주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pocophone F1 IPS LCD Screen & Digitizer Replacement
필요한 것
  1. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the SIM tray: 1 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the SIM tray: 1 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the SIM tray: 1 단계, 이미지 3개 중 3개
    • Before you begin, switch off your phone.
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Unfasten the back cover screws: 2 단계, 이미지 1개 중 1개
    • Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
  3. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
    • Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
  4. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Release the clips: 4 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Release the clips: 4 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Release the clips: 4 단계, 이미지 3개 중 3개
    • Slide the opening tool around the bottom right corner.
    • Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
  5. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 5 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the opening tool along the top edge of the phone to release the plastic clips holding the back cover in place.
  6. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening tool along the left edge of the phone to release the remaining plastic clips.
    • Try not to remove the back cover all the way yet, the flex cable of the fingerprint sensor is still connected to the motherboard.
  7. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully fold the phone assembly to the left side of the back cover like you'd open a book page.
    • Avoid tensioning the fingerprint flex cable during this procedure.
  8. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Unfasten screws: 8 단계, 이미지 1개 중 1개
    • Remove the ten 3.2 mm-long Phillips screws.
  9. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 9 단계, 이미지 3개 중 3개
    • Slide an opening pick under the bottom left corner of the motherboard cover.
    • Slide the opening pick around the corner and along the left edge of the motherboard cover to release the plastic clips holding it in place.
    • Use the opening pick to pry up the motherboard cover.
  10. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the motherboard cover: 10 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the motherboard cover: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard cover.
  11. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the back cover: 11 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the back cover: 11 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the back cover: 11 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
    • Remove the back cover.
  12. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the protective foil: 12 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the protective foil: 12 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the protective foil: 12 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to peel the black protective foil off the battery and logic board and remove it.
  13. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the battery connector.
  14. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the interconnect flex cable: 14 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the interconnect flex cable: 14 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the interconnect flex cable: 14 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the interconnect flex cable.
    • Fold the interconnect flex cable out of your way in order to get access to the battery.
    • You might want to use some adhesive tape like tesa and tape the flex cable on your desk to hold it in its folded position.
  15. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Peel off the stickers: 15 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Peel off the stickers: 15 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Peel off the stickers: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers or your fingernails to peel the orange sticker off the battery.
    • Peel the small white sticker off the battery.
  16. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Pull the battery up: 16 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Pull the battery up: 16 단계, 이미지 2개 중 2개
    • Grab both ends of the orange sticker.
    • Pull both ends of the orange sticker straight up to lift the battery out of its recess.
    • If you're having a hard time removing the battery, the adhesive might be a little bit too sticky. You can place a heated iOpener on the screen or use a heat gun to soften the adhesive beneath the battery. Apply the iOpener for at least two minutes.
  17. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the battery: 17 단계, 이미지 1개 중 1개
    • Peel the remaining adhesive off the battery.
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • You can reuse the old adhesive tape if it's still sticky. However if you want to replace your screen you need to remove it and replace it with new custom cut adhesive tape.
  18. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the battery adhesive tape: 18 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the battery adhesive tape: 18 단계, 이미지 2개 중 2개
    • Peel the remaining battery adhesive tape off the midframe.
  19. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the screen: 19 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the screen: 19 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Disconnect the screen: 19 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry up and disconnect the display flex cable.
    • Peel the display flex cable off the midframe.
  20. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Soften the display adhesive: 20 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
  21. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening pick: 21 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening pick: 21 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Insert an opening pick: 21 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom of the screen, as close to the edge as possible.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  22. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 22 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 22 단계, 이미지 2개 중 2개
    • Insert a second opening pick under the center of the bottom edge of the screen and slide it to the bottom left corner to cut the adhesive.
    • Leave the picks in their place to prevent the adhesive from resealing.
  23. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Slice the adhesive: 23 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Slice the adhesive: 23 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Slice the adhesive: 23 단계, 이미지 3개 중 3개
    • Insert a third opening pick under the bottom left corner of the phone.
    • Slide the opening pick up to the top left corner to slice the adhesive. Leave it there to prevent the adhesive from resealing.
    • If cutting becomes too difficult, reheat and reapply the iOpener.
  24. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 24 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 24 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick at the top left corner.
    • When nearing the front facing camera, only work with the tip of the opening pick to avoid damaging or smearing the camera.
    • Slide the opening pick along the top edge of the phone to cut the adhesive. Leave the pick in the top right corner of the screen to prevent the adhesive from resealing.
  25. Pocophone F1 IPS LCD Screen & Digitizer Replacement: 25 단계, 이미지 2개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement: 25 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick and slide it along the right edge of the phone to cut the remaining adhesive.
    • Try not to remove the display all the way yet, the display cable is still threaded through the frame and possible adhered on the inner side of the midframe.
  26. Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the display: 26 단계, 이미지 3개 중 1개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the display: 26 단계, 이미지 3개 중 2개 Pocophone F1 IPS LCD Screen & Digitizer Replacement, Remove the display: 26 단계, 이미지 3개 중 3개
    • Thread the display flex cable through the gap in the midframe and remove the display.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery.
다른 20명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
257,290 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,563개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 44
지난 30일: 147
전체 시간: 22,630
