주요 콘텐츠로 건너뛰기
이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
iPhone 8 LCD 및 디지타이저 교체
필요한 것
  1. iPhone 8 LCD 및 디지타이저 교체, Pentalobe/펜타로브/별 나사 분리: 1 단계, 이미지 1/1
    • 시작하기 전에 iPhone 배터리를 25% 이하로 방전하세요. 충전된 리튬-이온 배터리에 실수로 구멍이 생기면 화재를 일으키거나 폭발할 수 있습니다.
    • 분해를 시작하기 전에 iPhone 전원을 꺼주세요.
    • iPhone 하단 가장자리에 위치한 3.5mm pentalobe/펜타로브 나사 두 개를 빼주세요.
    • iPhone 디스플레이를 열게되면 방수 씰이 손상됩니다. 이 단계를 수행하기 전에 교체용 씰을 준비하거나 봉인 없이 iPhone을 재조립할 경우 액체에 노출되지 않도록 주의하세요.
    just how long are those screws- i turn and turn and turn and the lift off is soooo slight, seemingly insignificant…
    An. Jahnke - 답글
    I would recommend, from the very beginning, dumping all tools out of the kit (if you got it) and using that white paper tool box as a tray to organize the screws and braces in. It’s nice to work over because it catches screws well and makes it easy to see them if you drop any.
    Johnny Emrica - 답글
    That’s a great idea thank you
    Mohamed Dekkiche -
    Screw to the left of the charging port will not come out. Screw on the right came out no problem. Any ideas?
    Bill Maher - 답글
    I already replaced my iPhone 8 battery with one from iFixit and honestly I wasn't impressed. It worked well for a few months, but then I started noticing the peak performance capability dropping significantly thereafter. I followed the initial charging instructions to a tee and only let it drop below 20% once a month. Normal everyday use for me... no intense apps like games, etc. I considered having Apple do it this time around, but for these older models they don't keep the batteries in-stock and you have to give them your phone for up to a week. So in the end, I opted to try another battery from iFixit instead. Hopefully this one will last longer.
    tripmusic - 답글
    How with the gigantic kit do I not have a 3 1/2 pentalobe driver the very first screwdriver I reach for and that I need is not in any of these kits. What’s up with that?
    Michael Stephens - 답글
  2. iPhone 8 LCD 및 디지타이저 교체, 디스플레이에 테이프 붙이기: 2 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체, 디스플레이에 테이프 붙이기: 2 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체, 디스플레이에 테이프 붙이기: 2 단계, 이미지 3/3
    • 디스플레이 유리가 깨진 경우 깨진 유리에 테입을 붙여서 수리 도중 추가 파손을 막고 신체적 상해를 방지하세요.
    • 스크린 전체가 덮일 때까지 iPhone 디스플레이 위에 포장 테이프 스트립을 겹쳐 붙이세요.
    • 테이프를 붙이면 유리 파편이 흩어지지 않도록 하여 디스플레이를 들어 올릴 때 구조적 안전성을 유지합니다.
    • 수리 도중에 흔들려 떨어지는 유리 파편으로 부터 눈을 보호하기 위해 보호 안경을 착용하세요.
    • 유리 파편으로 인해 다음 몇 단계에서 흡입 컵이 붙지않는 경우 강한 테이프를 (예: 강력 접착테이프) 접어서 손잡이를 만들어 디스플레이를 들어 올리세요.
    In case of broken glass you can make the suction cup much more effective by covering the glass with a broad piece of translucent tape which eliminate air leakage through cracks in the glass.
    lionno1 - 답글
    Il n’est pas nécessaire de mettre beaucoup de scotch.
    Au contraire plus vous mettez de scotch, plus il y aura de défauts et la ventouse ne collera pas.
    Une bande bien positionnée suffit.
    Chloé Bossuette - 답글
    I’ve used hot glue on low setting to remove all types of crystals. The hot glue will release with a little iso alcohol. No damage to glass or plastic faced crystals or screens. Use a narrow piece of wood as a prying handle.
