주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Pro Controller Joystick Module Replacement
필요한 것
  1. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    댓글 쓰기
  2. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the handle covers: 2 단계, 이미지 3개 중 3개
    • Carefully remove the handle covers by pulling them away from the main body.
    댓글 쓰기
  3. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    댓글 쓰기
  4. Nintendo Switch Pro Controller Joystick Module Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Unclip the plastic cover: 4 단계, 이미지 3개 중 3개
    • Carefully pry away the clear plastic cover using your fingernail.
    댓글 쓰기
  5. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the clear plastic cover: 5 단계, 이미지 1개 중 1개
    • Remove the clear plastic cover.
    댓글 쓰기
  6. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the battery: 6 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the battery: 6 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the battery: 6 단계, 이미지 3개 중 3개
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    댓글 쓰기
  7. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the screws: 7 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the screws: 7 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the screws: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    댓글 쓰기
  8. Nintendo Switch Pro Controller Joystick Module Replacement: 8 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement: 8 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement: 8 단계, 이미지 3개 중 3개
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    댓글 쓰기
  9. Nintendo Switch Pro Controller Joystick Module Replacement, Open the flap: 9 단계, 이미지 2개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Open the flap: 9 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    댓글 쓰기
  10. Nintendo Switch Pro Controller Joystick Module Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Disconnect the interconnect cable: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    댓글 쓰기
  11. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the front case: 11 단계, 이미지 1개 중 1개
    • Remove the front case.
    댓글 쓰기
  12. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the joystick caps: 12 단계, 이미지 3개 중 3개
    • With light force pull the two joystick caps off of the controller.
    댓글 쓰기
  13. Nintendo Switch Pro Controller Joystick Module Replacement, Unscrew the motherboard: 13 단계, 이미지 1개 중 1개
    • Use a PH1 Philipps screwdriver to remove the four 5 mm-long screws securing the motherboard.
    댓글 쓰기
  14. Nintendo Switch Pro Controller Joystick Module Replacement, Remove the LED light: 14 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the LED light: 14 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Remove the LED light: 14 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use your fingernail or a pair of tweezers to pry the LED light away from its slot.
    • Set aside the LED light with its corresponding screw for reassembly.
    댓글 쓰기
  15. Nintendo Switch Pro Controller Joystick Module Replacement, Loosen the circuit board: 15 단계, 이미지 3개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Loosen the circuit board: 15 단계, 이미지 3개 중 2개 Nintendo Switch Pro Controller Joystick Module Replacement, Loosen the circuit board: 15 단계, 이미지 3개 중 3개
    • Loosen the circuit board off the chassis by gently pulling at the bottom right corner.
    • Lift the circuit board up to expose its backside.
    • Avoid using too much force when lifting the circuit board to prevent damaging the wires.
    댓글 쓰기
  16. Nintendo Switch Pro Controller Joystick Module Replacement, Desolder the joystick module: 16 단계, 이미지 2개 중 1개 Nintendo Switch Pro Controller Joystick Module Replacement, Desolder the joystick module: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixHub Smart Soldering Iron
    $79.95
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Remove the joystick module from the circuit board.
    • Refer to the following solder guide if necessary: 연결부 납땜 및 납제거 방법
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 56명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Daniel Tagalog
회원 가입일: 10/10/19
2,128 평판
안내서 3개를 작성함
Cal Poly, Team S11-G2, Regan Fall 2019 Cal Poly, Team S11-G2, Regan Fall 2019 회원
CPSU-REGAN-F19S11G2
5 회원들
안내서 45개를 작성함
28가이드 댓글
I managed to replace mine with much difficulty with the soldering but the stick does not seem to turn fully anymore, both with the replacement and the original. For reference, when I go to test it, it no longer registers as reaching the outer circle when pressed all the way down. Similarly when I go to calibrate it, it only reaches up til about the 2nd outer circle, not enough to actually trigger the green arrow. Since this seems to occur on both the replacement and original stick now, I’m guessing this must be some issue that arose while I was struggling with the desoldering process. Anybody have any ideas what might be causing my issue? Have I just damaged it beyond repair?
Tyler - 답글 공유
Without pictures it is impossible to tell, but there is the possibility that you strips the metal connection on the solder point. This is fixable by “bridging” the connection. You will want to find schematics of the wiring for the PCB and then solder the wire over to the next connection.
As a side note, I should mention that I have never tried this on a controller of any sort and that I have only used this method on keyboards with single wire connections. It is possible that the connection in a controller PCB have more going on and that this technique will not work.
Gavin A - 답글 공유
I have the same problem, I buy 2 joystick module from iFixit and the two gave me the same issue, the joystick module don't reach the green arrow.
I can't calibrate because of that issue.
Any ideas?
Piero Grasso - 답글 공유
I have also had the same issue with replacement, only reaches roughly 75%. I contacted ifixit and they sent me a replacement thinking it might be a faulty pot, I installed the new stick and have the same issue. Maybe different years used different resistance.
marcos aguilera - 답글 공유
See my answer a bit down. I think it has to do with the resistance of the module. I had the same issue with the part I received from iFixit, the original part has a resistance of 1150 ohm, but the replacement is 1600 ohm. And I have a different module which is about 500 ohm, and that works just fine.
Peter de Bruine - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 74
지난 7일: 518
지난 30일: 2,268
전체 시간: 178,570
