소개
This is a guide for replacing the motherboard of your Zeki device.
First, to reach the motherboard, remove the plastic backing, then the battery, and lastly the camera.
After replacing the motherboard, the device will need to be reassembled in the opposite order.
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
