주요 콘텐츠로 건너뛰기
iPhone 16 Pro Max Battery Replacement
필요한 것
  1. iPhone 16 Pro Max Battery Replacement, Before you begin: 1 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement, Before you begin: 1 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement, Before you begin: 1 단계, 이미지 3개 중 3개
    • Allow your iPhone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your iPhone.
    • Hold the power and either volume buttons, and slide to power off your iPhone.
  2. iPhone 16 Pro Max Battery Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 2개
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Max Battery Replacement, Remove the pentalobe screws: 3 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the pentalobe screws: 3 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
  4. iPhone 16 Pro Max Battery Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement, Mark your opening picks: 4 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 16 Pro Max Battery Replacement, Create a gap using a suction handle: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iOpener
    $14.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Max Battery Replacement: 6 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 6 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with strong, steady force to create a gap between the back glass and the frame.
    • If a gap doesn't appear, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Max Battery Replacement, Back glass information: 7 단계, 이미지 1개 중 1개
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the iPhone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the iPhone.
  8. iPhone 16 Pro Max Battery Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 2개 중 2개
    • Slide the opening pick along the bottom edge to slice the adhesive.
    • If the adhesive feels difficult to slice, reheat the edge for a minute and try again.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Max Battery Replacement, Heat the left edge: 9 단계, 이미지 1개 중 1개
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  10. iPhone 16 Pro Max Battery Replacement, Separate the left adhesive: 10 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Separate the left adhesive: 10 단계, 이미지 2개 중 2개
    • Insert a second opening pick into the bottom-left corner, close to the existing pick.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick along the left edge to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Max Battery Replacement, Heat the top edge and corner: 11 단계, 이미지 1개 중 1개
    • Use a hair dryer or heat gun to heat the top edge and top-right corner of the back glass until it's hot to the touch.
  12. iPhone 16 Pro Max Battery Replacement, Separate the top adhesive: 12 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Separate the top adhesive: 12 단계, 이미지 2개 중 2개
    • Insert a third opening pick into the top-left corner.
    • Slide the opening pick along the top edge and around the top-right corner, stopping above the volume up button.
    • Leave this pick inserted to prevent the adhesive from resealing.
  13. iPhone 16 Pro Max Battery Replacement, Heat the right edge: 13 단계, 이미지 1개 중 1개
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  14. iPhone 16 Pro Max Battery Replacement, Separate the right adhesive: 14 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Separate the right adhesive: 14 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick into the bottom-right corner.
    • Slide the opening pick around the corner and up the right edge, stopping below the volume down button.
  15. iPhone 16 Pro Max Battery Replacement, Reposition the back glass: 15 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement, Reposition the back glass: 15 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement, Reposition the back glass: 15 단계, 이미지 3개 중 3개
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the iPhone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
  16. iPhone 16 Pro Max Battery Replacement, Remove the battery connector cover: 16 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to remove the three screws securing the battery connector cover:
    • Two 1.3 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Max Battery Replacement: 17 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 17 단계, 이미지 2개 중 2개
    • Lift and remove the battery connector cover.
  18. iPhone 16 Pro Max Battery Replacement, Disconnect the battery: 18 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Disconnect the battery: 18 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  19. iPhone 16 Pro Max Battery Replacement, Remove the back glass connector cover: 19 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to remove the four screws securing the back glass connector cover:
    • Two 1.0 mm‑long screws
  20. iPhone 16 Pro Max Battery Replacement: 20 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 20 단계, 이미지 2개 중 2개
    • Lift the back glass connector cover straight up and remove it.
  21. iPhone 16 Pro Max Battery Replacement, Remove the back glass: 21 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the back glass: 21 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the back glass connector.
  22. iPhone 16 Pro Max Battery Replacement: 22 단계, 이미지 1개 중 1개
    • Remove the back glass.
