주요 콘텐츠로 건너뛰기
iPhone 7 Plus Speaker Replacement
필요한 것
  1. iPhone 7 Plus Speaker Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Plus Speaker Replacement: 4 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 4 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Plus Speaker Replacement: 5 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Plus Speaker Replacement, Heat the display: 6 단계, 이미지 1개 중 1개
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Plus Speaker Replacement, Separate the display: 7 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement, Separate the display: 7 단계, 이미지 2개 중 2개
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Plus Speaker Replacement: 8 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 8 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Plus Speaker Replacement: 9 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 9 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Plus Speaker Replacement, Screen information: 10 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Plus Speaker Replacement: 11 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 11 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 11 단계, 이미지 3개 중 3개
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Plus Speaker Replacement: 12 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 12 단계, 이미지 2개 중 2개
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Plus Speaker Replacement: 13 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 13 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 13 단계, 이미지 3개 중 3개
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Plus Speaker Replacement: 14 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 14 단계, 이미지 2개 중 2개
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Plus Speaker Replacement: 15 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 15 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 15 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Plus Speaker Replacement, Battery Disconnection: 16 단계, 이미지 1개 중 1개
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  17. iPhone 7 Plus Speaker Replacement: 17 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the lower display cable bracket.
  18. iPhone 7 Plus Speaker Replacement: 18 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 18 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 18 단계, 이미지 3개 중 3개
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Plus Speaker Replacement, Display Assembly: 19 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement, Display Assembly: 19 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement, Display Assembly: 19 단계, 이미지 3개 중 3개
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Plus Speaker Replacement: 20 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 20 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 20 단계, 이미지 3개 중 3개
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  21. iPhone 7 Plus Speaker Replacement: 21 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 21 단계, 이미지 2개 중 2개
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Plus Speaker Replacement: 22 단계, 이미지 1개 중 1개
  23. iPhone 7 Plus Speaker Replacement, Speaker: 23 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement, Speaker: 23 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board.
    • There are two coaxial connectors in close proximity. Disconnect the one nearest the battery connector.
    • During reassembly, this can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
  24. iPhone 7 Plus Speaker Replacement: 24 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 24 단계, 이미지 2개 중 2개
    • Carefully de-route the coaxial cable you just disconnected from the small metal clip holding it to the logic board.
  25. iPhone 7 Plus Speaker Replacement: 25 단계, 이미지 2개 중 1개 iPhone 7 Plus Speaker Replacement: 25 단계, 이미지 2개 중 2개
    • Use tweezers or the point of your spudger to pry both coaxial cables out of the metal clip holding them on the side of the speaker.
  26. iPhone 7 Plus Speaker Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the five Phillips screws securing the speaker:
    • Three 1.3 mm screws
    • One 2.3 mm screw
    • One 3.3 mm screw
  27. iPhone 7 Plus Speaker Replacement: 27 단계, 이미지 1개 중 1개
  28. iPhone 7 Plus Speaker Replacement, Wi-Fi Diversity Antenna: 28 단계, 이미지 1개 중 1개
    • Warm the lower speaker area where the antenna is adhered with an iOpener, hair dryer, or heat gun, until it's slightly too hot to touch.
    • Heat helps soften the adhesive securing the antenna.
  29. iPhone 7 Plus Speaker Replacement: 29 단계, 이미지 3개 중 1개 iPhone 7 Plus Speaker Replacement: 29 단계, 이미지 3개 중 2개 iPhone 7 Plus Speaker Replacement: 29 단계, 이미지 3개 중 3개
    • Slide an opening pick between the antenna and the speaker on the right side, and carefully separate the adhesive underneath.
  30. iPhone 7 Plus Speaker Replacement: 30 단계, 이미지 1개 중 1개
    • Rotate the speaker and re-insert your opening pick on the opposite side.
    • Separate any remaining adhesive securing the antenna.
    • If necessary, re-heat the adhesive until it separates easily.
  31. iPhone 7 Plus Speaker Replacement: 31 단계, 이미지 1개 중 1개
    • Remove the Wi-Fi diversity antenna from the speaker.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
다른 57명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jeff Suovanen
회원 가입일: 08/06/13
447,029 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
6가이드 댓글
Thanks Jeff, this guide helped me complete the repair, even the fiddly bits with the diversity antennae. Oh the joy of hearing the “by the seaside “ ringtone from a previously mute iPhone. :D
Kola - 답글
Hi, I have completed this but the speaker option is still not available and am not able to record videos, and basically not able to hear anything when placing a call. should i replace the earpiece speaker as well?
bhargava perni - 답글
Thank you Jeff! I followed this guide and everything went smoothly. Used this to fix my friend’s iPhone when her phone went silent. She says everything is working as it should be. Thanks again from her and I.
Maganafixes - 답글
Hallo zusammen, ich habe den Umbau wie oben vorgenommen, jedoch kommt unten kein Ton wenn mich jemand anruft. Woran kann das liegen?
Kann es noch eine andere Ursache geben außer den Lautsprecher zu tauschen?
Freue mich über eine Rückmeldung.
iannarrig - 답글
People still can’t hear me when I call. However, if I switch to loudspeaker they can. Did I miss a connection or do I need another part?
mtderosier - 답글
댓글 쓰기
조회 통계:
지난 24시간: 16
지난 7일: 143
지난 30일: 777
전체 시간: 80,438
