주요 콘텐츠로 건너뛰기
Nokia 1010 SIM Card Replacement
jnowels1
jnowels14 다른 기여자
최종 수정일 September 8, 2017
2 분
조정
If you are looking to add more memory to your Nokia 1010 this guide will show you how to access your SIM Card slot to add a SIM Card. This guide can also help you to find out where your SIM Card slot is if you want to take the SIM card out to transport your data on your SIM card somewhere else.
필요한 것
도구
  1. Nokia 1010 SIM Card Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nokia 1010 SIM Card Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using your thumbs, press and slide down the back cover of the Nokia 1010.
    If your screen is damaged and you can't see anything then don't bother unless you have a soldering/desoldering tools. The guide only shows you how to replace the glass. Not the screen. If you have your soldering kit then follow till the end and then after that desolder the old screen and solder on the new one.
    Macro Man - 답글
  2. Nokia 1010 SIM Card Replacement: 2 단계, 이미지 3개 중 1개 Nokia 1010 SIM Card Replacement: 2 단계, 이미지 3개 중 2개 Nokia 1010 SIM Card Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the prying tool in the notch above the battery.
    • Once the prying tool is inserted, lift up the battery.
  3. Nokia 1010 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 Nokia 1010 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 Nokia 1010 SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
    • Using the prying tool, pull back the latch of the SIM Card holder.
  4. Nokia 1010 SIM Card Replacement: 4 단계, 이미지 1개 중 1개
    • With your finger, remove the SIM card.
    • At this point the SIM card has nothing holding it in and the phone can be turned over allowing the SIM card to fall out.]
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
jnowels1
회원 가입일: 04/07/15
322 평판
안내서 1개를 작성함
댓글 3개
contact@davidmarsh.org.uk
what is the name or model or size of the SIM card please?
DavidEL Marsh - 답글
J’ai un problème avec mon téléphone
Abdoulaye Sawadogo - 답글
J’ai un problème avec téléphone
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 81
전체 시간: 7,846