  23. iPhone 16 Pro Max Battery Replacement, Remove the Taptic Engine cover: 23 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the Taptic Engine cover: 23 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
    • One 2.9 mm‑long screw
    • One 1.3 mm‑long screw
    • One 2.4 mm‑long screw
  24. iPhone 16 Pro Max Battery Replacement: 24 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 24 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 24 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
    • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
  25. iPhone 16 Pro Max Battery Replacement, Loosen the lower assembly cable: 25 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Loosen the lower assembly cable: 25 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the lower assembly cable from the logic board.
  26. iPhone 16 Pro Max Battery Replacement: 26 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 26 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 26 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and disconnect the two connectors near the bottom right edge of the frame.
  27. iPhone 16 Pro Max Battery Replacement: 27 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 27 단계, 이미지 2개 중 2개
    • Remove the two screws securing the lower assembly cable:
    • One 1.0 mm‑long tri-point Y000 screw
    • One 1.3 mm‑long Phillips screw
  28. iPhone 16 Pro Max Battery Replacement: 28 단계, 이미지 1개 중 1개
    • Use a hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
  29. iPhone 16 Pro Max Battery Replacement: 29 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 29 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 29 단계, 이미지 3개 중 3개
    • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
    • Carefully bend the cable out of the way so you can access the Taptic Engine.
  30. iPhone 16 Pro Max Battery Replacement, Remove the Taptic Engine: 30 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 2.1 mm‑long screw securing the Taptic Engine.
  31. iPhone 16 Pro Max Battery Replacement: 31 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 31 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pivot the corner bracket up.
  32. iPhone 16 Pro Max Battery Replacement: 32 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 32 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 32 단계, 이미지 3개 중 3개
    • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
  33. iPhone 16 Pro Max Battery Replacement: 33 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 33 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 33 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up the Taptic Engine.
    • Be careful not to pry against the battery.
    • Remove the Taptic Engine.
  34. iPhone 16 Pro Max Battery Replacement, Remove the loudspeaker: 34 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the loudspeaker: 34 단계, 이미지 2개 중 2개
    • Remove the four screws securing the loudspeaker:
    • One 1.7 mm‑long Phillips screw
    • One 1.5 mm‑long Phillips screw
    • One 4.1 mm‑long standoff screw
    • One 1.3 mm‑long tri-point Y000 screw
  35. iPhone 16 Pro Max Battery Replacement: 35 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 35 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 35 단계, 이미지 3개 중 3개
    • Insert the point of a spudger underneath the loudspeaker's bottom-right screw hole.
    • Pry up and remove the loudspeaker.
  36. iPhone 16 Pro Max Battery Replacement, Battery adhesive information: 36 단계, 이미지 1개 중 1개
    • Your iPhone's battery is secured with three stretch release adhesive strips. The next four steps show how to remove them and free your battery.
    • Be careful not to dent or puncture the battery. Avoid using sharp tools near it.
  37. iPhone 16 Pro Max Battery Replacement, Remove the battery: 37 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the battery: 37 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement, Remove the battery: 37 단계, 이미지 3개 중 3개
    • Use the tip of an opening pick to separate a black pull tab from the bottom of the battery.
    • Use tweezers to help peel the tab away from the battery.
    • Don't try to pull the tab out from under the battery just yet.
  38. iPhone 16 Pro Max Battery Replacement: 38 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 38 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 38 단계, 이미지 3개 중 3개
    • Use tweezers or your fingers to grab the pull tab.
    • Slowly pull the adhesive out from under the battery at as low of an angle as possible.
    • Give the strip plenty of time to stretch and re-grip it as necessary. Avoid dragging it over the components or cables above the battery.
    • When the strip becomes too long, wrap it around your tweezers and continue pulling.
    • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, move onto the next strip.
  39. iPhone 16 Pro Max Battery Replacement: 39 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 39 단계, 이미지 2개 중 2개
    • Repeat the procedure with the two remaining adhesive strips.
    • Carefully bend the lower assembly cable out of the way as needed to access the adhesive strips.
