소개
Use this guide to replace the battery in your Xiaomi Redmi Note 9T.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You'll need replacement adhesive in order to complete this repair.
필요한 것
Insert a SIM card eject tool into the small hole in the SIM card tray, located on the upper left edge edge of the phone.
Press firmly to eject the tray.
Insert an opening pick in a steep angle between the display assembly and the back cover where the charging port is located. This might require some force.
Slide the opening pick to the bottom right corner to release the plastic clips holding the back cover in place.
Leave the opening pick in the bottom right corner to prevent the clips from snapping back into place.
Slide the bottom left opening pick along the left edge of your phone to release the plastic clips.
Leave the opening pick in the top left corner to prevent the clips from snapping back into place.
Slide the bottom right opening pick along the right edge of your phone to release the plastic clips.
Leave the opening pick in the top right corner to prevent the clips from snapping back into place.
Slide the left opening pick around the top left corner to release the top edge plastic clips.
Carefully fold the back cover to the left side of the phone assembly like you would open the cover of a book.
Use a Phillips screwdriver to remove the ten 3.9 mm-long screws securing the motherboard cover.
Insert an opening pick underneath the bottom right edge of the motherboard cover.
Slide the opening pick along the right edge of the motherboard cover to release its plastic clips.
Twist the opening pick sideways to pry up the motherboard cover.
Use a spudger to disconnect the home and volume button cable by prying the connector straight up from its socket.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Grab both pull-tab ends labeled with an A and pull up on the adhesive strip to lift the battery out of its recess and swing it up to an upright position.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xiaomi Redmi Note 9T answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
