주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Reapply Durable Water Repellent (DWR) Coating
필요한 것
    1. How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: 1 단계, 이미지 3개 중 1개 How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: 1 단계, 이미지 3개 중 2개 How to Reapply Durable Water Repellent (DWR) Coating, Prepare your jacket: 1 단계, 이미지 3개 중 3개
      • Zip up all zippers to protect them during the wash and dry cycles.
      • Check all pockets for forgotten items and hidden treasures!
      댓글 쓰기
    2. How to Reapply Durable Water Repellent (DWR) Coating: 2 단계, 이미지 3개 중 1개 How to Reapply Durable Water Repellent (DWR) Coating: 2 단계, 이미지 3개 중 2개 How to Reapply Durable Water Repellent (DWR) Coating: 2 단계, 이미지 3개 중 3개
      • Loosen drawstrings and drawcords as much as possible.
      • Fasten hook-and-loop closures in their most relaxed position to avoid snagging.
      댓글 쓰기
    3. How to Reapply Durable Water Repellent (DWR) Coating, Load the washer: 3 단계, 이미지 1개 중 1개
      • Place the jacket in the washing machine.
      • Add 1–3 garments at a time. Avoid overfilling the drum—technical garments need room to move freely.
      • Ideally, use a front-loading washer instead of a top-loading machine.
      • Top-loaders usually have agitators, a rotating spindle that creates friction to clean your gear. Jackets can get caught in that spindle, leading to tangles, tears, or scratches.
      • Top-loaders also require more DWR treatment. (For example Storm Eco Proofer requires 75 ml for front-loaders vs. 112 ml for top-loaders.)
      댓글 쓰기
    4. How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: 4 단계, 이미지 3개 중 1개 How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: 4 단계, 이미지 3개 중 2개 How to Reapply Durable Water Repellent (DWR) Coating, Add DWR treatment: 4 단계, 이미지 3개 중 3개
      • Add durable water repellent treatment to the wash, following the instructions on the bottle.
      • For Patagonia® recommended Storm Eco Proofer:
      • Shake the bottle and measure out 2.5 ounces (75 ml) (about 1/3 cup or 5 tablespoons) per item.
      • Pour the treatment into the fabric softener compartment.
      • You can add Storm Clothing Wash to the detergent compartment. It’s designed to work with the Eco Proofer.
      • Don't use regular household detergent. It can interfere with the DWR treatment.
      댓글 쓰기
    5. How to Reapply Durable Water Repellent (DWR) Coating, Set the washing machine: 5 단계, 이미지 2개 중 1개 How to Reapply Durable Water Repellent (DWR) Coating, Set the washing machine: 5 단계, 이미지 2개 중 2개
      • Set the load size to small or medium, depending on the number of garments you're washing.
      • Set the water temperature to cold.
      • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
      • Set the spin cycle to low.
      • Start the washing machine.
      댓글 쓰기
    6. How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: 6 단계, 이미지 3개 중 1개 How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: 6 단계, 이미지 3개 중 2개 How to Reapply Durable Water Repellent (DWR) Coating, Tumble dry: 6 단계, 이미지 3개 중 3개
      • Hang the jacket up to drip dry first to remove excess water.
      • Tumble dry the jacket on low heat.
      • Don't skip the dryer! Heat activates the DWR coating.
      • Follow the garment care instructions for dryer time settings. While a lightweight rain shell may only take 20 minutes, a down insulated jacket could take up to 2 hours to fully dry.
      • If you don't have access to a dryer, use a low-heat iron with a clean damp cloth between the iron and the jacket to heat-set the treatment. See How to Iron a Waterproof Jacket for more info.
      댓글 쓰기
    7. How to Reapply Durable Water Repellent (DWR) Coating, All done!: 7 단계, 이미지 1개 중 1개
      • Your jacket is now refreshed and ready to take on the elements again. Whether you're heading into the mountains, the forest, or just out for a rainy-day walk, your gear is good to go.
      • Get back out there!
      댓글 쓰기
      • Spray-on treatments are great for targeted reapplication or when you want to avoid a full wash. Follow the instructions on the bottle, which typically include:
      • Spray onto a freshly cleaned garment while it's hanging or laid flat.
      • Focus the spray on high-wear areas like shoulders.
      • Let it sit for a few minutes, then heat-set it with a dryer or iron.
      댓글 쓰기
    8. 댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Clara Redwood
회원 가입일: 11/12/24
2,568 평판
안내서 19개를 작성함
Patagonia Patagonia 회원
Community
9 회원들
안내서 247개를 작성함
3가이드 댓글
Can you recommend a durable water repellency treatment? I have tried to treat my rain jacket in the past and have been disappointed in the results.
Andrea Jeffery - 답글 공유
If fabric becomes wet, it loses its performance and breathability indeed. Therefore, most technical garments contain a tiny layer of Durable Water Repellency (DWR) coating outside. This layer of liquid prevents dirt, grease, oil, and water as well. But, usually, protecting this essential fabric layer becomes very difficult yet.
Therefore, some people use the best waterproofing spray for the outdoor fabric to protect this liquid coating. These waterproofing sprays protect our footwear, and other clothing stuffs from water damage. Though this spray’s main function is to prevent water and form a protective barrier against sun and dirt, it has more benefits than one. These waterproofing sprays improve the performance of your fabrics.
For More Information & Products Review and Buying Guide Visit - https://www.bestoutdoorreview.com/best-w...
Best Outdoor Review - 답글 공유
I’ve used every DWR product available, none of them work
DaveWave - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 66
지난 30일: 408
전체 시간: 39,243
