주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note 6 Pro Battery Replacement
필요한 것
    1. Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: 1 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: 1 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Eject the SIM tray: 1 단계, 이미지 3개 중 3개
      • Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
      • Press directly into the hole to eject the SIM card tray.
      • Remove the SIM card tray.
      댓글 쓰기
    1. Xiaomi Redmi Note 6 Pro Battery Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
      • The back cover is held in place by plastic clips.
      • Insert an opening pick between the screen and the back cover on the left edge of the phone where the SIM card tray was located.
      댓글 쓰기
    2. Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the plastic clips: 3 단계, 이미지 3개 중 3개
      • Slide the opening pick along the left edge to the bottom left corner to release the plastic clips.
      댓글 쓰기
    3. Xiaomi Redmi Note 6 Pro Battery Replacement: 4 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement: 4 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Slide the opening pick along the bottom edge to the bottom right corner to release the plastic clips.
      댓글 쓰기
    4. Xiaomi Redmi Note 6 Pro Battery Replacement: 5 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement: 5 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement: 5 단계, 이미지 3개 중 3개
      • Slide the opening pick along the right edge of your phone to the top right corner to release the plastic clips.
      댓글 쓰기
    5. Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: 6 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: 6 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Release the remaining plastic clips: 6 단계, 이미지 3개 중 3개
      • Slide the opening pick along the top edge to release the remaining plastic clips.
      • Don't try to remove the back cover all the way yet! It's still connected to the motherboard!
      댓글 쓰기
    6. Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: 7 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: 7 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Swing open the phone assembly: 7 단계, 이미지 3개 중 3개
      • Carefully fold the phone assembly to the left side of the back cover like you'd open a book.
      댓글 쓰기
    7. Xiaomi Redmi Note 6 Pro Battery Replacement, Unscrew the fingerprint cable connector cover: 8 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the 2.9 mm-long screw securing the fingerprint cable connector cover.
      댓글 쓰기
    8. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: 9 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: 9 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the metal cover: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of blunt nose tweezers to remove the metal cover.
      댓글 쓰기
    9. Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the fingerprint sensor: 10 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the fingerprint sensor: 10 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to disconnect the fingerprint sensor cable.
      댓글 쓰기
    10. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the back cover: 11 단계, 이미지 1개 중 1개
      • Remove the back cover.
      댓글 쓰기
    1. Xiaomi Redmi Note 6 Pro Battery Replacement, Unscrew the battery connector cover: 12 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the two 3.0 mm-long screws securing the battery connector cover.
      댓글 쓰기
    2. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: 13 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: 13 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery connector cover: 13 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a pair of blunt nose tweezers to remove the battery connector cover.
      댓글 쓰기
    3. Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Disconnect the battery: 14 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      댓글 쓰기
    1. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: 15 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: 15 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the stretch-release adhesive: 15 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • The battery is secured to the rear case with two pieces of stretch-release adhesive.
      • Use a pair of tweezers or a clean fingernail to peel down both battery adhesive pull-tabs to un-stick them from the bottom edge of the battery.
      • Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
      댓글 쓰기
    2. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the pull-tabs: 16 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the pull-tabs: 16 단계, 이미지 2개 중 2개
      • Grab the first pull-tab with a pair of tweezers or your fingers and slowly pull it away from the battery and towards the bottom edge of your phone.
      • Pull hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
      • Don't press down on the battery. Hold the Redmi firmly by its sides.
      • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
      • Pull at a low angle so the strip doesn't snag on the edge of the battery.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
      • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
      댓글 쓰기
    3. Xiaomi Redmi Note 6 Pro Battery Replacement: 17 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement: 17 단계, 이미지 2개 중 2개
      • Repeat the previous pull-tab removal procedure on the second pull-tab.
      • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
      • If the adhesive breaks off underneath the battery and can't be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
      • Wait about one minute for the alcohol solution to weaken the adhesive.
      • Use the flat end of a spudger to gently lift the battery.
      • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
      댓글 쓰기
    4. Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: 18 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: 18 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 6 Pro Battery Replacement, Remove the battery: 18 단계, 이미지 3개 중 3개
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Before installing a new battery remove any remaining adhesive, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      • During reassembly, temporarily reconnect the battery to the motherboard to help align it correctly. Disconnect the battery after it is seated.
      댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,816 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 32,361개를 작성함
1가이드 댓글
un tuto très clair et bien détaillé, une belle qualité, merci
Gerbi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 27
지난 30일: 91
전체 시간: 10,174