    Emilio Gonzalez - 답글
    I recently had issues with removing the glass with the suction cup. I have done this many times with older generation iPhones but this time the glass seemed sealed on quite solidly. I told myself that the last option would be to use the screwdriver tip. After all my attempts, I transitioned to the option of using the screwdriver tip. Surprisingly, it was the easiest thing ever. I placed the 1mm flathead screwdriver at the interface between the glass and the cover (normal start location) and pried up very gently. Voila, the glass came up and I can’t even notice any dents or scratches. It felt much easier than the suction cup technique. If the suction cup is giving you a hard time consider using that 1mm flathead.
    forhereyesonly - 답글
    This is definetly the best option to open this thing up. I’ve spend 30min with trying to heat it up and remove it using the suction cup. I needed 3sec with the 1mm flat screwdriver and i t was’nt scary at all. No dents nor scratches here too. Thanks for your comment.
    Berggorilla -
    thank you!!!!!
    Adrian Phan -
    Great suggestion to use the screwdriver!! Thanks, it really helped
    obo12759 - 답글
    Duck Tape worked great for me. Thanks for the great instruction!
    Michael - 답글
    Tried several types of tape but finally used this screw driver solution. At first I wasn't pushing hard enough for fear of damaging things but with just a bit of extra force I was able to open it right up. Everything is fine with only a slight scratch on the frame.
    Wesley Shank - 답글
  3. iPhone 8 LCD 및 디지타이저 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체, Anti-Clamp/안티-클램프 지침: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Clamp
    $24.95
    구매
    • 다음 두 단계는 여는 절차를 더 쉽게 하기 위해 고안된 도구 안티-클램프에 대한 설명입니다. 안티-클램프를 사용하지 않는다면 세 단계를 건너뛰고 다른 방법을 사용하세요.
    • 안티-클램프 사용법에 대한 전체 지침은 이 안내서를 확인하세요.
    • 파란색 손잡이를 뒤로 당겨 안티-클램프의 팔을 잠금 해제하세요.
    • 팔을 휴대폰의 왼편 또는 오른편 가장자리 위로 밀어 주세요.
    • 흡입 컵을 휴대폰의 하단 가장자리 홈 버튼 근처에 배치하세요—전면에 하나, 후면에 하나.
    • 적절한 위치에 컵을 함께 꽉 쥐고 흡착하세요.
    • 휴대폰 표면이 너무 미끄러워 안티-클램프가 잘 고정되지 않으면 테이프를 사용하여 표면에 더 잘 고정되게 할 수 있습니다.
  4. iPhone 8 LCD 및 디지타이저 교체: 4 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 4 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 4 단계, 이미지 3/3
    • 파란색 손잡이를 앞으로 당겨 팔을 고정하세요.
    • 손잡이를 시계 방향으로 360도 돌리거나 컵이 늘어나기 시작할 때까지 돌리세요.
    • 흡입 컵이 서로 정렬된 상태를 유지하는지 확인하세요. 정렬에서 벗어나기 시작하면 흡입 컵을 약간 풀고 팔을 다시 정렬하세요.
  5. iPhone 8 LCD 및 디지타이저 교체: 5 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 5 단계, 이미지 2/2
    • iOpener를 가열하여 안티-클램프의 팔에 끼워 넣습니다.
    • 헤어 드라이어, 열선총 또는 핫 플레이트를 사용할 수도 있지만—과도한 열은 디스플레이 및/또는 내부 배터리를 손상할 수 있으므로 신중히 진행하세요.
    • iPhone 하단 가장자리에 놓이도록 iOpener를 접으세요.
    • 접착제가 풀려서 틈이 생길 때까지 1분 정도 기다리세요.
    • 틈에 여는 픽을 끼우세요.
    • 안티-클램프가 충분한 틈을 만들지 못하면 열을 더 가하고 핸들을 1/4 바퀴 돌리세요.
    • 한 번에 1/4 바퀴 이상 돌리지 말고 매번 돌릴 때마다 1분 정도 기다리세요. 안티-클램프와 시간에 맡기세요.
    • 다음 세 단계는 건너뛰세요.
    it looks like a....
    Gergely Soki - 답글
  6. iPhone 8 LCD 및 디지타이저 교체, 디스플레이 가열하기: 6 단계, 이미지 1/1
    • 다음 세 단계는 흡입 컵을 사용하여 스크린을 분리하는 방법을 보여줍니다.
    • iPhone 하단 가장자리를 가열하면 디스플레이를 고정하고 있는 접착제가 부드러워져서 보다 쉽게 ​​열 수 있습니다.
    • 헤어 드라이어 또는 iOpener를 준비하여 iPhone 하단 가장자리를 약 90초 동안 가열하여 밑에 있는 접착제를 부드럽게 합니다.
