주요 콘텐츠로 건너뛰기
iPhone 6 Plus Home Button Assembly Replacement
필요한 것
동영상 개요
  1. iPhone 6 Plus Home Button Assembly Replacement, Pentalobe Screws: 1 단계, 이미지 1/1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Plus Home Button Assembly Replacement, Anti-Clamp instructions: 2 단계, 이미지 1/3 iPhone 6 Plus Home Button Assembly Replacement, Anti-Clamp instructions: 2 단계, 이미지 2/3 iPhone 6 Plus Home Button Assembly Replacement, Anti-Clamp instructions: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Plus Home Button Assembly Replacement: 3 단계, 이미지 1/3 iPhone 6 Plus Home Button Assembly Replacement: 3 단계, 이미지 2/3 iPhone 6 Plus Home Button Assembly Replacement: 3 단계, 이미지 3/3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Plus Home Button Assembly Replacement, Front Panel Assembly: 4 단계, 이미지 1/1
    • Use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Plus Home Button Assembly Replacement: 5 단계, 이미지 1/1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Plus Home Button Assembly Replacement: 6 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 6 단계, 이미지 2/2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Plus Home Button Assembly Replacement: 7 단계, 이미지 1/3 iPhone 6 Plus Home Button Assembly Replacement: 7 단계, 이미지 2/3 iPhone 6 Plus Home Button Assembly Replacement: 7 단계, 이미지 3/3
    • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  8. iPhone 6 Plus Home Button Assembly Replacement: 8 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 8 단계, 이미지 2/2
    • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Plus Home Button Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.3 mm screw
    • One 3.1 mm screw
  10. iPhone 6 Plus Home Button Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Plus Home Button Assembly Replacement: 11 단계, 이미지 1/1
    • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Plus Home Button Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the following Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.5 mm screw
    • One 2.9 mm screw
    • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
  13. iPhone 6 Plus Home Button Assembly Replacement: 13 단계, 이미지 1/1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Plus Home Button Assembly Replacement: 14 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 14 단계, 이미지 2/2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
  15. iPhone 6 Plus Home Button Assembly Replacement: 15 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 15 단계, 이미지 2/2
    • Disconnect the home button cable connector.
  16. iPhone 6 Plus Home Button Assembly Replacement: 16 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 16 단계, 이미지 2/2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a plastic opening tool to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Plus Home Button Assembly Replacement: 17 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 17 단계, 이미지 2/2
    • Finally, disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Plus Home Button Assembly Replacement: 18 단계, 이미지 1/1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Plus Home Button Assembly Replacement, Home Button Assembly: 19 단계, 이미지 1/1
    • Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
  20. iPhone 6 Plus Home Button Assembly Replacement: 20 단계, 이미지 1/1
    • Remove the home button bracket from the front panel assembly.
  21. iPhone 6 Plus Home Button Assembly Replacement: 21 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 21 단계, 이미지 2/2
    • Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable.
  22. iPhone 6 Plus Home Button Assembly Replacement: 22 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iOpener
    $12.99
    구매
    • Carefully wedge the tip of a spudger underneath the home button connector cable.
    • Gently move the spudger across to separate the home button connector cable from the adhesive securing it to the front panel assembly.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  23. iPhone 6 Plus Home Button Assembly Replacement: 23 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 23 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iOpener
    $19.99
    구매
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  24. iPhone 6 Plus Home Button Assembly Replacement: 24 단계, 이미지 1/2 iPhone 6 Plus Home Button Assembly Replacement: 24 단계, 이미지 2/2
    • Carefully use the tip of a spudger to finish separating the home button from the front panel.
  25. iPhone 6 Plus Home Button Assembly Replacement: 25 단계, 이미지 1/1
    • Lift and remove the home button assembly off the front panel assembly.
결론
다른 122명이 해당 안내서를 완성하였습니다.
Walter Galan
694,877 평판
안내서 1,203개 작성하였습니다
댓글 23개
My iphone was screen broken and i change it with a original complete iphone screen, the home button works fine but the touch id dont work. I change the home button to the one that i have in the broken screen and still the touch id dont work. What can i do to fix the touch id?
Juanjo Checo - 답글
replace the flex cable which connects touch ID cable with mother board
engradnanriaz -
Hi guys, I replaced my front assembly and I'm having the opposite issue with my home button: The TouchID is working fine, but the home button being pressed is not working. I've tried re-seating the cable a few times. I'm normally pretty good at these kinds of things but I'm assuming I may have somehow crimped one of the ribbon cables.
My question: If something is damaged, is it more likely the cable on the back of the heat-sink that is damaged, or the home button ribbon cable itself? I realize that I will lose TouchID if its the latter, I just want to know what my options are. I'm having trouble searching the issue because everyone else has the issue where the TouchID doesn't work (for obvious reasons) but mine is working just fine.
Thanks for any advice.
Joshua Ryan - 답글
Hi everyone, I replaced the home button on my cell phone iphone 6+, the home button functionality works just fine, however the biometrics fingerprint reader does not work anymore. Any suggestions? Thank you
J Jesus Perez - 답글
Unfortunately, as stated in the introduction to this guide, that outcome is normal. For security reasons, the fingerprint sensor is coded to your phone's logic board at the factory. If you replace the button, you'll lose the fingerprint sensor function. Only Apple has the capability to pair new Touch ID sensors to existing phones. As far as I know, there are only two ways around this: (1) replace both your home button and logic board with a factory-paired home button and logic board harvested from another phone, or (2) pay Apple for an out-of-warranty repair (meaning you ship your phone to them and they give you a refurb in return).
Jeff Suovanen -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 47
30일 전: 191
전체 시간: 141,339
