주요 콘텐츠로 건너뛰기
Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement
Edgar Galindo
Edgar Galindo4 다른 기여자
최종 수정일 April 4, 2024
5 - 10 분
조정
Use the guide to replace both or one of your broken or wasted thumbsticks in your Xbox Series X controller.
The thumbsticks are the central part of the controller that allows for most of your in-game movement. A wasted or broken thumbstick could reduce your performance for some of your favorite games.
Before using this guide, make sure to ensure that your thumbsticks are the ones wasted or broken because if it is stick drift, then this is not the correct guide for you to follow.
필요한 것
부품
도구
더보기...
  1. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: 1 단계, 이미지 3개 중 3개
    • Remove the battery pack cover.
    • If there are any batteries inside of it, remove them.
  2. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Place an iFixit opening tool between the seam of both the front and side plates.
    • Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
  3. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Remove or pick a hole on the warranty sticker label to reveal the center screw.
    • Remove all five screws from the backplate using a TR8 Torx screwdriver.
  4. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the front plate from the controller.
  5. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 1개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 2개 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: 5 단계, 이미지 3개 중 3개
    • Pop-out the old thumbsticks and connect the new thumbsticks to the joystick.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Edgar Galindo
회원 가입일: 03/20/22
509 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-80, Briggs Spring 2022 CSU Los Angeles, Team 8-80, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S8G80
1 회원
안내서 4개를 작성함
댓글 4개
Does this method fix joystick drift?
Aaron - 답글
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Kris Rodriguez -
Where is the article addressing stick-drift/replacement, if this is not it?
Pictory - 답글
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 109
지난 30일: 320
전체 시간: 26,683
