How to disconnect the battery assembly of the Huawei Watch GT 2 (46 mm)
Prerequisite only! Use this guide to disconnect the battery assembly in your Huawei Watch GT 2 (46 mm).
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
Use a pair of tweezer to remove the metal shield covering the multi-purpose flex connector.
Use the flat end of a spudger to pry up and disconnect the multi-purpose flex connector.
