주요 콘텐츠로 건너뛰기
Xiaomi Redmi Note 11 Pro Battery Replacement
필요한 것
  1. Xiaomi Redmi Note 11 Pro Battery Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 11 Pro Battery Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • If you're having trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Xiaomi Redmi Note 11 Pro Battery Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Slice the bottom edge adhesive: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 11 Pro Battery Replacement, Slice the left edge adhesive: 4 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Slice the left edge adhesive: 4 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Slice the left edge adhesive: 4 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 11 Pro Battery Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 11 Pro Battery Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • At this point, the rear glass should be separated from the frame. If there's still resistance around the edges of the glass, use an opening pick to separate any remaining adhesive.
  7. Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the rear glass: 7 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the rear glass: 7 단계, 이미지 2개 중 2개
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. Xiaomi Redmi Note 11 Pro Battery Replacement, Eject the SIM card tray: 8 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Eject the SIM card tray: 8 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Eject the SIM card tray: 8 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the bottom edge of the phone.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  9. Xiaomi Redmi Note 11 Pro Battery Replacement, Unfasten the midframe screws: 9 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Unfasten the midframe screws: 9 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the seventeen 3.6 mm-long screws securing the midframe.
  10. Xiaomi Redmi Note 11 Pro Battery Replacement, Insert an opening pick: 10 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Insert an opening pick: 10 단계, 이미지 2개 중 2개
    • The midframe of the Xiaomi Redmi Note 11 Pro is held in place by plastic clips.
    • Insert an opening pick between the midframe and front panel assembly on the bottom left edge of the phone where the SIM tray slot is located.
  11. Xiaomi Redmi Note 11 Pro Battery Replacement, Release the plastic clips: 11 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Release the plastic clips: 11 단계, 이미지 2개 중 2개
    • The plastic clips of the midframe are sitting in place tightly. Releasing them might require some force.
    • Slide the opening pick around the bottom left corner of the phone to release the plastic clips.
  12. Xiaomi Redmi Note 11 Pro Battery Replacement: 12 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 12 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the opening pick along the left edge of the phone to release the plastic clips.
  13. Xiaomi Redmi Note 11 Pro Battery Replacement: 13 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 13 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement: 13 단계, 이미지 3개 중 3개
    • Slide the opening pick around the top left corner and along the top edge of the phone to release the plastic clips.
  14. Xiaomi Redmi Note 11 Pro Battery Replacement: 14 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 14 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement: 14 단계, 이미지 3개 중 3개
    • Slide the opening pick around the top right corner and along the right edge of the phone to release the remaining plastic clips.
    • Do not try to remove the midframe all the way yet. The midframe cable is still connected to the motherboard.
  15. Xiaomi Redmi Note 11 Pro Battery Replacement, Free the midframe cable connector: 15 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Free the midframe cable connector: 15 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Free the midframe cable connector: 15 단계, 이미지 3개 중 3개
    • Carefully swing open the midframe to the left like you would open the front cover of a book to get free access to its cable connector.
    • Place the midframe next to the left edge of the front panel assembly.
  16. Xiaomi Redmi Note 11 Pro Battery Replacement, Disconnect the midframe cable: 16 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Disconnect the midframe cable: 16 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the midframe cable by prying the connector straight up from its socket.
  17. Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the midframe: 17 단계, 이미지 1개 중 1개
    • Remove the midframe.
  18. Xiaomi Redmi Note 11 Pro Battery Replacement, Disconnect the battery cables: 18 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Disconnect the battery cables: 18 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Disconnect the battery cables: 18 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the left and right battery cable by prying the connectors straight up from their socket.
  19. Xiaomi Redmi Note 11 Pro Battery Replacement, Peel off the battery pull-tabs: 19 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Peel off the battery pull-tabs: 19 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Peel off the battery pull-tabs: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labeled with an A off the battery.
  20. Xiaomi Redmi Note 11 Pro Battery Replacement: 20 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement: 20 단계, 이미지 2개 중 2개
    • Repeat the previous pull-tab procedure on the orange adhesive strip labeled with a B.
  21. Xiaomi Redmi Note 11 Pro Battery Replacement, Lift the battery: 21 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Lift the battery: 21 단계, 이미지 2개 중 2개
    • Grab both pull-tab ends labeled with an A and pull up on the adhesive strip to lift the battery out of its recess and swing it up to an upright position.
    • If you're having trouble lifting the battery out of its recess, apply a heated iOpener to the screen for two minutes to loosen the battery adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  22. Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the battery: 22 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the battery: 22 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 11 Pro Battery Replacement, Remove the battery: 22 단계, 이미지 3개 중 3개
    • Peel the battery off the remaining adhesive.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly, apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dominik Schnabelrauch
회원 가입일: 11/23/16
247,693 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
2가이드 댓글
IS there a way to shorten the battery? Im planing to make an "z-flip" mod, so its an flipable budget phone. Also trying to make the mod public if suceed
Neo Meier - 답글
Or maybe also make the batterycable longer?
Neo Meier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 111
지난 30일: 454
전체 시간: 14,517
