주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
OnePlus 6 Battery Replacement
필요한 것
    1. OnePlus 6 Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      댓글 쓰기
    2. OnePlus 6 Battery Replacement: 2 단계, 이미지 2개 중 1개 OnePlus 6 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      댓글 쓰기
    3. OnePlus 6 Battery Replacement: 3 단계, 이미지 2개 중 1개 OnePlus 6 Battery Replacement: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      댓글 쓰기
    1. OnePlus 6 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 OnePlus 6 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      댓글 쓰기
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
취소: 해당 안내서를 완성하지 않았습니다.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
John Steven Trammell
회원 가입일: 09/28/21
961 평판
안내서 4개를 작성함
Clemson, Team 4-3, Hunter Fall 2021 Clemson, Team 4-3, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G3
5 회원들
안내서 56개를 작성함
6가이드 댓글
How do I glue the phone back together when I am done? Do I need to add more glue? Do I just heat it with the heat gun again and squeeze it together?
Timothy Magee - 답글 공유
I agree, this is unclear.
The "Parts" section at the top includes "Precut adhesive card", but when you click on that item, it gives a whole bunch of different size options for rolls of tape (8mm, 5mm, 1mm, etc.) and it's unclear which size to get. Does anyone have details of this?
Greg - 답글 공유
Great tutorial, battery is fixed thank you ! If you prefer videos, this one is a good complement https://www.youtube.com/watch?v=OBN7Tc7J...
Kergara B - 답글 공유
Battery good so far, instructions clear enough! I turned the phone on immediately after replacing the battery to make sure everything worked. This was to avoid putting the phone back together only to find it wouldn't turn on, and then having to dismantle it again.
One thing you may want to pay attention to is not to separate the screen (front) layer from the phone, rather than the back side, which is what I did on my first try.
I opted not to get adhesive strips and I simply applied thinly cut electrical tape around the phone's edges, on the outside, to keep it together after fixing. Not terribly aesthetic but does the job well enough, especially if you use a book-style phone case like me.
Pretty doable fix for a first-timer, especially when using the fixit tools (picks, spudgers etc). Happy with the results. Thank you for the guide!
Nic F - 답글 공유
Additional tips (1/2):
1. When buying tools, consider buying a suction handle. This was useful to use on the heated back cover to open up a gap to insert the opening picks into.
2. Consider removing the SIM tray before heating the back cover.
3. When heating the glass back cover, consider wearing some resistant gloves when heating the glass back cover. The glass can get a little got and I was only using a hair dryer on the highest setting, rather than a heat gun.
4. When you have managed to wedge your first opening pick underneath the back cover, take another pick and drag it along the nearest part of the gap to open up the gap further before setting that pick into position. Repeat as you go around the entire edge of the phone. However, BE CAREFUL to not push the opening pick too deep, especially around where the volume buttons are, as the fingerprint sensor cable is located close the edge of the phone.
Adrian Wan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 61
지난 30일: 266
전체 시간: 30,593
