주요 콘텐츠로 건너뛰기
Razer BlackShark V2 Cable Replacement
BlakeB
BlakeB2 다른 기여자
최종 수정일 September 16, 2023
20 - 35 분
조정
If your Razer BlackShark V2 is producing choppy, interrupted, or no audio, your headset’s cable may be damaged (to confirm diagnoses & solutions, see Razer Blackshark V2 Troubleshooting Page, "Audio Cutting Out" or “No Audio at All”). This guide will assist you in the replacement of this component. Be mindful of which layers of the headset assembly you're taking apart and that you don't adversely damage the holds, small wires, ear cushions, ear cushions’ rubber linings or plastic ridges, or headset itself when applying pressure.
필요한 것
도구
  1. Razer BlackShark V2 Cable Replacement, Ear Cushion: 1 단계, 이미지 1개 중 1개
    • Place the headset so that the left side is facing you.
    • The left side of the headset has the cable attachment and the volume control knob.
  2. Razer BlackShark V2 Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Scoop your middle and ring finger underneath the top or bottom inner portion of the ear cushion.
    • You should feel a hard plastic ridge.
    • Pull from the hard plastic ridge, being sure not to pull from the soft cushion.
    • Slowly apply pressure to prevent damage.
  3. Razer BlackShark V2 Cable Replacement: 3 단계, 이미지 1개 중 1개
  4. Razer BlackShark V2 Cable Replacement: 4 단계, 이미지 2개 중 1개 Razer BlackShark V2 Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Once the cushion is removed, make sure the hard plastic base with the clips is attached to it.
    • If you are replacing both ear cushions, repeat Steps 1-4 for the other side. Then, insert the new ear cushions by lining up the clips in their respective holes and applying even pressure until they audibly click.
  5. Razer BlackShark V2 Cable Replacement, Speaker: 5 단계, 이미지 2개 중 1개 Razer BlackShark V2 Cable Replacement, Speaker: 5 단계, 이미지 2개 중 2개
    • Remove the four screws holding the speaker in the headset using a Phillips #1 screwdriver.
  6. Razer BlackShark V2 Cable Replacement: 6 단계, 이미지 2개 중 1개 Razer BlackShark V2 Cable Replacement: 6 단계, 이미지 2개 중 2개
    • Gently grab the headset and slowly apply pressure to the speaker cover; it will come off.
    • Be careful of the wires that are attached to the back of the speaker to ensure they won't be damaged when removing the speaker and its cover.
  7. Razer BlackShark V2 Cable Replacement: 7 단계, 이미지 3개 중 1개 Razer BlackShark V2 Cable Replacement: 7 단계, 이미지 3개 중 2개 Razer BlackShark V2 Cable Replacement: 7 단계, 이미지 3개 중 3개
    • After disconnecting the speaker from the headset, it is still connected by the wires that power the speaker itself.
    • With heat or with a sharp tool, remove the glue around the wires that connect the speaker to the headset.
    • Using the new speaker, you can reattach the wires soldering them in with existing glue.
    • If replacing internal components and NOT the speaker, you can do so without severing any wire connections; operate carefully to not sever them unnecessarily!
  8. Razer BlackShark V2 Cable Replacement, Cable: 8 단계, 이미지 2개 중 1개 Razer BlackShark V2 Cable Replacement, Cable: 8 단계, 이미지 2개 중 2개
    • Locate the main cable after it protrudes through the opening in the headset and where the cable is attached to the motherboard.
  9. Razer BlackShark V2 Cable Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the connecting glue attaching the wires to the motherboard with a sharp object or heat.
    • Be careful around the motherboard when removing the connected wires.
  10. Razer BlackShark V2 Cable Replacement: 10 단계, 이미지 2개 중 1개 Razer BlackShark V2 Cable Replacement: 10 단계, 이미지 2개 중 2개
    • Reattach the new cable with the soldering iron.
    • Be sure not to damage the motherboard when resoldering the new cable.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
BlakeB
회원 가입일: 03/08/23
545 평판
안내서 3개를 작성함
댓글 4개
any chance you have a guide to replacing the battery?
Bradix Thresher - 답글
Never mind figured it out, battery is on the right earpiece... Love all your guides though!!
Bradix Thresher -
Cuál es el orden del cableado en el plug 3.5 porfavoor! No lo encuentro por ningún lado :(
Panerukk M. - 답글
donde consigo un repuesto del cable de los audífonos??
Where do I get a replacement headphone cable??
Irvin Cvrs - 답글
댓글 쓰기
조회 통계:
지난 24시간: 11
지난 7일: 100
지난 30일: 266
전체 시간: 6,457
