주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Montiss Air bubble Massage Machine Fuse Replacement
필요한 것
  1. Montiss Air bubble Massage Machine Fuse Replacement, Fuse: 1 단계, 이미지 1개 중 1개
    • Place the product in front of you
    댓글 쓰기
  2. Montiss Air bubble Massage Machine Fuse Replacement: 2 단계, 이미지 2개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the tube, twist it and take it out.
    댓글 쓰기
  3. Montiss Air bubble Massage Machine Fuse Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the product upside down, you will see five holes, in which the screws are located.
    댓글 쓰기
  4. Montiss Air bubble Massage Machine Fuse Replacement: 4 단계, 이미지 3개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 4 단계, 이미지 3개 중 2개 Montiss Air bubble Massage Machine Fuse Replacement: 4 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to loosen the screws, then turn the product right side up to get the screws out of the casing.
    댓글 쓰기
  5. Montiss Air bubble Massage Machine Fuse Replacement: 5 단계, 이미지 1개 중 1개
    • Place the product on its feet and place the upper part of the casing next to the bottom part.
    댓글 쓰기
  6. Montiss Air bubble Massage Machine Fuse Replacement: 6 단계, 이미지 2개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 6 단계, 이미지 2개 중 2개
    • An electronic wire is connecting the two PCB’s. Take off the PCB in the lower part of the case by gently pulling the plastic housing, the connection will slowly loosen.
    댓글 쓰기
  7. Montiss Air bubble Massage Machine Fuse Replacement: 7 단계, 이미지 2개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 7 단계, 이미지 2개 중 2개
    • Take the PCB out of the case. Here you can see the fuse you want to replace
    댓글 쓰기
  8. Montiss Air bubble Massage Machine Fuse Replacement: 8 단계, 이미지 3개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 8 단계, 이미지 3개 중 2개 Montiss Air bubble Massage Machine Fuse Replacement: 8 단계, 이미지 3개 중 3개
    • Desolder the two spots connecting the fuse to the PCB. If you have never done this before, use this guide from iFixIt.
    댓글 쓰기
  9. Montiss Air bubble Massage Machine Fuse Replacement: 9 단계, 이미지 2개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 9 단계, 이미지 2개 중 2개
    • Take out the fuse with some pliers, since it will be hot because of the soldering.
    댓글 쓰기
  10. Montiss Air bubble Massage Machine Fuse Replacement: 10 단계, 이미지 2개 중 1개 Montiss Air bubble Massage Machine Fuse Replacement: 10 단계, 이미지 2개 중 2개
    • Put in a new fuse and solder it back in place. Now you can reassemble the product.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Lisa Hoogeveen
회원 가입일: 03/08/17
101 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 35
전체 시간: 915
