소개
Use this guide to replace the headphone/microphone jacks on your iMac.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Disconnect the audio port cable by pulling its connector toward the left side of the iMac.
Peel the audio port cable off the front face of the logic board.
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
