch.
    • Repeat for the other watch band.
  2. Google Pixel Watch Screen Replacement, Loosen the screen adhesive: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the screen for about two minutes to soften the adhesive securing the screen.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  3. Google Pixel Watch Screen Replacement, Insert an iFlex: 3 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Insert an iFlex: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFlex Opening Tool
    $11.99
    • The thin seam between the frame and screen requires a thin metal tool—take your time and work carefully to avoid scraping or gouging the watch body or glass.
    • Insert an iFlex into the thin gap between the screen and frame, left of the digital crown.
  4. Google Pixel Watch Screen Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Slice the screen adhesive: 4 단계, 이미지 3개 중 3개
    • When slicing the screen adhesive, insert the iFlex no deeper than 3 mm to prevent damaging internal components.
    • Slide the iFlex around the entire perimeter of the watch to slice all of the screen adhesive.
  5. Google Pixel Watch Screen Replacement, Pry up the screen: 5 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Pry up the screen: 5 단계, 이미지 2개 중 2개
    • Remove the iFlex and reinsert it under the screen, to the right of the speaker grille.
    • Twist the iFlex to pry the screen up.
    • Don't try to fully remove the screen just yet, as it‘s still connected to the watch assembly by a delicate cable.
  6. Google Pixel Watch Screen Replacement, Swing open the screen: 6 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Swing open the screen: 6 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Swing open the screen: 6 단계, 이미지 3개 중 3개
    • Be careful not to strain the screen assembly cable when you open the display.
    • Swing the screen open to an upright position.
    • During reassembly, this is a good point to power on your device and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
  7. Google Pixel Watch Screen Replacement, Unfasten the speaker bracket: 7 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Unfasten the speaker bracket: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $36.95
    • Use a Torx T2 screwdriver to remove the 2.1 mm-long screw securing the speaker bracket.
  8. Google Pixel Watch Screen Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Remove the speaker bracket: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals or catch fire.
    • Use a pair of tweezers to remove the speaker bracket.
  9. Google Pixel Watch Screen Replacement, Disconnect the vibration motor: 9 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Disconnect the vibration motor: 9 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the vibration motor‘s press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  10. Google Pixel Watch Screen Replacement, Loosen the vibration motor cable: 10 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Loosen the vibration motor cable: 10 단계, 이미지 2개 중 2개
    • Be careful with sharp tools around the battery.
    • Use tweezers to peel up the yellow tape securing the vibration motor cable to the battery.
  11. Google Pixel Watch Screen Replacement, Unfasten the vibration motor: 11 단계, 이미지 1개 중 1개
    • Use a Torx T2 screwdriver to remove the two screws securing the vibration motor:
    • One 1.8 mm-long screw
    • One 2.8 mm-long screw
  12. Google Pixel Watch Screen Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Remove the grounding bracket: 12 단계, 이미지 3개 중 3개
    • Use tweezers to lift the grounding bracket out of its recess and remove it.
  13. Google Pixel Watch Screen Replacement, Remove the vibration motor: 13 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Remove the vibration motor: 13 단계, 이미지 2개 중 2개
    • Remove the vibration motor.
  14. Google Pixel Watch Screen Replacement, Unfasten the battery bracket: 14 단계, 이미지 1개 중 1개
    • Use a Torx T2 screwdriver to remove the two 3 mm-long screws securing the battery bracket.
  15. Google Pixel Watch Screen Replacement, Remove the grounding bracket: 15 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Remove the grounding bracket: 15 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Remove the grounding bracket: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
  16. Google Pixel Watch Screen Replacement, Loosen the battery tape: 16 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Loosen the battery tape: 16 단계, 이미지 2개 중 2개
    • Use tweezers to peel up the yellow tape from the edge of the battery, next to the speaker.
  17. Google Pixel Watch Screen Replacement, Pry up the battery: 17 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Pry up the battery: 17 단계, 이미지 2개 중 2개
    • Slide the flat end of a spudger under the edge of the battery where the vibration motor was.
    • Pry up the battery until you can grip it with your fingers.
