주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement
Walter Galan
Walter Galan7 다른 기여자
최종 수정일 July 31, 2013
예상시간 없음
조정
Remove your upper case to access the internals of your PowerBook.
필요한 것
부품
도구
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • TR8 Torx Security Screwdriver
더보기...
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Battery: 1 단계, 이미지 2개 중 1개 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Memory Door: 2 단계, 이미지 1개 중 1개
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 3 단계, 이미지 2개 중 1개 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Upper Case: 4 단계, 이미지 1개 중 1개
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 5 단계, 이미지 2개 중 1개 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 5 단계, 이미지 2개 중 2개
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 6 단계, 이미지 1개 중 1개
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 9 단계, 이미지 2개 중 1개 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 9 단계, 이미지 2개 중 2개
    • Depress the display latch release button and open your display.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 10 단계, 이미지 2개 중 1개 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: 10 단계, 이미지 2개 중 2개
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
결론
첨부 문서
작성자
7다른 기여자 명과 함께
Walter Galan
701,292 평판
안내서 1,203개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 18
전체 시간: 4,241