  40. iPhone 16 Pro Max Battery Replacement: 40 단계, 이미지 1개 중 1개
    • If you removed all three stretch release adhesive strips, congratulations! Remove the battery and skip down three steps for reassembly instructions.
    • If one or more adhesive strips broke, skip to the next step to remove them with isopropyl alcohol.
  41. iPhone 16 Pro Max Battery Replacement, Alternate method to remove the battery: 41 단계, 이미지 1개 중 1개
    • The next two steps show how to remove the battery if the adhesive strips broke.
    • Lift the bottom edge of the frame to tilt the iPhone.
    • Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
  42. iPhone 16 Pro Max Battery Replacement: 42 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 42 단계, 이미지 2개 중 2개
    • Insert the flat edge of an opening pick between the left edge of the battery and the frame.
    • Pry the battery upwards slowly with steady force. Give the adhesive time to release.
    • Don't bend or crease the battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Once the adhesive loosens, grab and remove the battery.
  43. iPhone 16 Pro Max Battery Replacement, Disassembly complete: 43 단계, 이미지 1개 중 1개
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
  44. iPhone 16 Pro Max Battery Replacement, Install the replacement battery: 44 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Install the replacement battery: 44 단계, 이미지 2개 중 2개
    • Remove any remaining adhesive from the battery recess. Wipe the frame surface with a lint-free cloth and a few drops of isopropyl alcohol.
  45. iPhone 16 Pro Max Battery Replacement: 45 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Stretch Release Battery Adhesive
    $3.99
  46. iPhone 16 Pro Max Battery Replacement: 46 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 46 단계, 이미지 2개 중 2개
    • The battery adhesive is very sticky! Be careful as you align the battery in its recess—once it sticks, you won't be able to realign it.
    • Lower the battery partially into its recess.
    • Temporarily connect the battery to the logic board to ensure that the cable reaches.
    • Lay the battery in its recess.
  47. iPhone 16 Pro Max Battery Replacement: 47 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 47 단계, 이미지 2개 중 2개
    • Use your fingers to press firmly against the battery for ten seconds to bond it to the frame.
    • Disconnect the battery from the logic board.
  48. iPhone 16 Pro Max Battery Replacement, Install the loudspeaker: 48 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Install the loudspeaker: 48 단계, 이미지 2개 중 2개
    • Angle the bottom edge of the loudspeaker towards the frame.
    • Press the loudspeaker into its recess.
  49. iPhone 16 Pro Max Battery Replacement: 49 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 49 단계, 이미지 2개 중 2개
    • Install the four screws securing the loudspeaker:
  50. iPhone 16 Pro Max Battery Replacement, Install the Taptic Engine: 50 단계, 이미지 1개 중 1개
    • Lay the Taptic Engine in its recess.
  51. iPhone 16 Pro Max Battery Replacement: 51 단계, 이미지 1개 중 1개
    • Use your finger to pivot the corner bracket down into place.
  52. iPhone 16 Pro Max Battery Replacement: 52 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to install the 2.1 mm‑long screw securing the Taptic Engine.
  53. iPhone 16 Pro Max Battery Replacement: 53 단계, 이미지 1개 중 1개
    • Use your finger to gently press the lower assembly cable onto the top of the Taptic Engine.
  54. iPhone 16 Pro Max Battery Replacement: 54 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 54 단계, 이미지 2개 중 2개
    • Install the two screws securing the lower assembly cable:
  55. iPhone 16 Pro Max Battery Replacement: 55 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 55 단계, 이미지 2개 중 2개
    • Use your finger or a spudger to press and connect the two lower assembly cable connectors.
  56. iPhone 16 Pro Max Battery Replacement: 56 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 56 단계, 이미지 2개 중 2개
    • Lay the Taptic Engine cover in place and align it by its screw holes.
    • Make sure the bottom edge of the cover latches properly to the frame.
