주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Steam Controller (2nd Gen, 2026) Buttons Replacement
필요한 것
  1. Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: 1 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: 1 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Before you begin: 1 단계, 이미지 3개 중 3개
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    댓글 쓰기
  2. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover screws: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    TR6 Torx Security Screwdriver
    $5.99
    댓글 쓰기
  3. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover: 3 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the back cover: 3 단계, 이미지 2개 중 2개
    • Remove the back cover.
    댓글 쓰기
  4. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the battery: 4 단계, 이미지 3개 중 3개
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    댓글 쓰기
  5. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket screws: 5 단계, 이미지 2개 중 2개
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    댓글 쓰기
  6. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the mounting bracket: 6 단계, 이미지 2개 중 2개
    댓글 쓰기
  7. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the rumble motors: 7 단계, 이미지 3개 중 3개
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    댓글 쓰기
  8. Steam Controller (2nd Gen, 2026) Buttons Replacement: 8 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 8 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 8 단계, 이미지 3개 중 3개
    • Repeat to disconnect the other rumble motor.
    댓글 쓰기
  9. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the interconnect cable: 9 단계, 이미지 3개 중 3개
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    댓글 쓰기
  10. Steam Controller (2nd Gen, 2026) Buttons Replacement: 10 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 10 단계, 이미지 2개 중 2개
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    댓글 쓰기
  11. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board screws: 11 단계, 이미지 3개 중 3개
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    댓글 쓰기
  12. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: 12 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: 12 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the main board: 12 단계, 이미지 3개 중 3개
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    댓글 쓰기
  13. Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: 13 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: 13 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Rubber piece information: 13 단계, 이미지 3개 중 3개
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    댓글 쓰기
  14. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the hinge pin: 14 단계, 이미지 3개 중 3개
    • With one hand, hold one of the triggers down in the fully actuated position.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be aligned with the white rectangle on the board (labelled PIN)—the should be no wobble.
    댓글 쓰기
  15. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: 15 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: 15 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the trigger: 15 단계, 이미지 3개 중 3개
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
    댓글 쓰기
  16. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the other trigger: 16 단계, 이미지 3개 중 3개
    • Repeat to remove the other trigger.
    댓글 쓰기
  17. Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: 17 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: 17 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Reassembly information: 17 단계, 이미지 3개 중 3개
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
    댓글 쓰기
  18. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe screws: 18 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe screws: 18 단계, 이미지 2개 중 2개
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to damage the plastic button membrane.
    댓글 쓰기
  19. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: 19 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: 19 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the midframe: 19 단계, 이미지 3개 중 3개
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone pads are now sitting loose in their recesses. Be very careful not to flip the front shell, or the buttons will fall out.
    • During reassembly:
    • Check the two large silicone button pads to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
    댓글 쓰기
  20. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: 20 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: 20 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the button membranes: 20 단계, 이미지 3개 중 3개
    • Remove the three silicone button membranes.
    댓글 쓰기
  21. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: 21 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: 21 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the buttons: 21 단계, 이미지 3개 중 3개
    • Use tweezers to remove the D‑Pad, View, Steam, Menu, and ABXY buttons.
    • Alternatively, you can flip the front case over and let the buttons fall out.
    • To replace the Quick Access Menu button, you'll need to remove the remaining board attached to the front shell. Check out this guide to do so.
    • During reassembly, use the alignment tabs to orient each button in its recess. Each one is keyed specifically for its recess and proper orientation.
    댓글 쓰기
  22. Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: 22 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: 22 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Seat the button dampeners: 22 단계, 이미지 3개 중 3개
    • Make sure the button dampeners (that surround the button recesses) are pushed down and fully seated against the shell. Otherwise, button presses may feel off or not register.
    댓글 쓰기
  23. Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: 23 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: 23 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Disconnect the touchpad cables: 23 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to lift the hinged, locking flap on one of the touchpad ZIF connectors.
    댓글 쓰기
  24. Steam Controller (2nd Gen, 2026) Buttons Replacement: 24 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 24 단계, 이미지 2개 중 2개
    댓글 쓰기
  25. Steam Controller (2nd Gen, 2026) Buttons Replacement: 25 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 25 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement: 25 단계, 이미지 3개 중 3개
    • Repeat to disconnect the other touchpad cable.
    댓글 쓰기
  26. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board screws: 26 단계, 이미지 2개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board screws: 26 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
    댓글 쓰기
  27. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: 27 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: 27 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the FSC board: 27 단계, 이미지 3개 중 3개
    • Remove the FSC board.
    • Use the alignment pegs to ensure the board is correctly positioned.
    댓글 쓰기
  28. Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: 28 단계, 이미지 3개 중 1개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: 28 단계, 이미지 3개 중 2개 Steam Controller (2nd Gen, 2026) Buttons Replacement, Remove the Quick Access Menu button: 28 단계, 이미지 3개 중 3개
    • Remove the Quick Access Menu membrane and button.
    • During reassembly, make sure the silicone button dampener (it surrounds the button recess) is fully pushed down and seated against the shell.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
196,232 평판
안내서 1,243개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 113
지난 30일: 616
전체 시간: 2,096