    • The battery is held in place by mild adhesive. If you're struggling to pry up the battery, apply a heated iOpener to the bottom of the watch for about 2 minutes to loosen the adhesive. Don't apply the iOpener directly to the battery.
    • Don't try to remove the battery all the way yet, as it‘s still connected to the watch assembly by a delicate cable.
  18. Google Pixel Watch Screen Replacement, Reposition the battery: 18 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Reposition the battery: 18 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Reposition the battery: 18 단계, 이미지 3개 중 3개
    • Avoid straining or tearing the battery cable when moving the battery.
    • Carefully place the battery next to the watch to access the battery connector bracket.
  19. Google Pixel Watch Screen Replacement, Unfasten the battery connector bracket: 19 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Unfasten the battery connector bracket: 19 단계, 이미지 2개 중 2개
    • Use a Torx T2 screwdriver to remove the two 1.5 mm-long screws securing the battery connector bracket.
  20. Google Pixel Watch Screen Replacement, Remove the battery connector bracket: 20 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Remove the battery connector bracket: 20 단계, 이미지 2개 중 2개
    • Use tweezers to remove the battery connector bracket.
  21. Google Pixel Watch Screen Replacement, Disconnect the battery cable: 21 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Disconnect the battery cable: 21 단계, 이미지 2개 중 2개
    • Use the point of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  22. Google Pixel Watch Screen Replacement, Remove the battery: 22 단계, 이미지 1개 중 1개
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  23. Google Pixel Watch Screen Replacement, Disconnect the screen assembly cable: 23 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Disconnect the screen assembly cable: 23 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Disconnect the screen assembly cable: 23 단계, 이미지 3개 중 3개
    • Note: The screen assembly cable is threaded underneath the test port cable.
    • Avoid straining or tearing the test port cable in the following steps.
    • Use the point of a spudger to disconnect the screen assembly cable by carefully prying the connector straight up from its socket.
  24. Google Pixel Watch Screen Replacement, Loosen the screen assembly cable: 24 단계, 이미지 2개 중 1개 Google Pixel Watch Screen Replacement, Loosen the screen assembly cable: 24 단계, 이미지 2개 중 2개
    • The screen assembly cable is secured by light adhesive.
    • Slide the flat end of a spudger underneath the screen assembly cable to loosen its adhesive and detach it from the watch frame.
  25. Google Pixel Watch Screen Replacement, Remove the screen assembly: 25 단계, 이미지 3개 중 1개 Google Pixel Watch Screen Replacement, Remove the screen assembly: 25 단계, 이미지 3개 중 2개 Google Pixel Watch Screen Replacement, Remove the screen assembly: 25 단계, 이미지 3개 중 3개
    • Carefully pull the screen assembly cable out from underneath the test port cable.
    • Remove the screen assembly.
    • During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with high-concentration isopropyl alcohol (>90%).
    • After installing the screen, apply strong, steady pressure for several hours to help the adhesive form a good bond—a stack of heavy books works well.
결론
If you were installing a new batter—For optimal performance, calibrate your newly installed battery after completing this guide.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
246,856 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,643개를 작성함
7가이드 댓글
Bekommt man das Display überhaupt irgendwo zu kaufen? Ich habs nicht irgendwo gefunden
Anna Katharina Linges - 답글
Whee do you get the screen
Janelle Roland - 답글
Replacement screen can be obtained by buying a broken Pixel Watch (with an intact screen) off eBay. There aren't a lot for sale but they do come up. I just bought one for 34 USD plus 15 USD shipping to Canada.
What width replacement adhesive is needed? Is this Tesa tape suitable? Tesa 61395 Tape
Lance Kersey - 답글
Is it an adhesive tape or will something like uhu or evostik work?
Marcus Winter - 답글
Gibt es ein schon fertiges Klebeband für das Display?
Maximilian Schmidt - 답글
댓글 쓰기
조회 통계:
지난 24시간: 31
지난 7일: 225
지난 30일: 1,067
전체 시간: 30,702
