주요 콘텐츠로 건너뛰기
Huawei Honor 10 Battery Replacement
필요한 것
  1. Huawei Honor 10 Battery Replacement, Rear Glass: 1 단계, 이미지 1개 중 1개
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to a long edge of the phone to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes.
  2. Huawei Honor 10 Battery Replacement: 2 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement: 2 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Press a suction cup onto the back cover.
    • Lift the back cover's right edge with your suction cup, opening a slight gap between the back cover and the frame.
    • Insert the tip of an opening pick in the gap you created and slide it to the bottom right corner.
  3. Huawei Honor 10 Battery Replacement: 3 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Apply more heat if the adhesive becomes hard to cut. During the removal process, the back cover is under tension all the time and is likely to break if the adhesive isn't softened enough.
    • Insert a second opening pick at the bottom right corner of the rear glass.
    • Slide the opening pick along the bottom edge of the rear glass to cut the adhesive and leave it in the bottom left corner.
  4. Huawei Honor 10 Battery Replacement: 4 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement: 4 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a third opening pick at the bottom left corner of the rear glass.
    • Slide the opening pick along the left edge of the rear glass to cut the adhesive.
    • Leave the opening pick at the top left corner of the rear glass.
  5. Huawei Honor 10 Battery Replacement: 5 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick at the top left corner of the rear glass.
    • Slide the opening along the top edge of the rear glass and cut the remaining adhesive with it.
  6. Huawei Honor 10 Battery Replacement: 6 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully lift the rear glass of the Huawei Honor 10 and remove it.
  7. Huawei Honor 10 Battery Replacement, Battery disconnect: 7 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement, Battery disconnect: 7 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement, Battery disconnect: 7 단계, 이미지 3개 중 3개
    • Use a pair of tweezer to carefully peel the black foil off the loudspeaker and daughterboard cover.
    • Remove the foil completely.
  8. Huawei Honor 10 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the three Phillips #00 screws (2.9 mm length) that secure the metal bracket on top of the battery, interconnect, and display flex cable.
  9. Huawei Honor 10 Battery Replacement: 9 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the metal shield that covers the connectors of the interconnect cable, the battery and the display flex cable.
  10. Huawei Honor 10 Battery Replacement: 10 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to pry up and disconnect the battery flex cable.
  11. Huawei Honor 10 Battery Replacement, Loudspeaker Unit: 11 단계, 이미지 1개 중 1개
    • Remove the seven Phillips screws securing the loudspeaker unit:
    • Three silver 2.9 mm long screws
    • Four black 3.4 mm long screws
  12. Huawei Honor 10 Battery Replacement: 12 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement: 12 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement: 12 단계, 이미지 3개 중 3개
    • There's a little bit of adhesive under the loudspeaker. It's possible to remove the loudspeaker without heating the adhesive but if you're having a hard time removing it, you can use an iOpener to soften the adhesive.
    • Slide the flat end of a spudger under the right side of the loudspeaker unit.
    • Pry up the loudspeaker unit until you can get a good grip.
    • Remove the loudspeaker unit.
  13. Huawei Honor 10 Battery Replacement, Battery: 13 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement, Battery: 13 단계, 이미지 2개 중 2개
    • Use a spudger to pry off and disconnect the bottom end of the interconnect flex cable.
  14. Huawei Honor 10 Battery Replacement: 14 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Use a spudger tor pry up and disconnect the top end of the interconnect flex cable.
    • Remove the interconnect flex cable.
  15. Huawei Honor 10 Battery Replacement: 15 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 15 단계, 이미지 2개 중 2개
    • Use a spudger to pry off and disconnect the display flex cable.
    • Fold the display flex cable backwards and out of the way to make the battery removal process easier.
  16. Huawei Honor 10 Battery Replacement: 16 단계, 이미지 1개 중 1개
  17. Huawei Honor 10 Battery Replacement: 17 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement: 17 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement: 17 단계, 이미지 3개 중 3개
    • If you have trouble prying up the battery, the adhesive may not be loose enough. You can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • Try your best not to deform or puncture the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    • Insert the flat end of a spudger at the top left corner of the battery where the display flex cable connector is located and start to pry it up.
    • Work your way down the left side of the battery and loosen the adhesive with the spudger.
  18. Huawei Honor 10 Battery Replacement: 18 단계, 이미지 3개 중 1개 Huawei Honor 10 Battery Replacement: 18 단계, 이미지 3개 중 2개 Huawei Honor 10 Battery Replacement: 18 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger at the top right corner of the battery to pry it up.
    • Work your way down the right side of the battery and loosen the adhesive.
  19. Huawei Honor 10 Battery Replacement: 19 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 19 단계, 이미지 2개 중 2개
    • Cut the remaining adhesive beneath the center of the battery using the spudger.
    • Pry up the battery until you can get a good grip.
  20. Huawei Honor 10 Battery Replacement: 20 단계, 이미지 2개 중 1개 Huawei Honor 10 Battery Replacement: 20 단계, 이미지 2개 중 2개
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Before installing a new battery remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
결론
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
230,109 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,533개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 100
지난 30일: 364
전체 시간: 11,509
