Nokia 1010 SIM Card Replacement
If you are looking to add more memory to your Nokia 1010 this guide will show you how to access your SIM Card slot to add a SIM Card. This guide can also help you to find out where your SIM Card slot is if you want to take the SIM card out to transport your data on your SIM card somewhere else.
필요한 것
다른 9명이 해당 안내서를 완성하였습니다.
댓글 3개
contact@davidmarsh.org.uk
what is the name or model or size of the SIM card please?
J’ai un problème avec mon téléphone
J’ai un problème avec téléphone
If your screen is damaged and you can't see anything then don't bother unless you have a soldering/desoldering tools. The guide only shows you how to replace the glass. Not the screen. If you have your soldering kit then follow till the end and then after that desolder the old screen and solder on the new one.
Macro Man - 답글
