주요 콘텐츠로 건너뛰기
TI-Nspire CX Battery Replacement
Jim Kerman
Jim Kerman7 다른 기여자
최종 수정일 March 10, 2025
10 분
쉬움
If your TI-Nspire CX calculator isn't powering on after being charged, or appears to need charged more often or for longer than usual, you may need to replace the battery. Use this guide to replace the calculator's internal rechargeable battery.
The rechargeable battery may become damaged or faulty with repeated use and charging cycles. A faulty battery will store less energy or no energy at all.
Step 3 requires you to disconnect and remove the old battery. Before removing the old battery, inspect it for damage such as leaking or appearing puffy. Damaged batteries are a fire hazard. If the battery appears damaged, you must take appropriate precautions.
Before using this guide, be sure to power off the calculator completely.
If the battery appears to be punctured do not use it.
Use an official Texas Instruments battery for optimal performance.
필요한 것
부품
도구
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. TI-Nspire CX Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to loosen the captive screws on the back plate of the calculator.
    • The screws do not come all the way out. Simply twist them until you are able to remove the back plate.
  2. TI-Nspire CX Battery Replacement: 2 단계, 이미지 2개 중 1개 TI-Nspire CX Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the back plate using the spudger or by hand.
  3. TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 1개 TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 2개 TI-Nspire CX Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Carefully disconnect and remove the old battery.
    • Unhook the wire from the tab.
    • Carefully pull out the connector.
    • Grip the wire close to the top and pull away.
  4. TI-Nspire CX Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Plug in the new battery.
    • Make sure to put the wire back in the same way. You should see 4 metal connections on top
  5. TI-Nspire CX Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Position the new battery and tuck the wire under the tab.
  6. TI-Nspire CX Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Replace the back plate and the 2 screws.
결론
Now charge your calculator and power it up. If replacing the battery does not solve your problem, it may be a problem with your charging cord or the internal sockets.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jim Kerman
회원 가입일: 02/24/15
335 평판
안내서 1개를 작성함
Cal Poly, Team 24-2, Green Winter 2015 Cal Poly, Team 24-2, Green Winter 2015 회원
CPSU-GREEN-W15S24G2
4 회원들
안내서 4개를 작성함
댓글 2개
Hi. I own a TI Nspire CX CAS. I’ve had it for 5 years now and the battery’s been screwy for the past few years. I just ordered a new battery with good reviews from amazon. I’m worried that if I take out the battery my documents and other saved settings will be deleted. Does removing the battery delete anything? I have the modded operating system for my oldschool gameboy games, so I really don’t want to lose my games and settings, as the laptop I used years ago to put the games on there has been broken. I would really appreciate any help. Thank you.
G Reod - 답글
Hola Amigo. Pudiste solucionar?
Armando02 -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 14
지난 30일: 100
전체 시간: 17,595
