주요 콘텐츠로 건너뛰기
Oontz Angle 3 ULTRA Driver Replacement
Ian
Ian2 다른 기여자
최종 수정일 March 7, 2024
30 분
어려움
더 나은 이미지가 필요함
If your Oontz Angle 3 ULTRA speaker is playing faulty audio, you may need to replace your speaker’s drivers. This replacement guide will walk you through replacing the drivers of your Oontz Angle 3 ULTRA Bluetooth speaker. For this guide, you will need a plastic opening tool, a Phillips #0 Screwdriver, a Soldering Iron with Solder Wick or a Solder Sucker, and a Jimmy. Follow this guide to learn how to solder and de-solder connections. 연결부 납땜 및 납제거 방법
You will need to match the resistance of the speaker’s default drivers with your replacements, or else your Oontz Angle 3 ULTRA will not function properly with the replacement drivers.
필요한 것
도구
더보기...
  1. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Oontz Angle 3 ULTRA Driver Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Driver Replacement: 2 단계, 이미지 3개 중 1개 Oontz Angle 3 ULTRA Driver Replacement: 2 단계, 이미지 3개 중 2개 Oontz Angle 3 ULTRA Driver Replacement: 2 단계, 이미지 3개 중 3개
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Driver Replacement: 3 단계, 이미지 3개 중 1개 Oontz Angle 3 ULTRA Driver Replacement: 3 단계, 이미지 3개 중 2개 Oontz Angle 3 ULTRA Driver Replacement: 3 단계, 이미지 3개 중 3개
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Driver Replacement: 4 단계, 이미지 3개 중 1개 Oontz Angle 3 ULTRA Driver Replacement: 4 단계, 이미지 3개 중 2개 Oontz Angle 3 ULTRA Driver Replacement: 4 단계, 이미지 3개 중 3개
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Driver Replacement, Driver: 5 단계, 이미지 1개 중 1개
    • Insert the Jimmy into the gap between the speaker's grill and the plastic enclosure.
    • Work the Jimmy around the gap to free it from the speaker enclosure.
    • The grill edges are sharp. Be careful and patient when performing this step to avoid injuring yourself.
  6. Oontz Angle 3 ULTRA Driver Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Locate the wires connecting to the driver. There will be a red wire connected to the driver’s positive terminal, and a black wire connected to the driver’s negative terminal.
    • During reassembly, it is important to orient the wires properly to avoid damage to the speaker and new drivers.
    • With your soldering iron and solder sucker, remove the solder connecting the wires to each terminal, and then gently pull the wires away from the terminals to free them.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  7. Oontz Angle 3 ULTRA Driver Replacement: 7 단계, 이미지 2개 중 1개 Oontz Angle 3 ULTRA Driver Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the eight screws with the Phillips #0 screwdriver.
    • Gently push the driver from the rear out of the enclosure to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ian
회원 가입일: 01/16/20
386 평판
안내서 3개를 작성함
댓글 3개
Where can i purchase replacement speaker
John Benedict Sumallo - 답글
reference of speakers of Oontz Angle 3 ULTRA U12A pls to replacement speaker
Luis Calderon - 답글
any luck on replacement speakers?
Tirso Ramirez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 17
전체 시간: 1,089
