주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening Procedure
필요한 것
  1. Opening Procedure, Power down your watch: 1 단계, 이미지 2개 중 1개 Opening Procedure, Power down your watch: 1 단계, 이미지 2개 중 2개
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    댓글 쓰기
  2. Opening Procedure, Unfasten the back cover: 2 단계, 이미지 1개 중 1개
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    댓글 쓰기
  3. Opening Procedure, Loosen the back cover adhesive: 3 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    댓글 쓰기
  4. Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 1개 Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 2개 Opening Procedure, Pry up the back cover assembly: 4 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    댓글 쓰기
  5. Opening Procedure, Disconnect the sensor assembly cable: 5 단계, 이미지 2개 중 1개 Opening Procedure, Disconnect the sensor assembly cable: 5 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  6. Opening Procedure, Remove the back cover assembly: 6 단계, 이미지 3개 중 1개 Opening Procedure, Remove the back cover assembly: 6 단계, 이미지 3개 중 2개 Opening Procedure, Remove the back cover assembly: 6 단계, 이미지 3개 중 3개
    • Remove the back cover assembly.
    댓글 쓰기
결론
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
261,540 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,532개를 작성함
2가이드 댓글
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - 답글 공유
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 56
전체 시간: 2,411