  57. iPhone 16 Pro Max Battery Replacement: 57 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 57 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to install the three screws securing the Taptic Engine cover:
  58. iPhone 16 Pro Max Battery Replacement: 58 단계, 이미지 1개 중 1개
    • Use your finger or a spudger to press the assembly cable connector onto the logic board.
  59. iPhone 16 Pro Max Battery Replacement, Remove the leftover adhesive: 59 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the leftover adhesive: 59 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement, Remove the leftover adhesive: 59 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
  60. iPhone 16 Pro Max Battery Replacement, Clean the back glass: 60 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Clean the back glass: 60 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
  61. iPhone 16 Pro Max Battery Replacement, Clean the frame: 61 단계, 이미지 1개 중 1개
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
  62. iPhone 16 Pro Max Battery Replacement, Apply the replacement adhesive: 62 단계, 이미지 1개 중 1개
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
  63. iPhone 16 Pro Max Battery Replacement: 63 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 63 단계, 이미지 2개 중 2개
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
  64. iPhone 16 Pro Max Battery Replacement: 64 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 64 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 64 단계, 이미지 3개 중 3개
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
  65. iPhone 16 Pro Max Battery Replacement: 65 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 65 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 65 단계, 이미지 3개 중 3개
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
  66. iPhone 16 Pro Max Battery Replacement: 66 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 66 단계, 이미지 2개 중 2개
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
  67. iPhone 16 Pro Max Battery Replacement: 67 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 67 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 67 단계, 이미지 3개 중 3개
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
  68. iPhone 16 Pro Max Battery Replacement, Connect the back glass: 68 단계, 이미지 1개 중 1개
    • Prop up the back glass along the right edge of your iPhone.
  69. iPhone 16 Pro Max Battery Replacement: 69 단계, 이미지 1개 중 1개
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
  70. iPhone 16 Pro Max Battery Replacement, Connect the battery: 70 단계, 이미지 1개 중 1개
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
  71. iPhone 16 Pro Max Battery Replacement, Install the connector covers: 71 단계, 이미지 1개 중 1개
    • Align the back glass connector cover by its screw holes and lay it in place.
  72. iPhone 16 Pro Max Battery Replacement: 72 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
  73. iPhone 16 Pro Max Battery Replacement: 73 단계, 이미지 1개 중 1개
    • Align the battery connector cover by its screw holes and lay it in place.
  74. iPhone 16 Pro Max Battery Replacement: 74 단계, 이미지 1개 중 1개
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
  75. iPhone 16 Pro Max Battery Replacement, Remove the final adhesive liners: 75 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Remove the final adhesive liners: 75 단계, 이미지 2개 중 2개
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
  76. iPhone 16 Pro Max Battery Replacement: 76 단계, 이미지 3개 중 1개 iPhone 16 Pro Max Battery Replacement: 76 단계, 이미지 3개 중 2개 iPhone 16 Pro Max Battery Replacement: 76 단계, 이미지 3개 중 3개
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
  77. iPhone 16 Pro Max Battery Replacement, Apply heat to the perimeter: 77 단계, 이미지 1개 중 1개
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
  78. iPhone 16 Pro Max Battery Replacement, Apply pressure to the perimeter: 78 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Apply pressure to the perimeter: 78 단계, 이미지 2개 중 2개
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
  79. iPhone 16 Pro Max Battery Replacement: 79 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 79 단계, 이미지 2개 중 2개
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
  80. iPhone 16 Pro Max Battery Replacement: 80 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement: 80 단계, 이미지 2개 중 2개
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
  81. iPhone 16 Pro Max Battery Replacement, Install the pentalobe screws: 81 단계, 이미지 2개 중 1개 iPhone 16 Pro Max Battery Replacement, Install the pentalobe screws: 81 단계, 이미지 2개 중 2개
    • Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
결론
After your repair, run Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Calibrate your newly installed battery after completing this guide.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
310,081 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 160
지난 7일: 648
지난 30일: 1,907
전체 시간: 27,242