    No hair dryer so GENTLY heated over stove burner
    John Toth - 답글
    Hello,
    What temperature is suitable for removing the front display ? I bought i-Fixit ProTech which is not include the heating "roller" . Thanks for help
    Jiří Sítko - 답글
    Ich habe eine heiße Wärmflasche verwendet. Das hat gut funktioniert :-)
    Moritz Hartges - 답글
    I laid my phone face-down on my 3D printer’s heated bed, and set the temperature to 60 C. After a few minutes, it was ready to loosen.
    Nate B - 답글
    If you don’t have an “iOpener” or heat gun, try using an electric heating pad. I have a small $11 pad I got at CVS for my knee. On medium heat it worked fine for removal and with the “pennies” for setting the new seal.
    Pete P - 답글
    I used a heated tea kettle and a tea towel, it worked!
    Adam Yavner - 답글
    I put on the furnace vent for 10 minutes to get it warm to the touch but not hot.
    terrelldoc - 답글
    I attached it to the after burner of my rocket ship and that worked.
    Matt Brown - 답글
    I'm holding mine just above an erupting volcano but I'm still waiting to see if it has worked. How long does it need?
    Paul Aron - 답글
    I used a water-filled ziploc bag, heated it in microwave. fast, cheap, worked.
    John Barker - 답글
    Hairdryer works fine for this step. No issues.
    tripmusic - 답글
    The most effective way to heat up the glue is to leave the phone in full sun - if it's available. In fact I would always wait for a sunny day to repair any glued together Apple device. The heat will be very even and the phone was probably designed to survive anything the sun can throw at it - although it can get very warm. (I'm in the UK) If you leave the phone turned on it will give a warning if it goes near the temperature limit.
    John - 답글
    I'm sorry but I tried both the hair dryer (for 3 minutes!) and the eye opener (also 3 minutes) and no luck. Not even a hint of loosening the adhesive holding down the display!! Do I send this kit back for a refund or what??!!
    John Noble - 답글
    No luck, guys. 3 minutes of hair drying and 3 minutes heating up the iopener. What next?
    John Noble - 답글
    Okay, a half hour later i finally got the screen loose, but not after super heating it for at leat 10 minutes with a hair drying and burning my hand trying to pry it open. Also, watch out for the power button because it inadvertently keeps switching the phone back on while you wrestle with it. More later . . .
    John Noble - 답글
    . . . and now I need to buy a new phone!!! the cable broke as I was trying to unscrew one of the top screws, so thanks! I FIXed IT but Good!!!!
    John Noble - 답글
    Nate B's advice was key. I couldn't get the temperature of the display hot enough to break the seal with a hair dryer. A heat gun set to low speed and 550F (287C) got the display up to just over 130F, close to the 60C Nate mentioned.
    Matt C - 답글
  7. iPhone 8 LCD 및 디지타이저 교체, 디스플레이 분리하기: 7 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, 디스플레이 분리하기: 7 단계, 이미지 2/2
    • 흡입 컵을 전면 패널 하단, 홈 버튼 바로 위에 눌러주세요.
    • 흡입 컵이 홈 버튼과 겹치지 않도록 하세요. 겹치는 경우 흡입 컵과 전면 유리 사이에 씰이 형성되지 않습니다.
    Even with using high heat from a blow dryer, I had to put the suction cup over the home button or the bottom edge wouldn’t lift at all. That waterproof adhesive is incredibly strong.
    Aaron Soderholm - 답글
    As others have said, this part really stinks, but it’ll work if you keep trying. Agree with multiple rounds of hair dryer on high (did about 60-90s each time), and with having to out the suction cup over the home button. You don’t need a big gap to pry it open - it’ll be slight …
    Johnny Emrica - 답글
    Patience is the key here. Expletives and patience. Like previous comments say, putting the suction cup over the home button (I used packing tape to maintain the seal) will allow you to apply force to the proper location to separate the screen. Good luck!
    J Rawlinson - 답글
    Get a suction cup pliers. It’ll make this part fun
    Bradley Steiner - 답글
    iSclack EVO opened the iPhone easily even without heating with no fear of accidentally over-opening it like with a simple suction cup.
    Matti Haveri - 답글
    If you don't have the anti-clamp device, to prevent the screen from tearing open when suctioning it, I suggest some layers of tape around it and the back of the phone (the tape has to be stretchy enough to just minimise the momentum when separating the screen), or some big rubberbands
    Raziocinjo - 답글
  8. iPhone 8 LCD 및 디지타이저 교체: 8 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 8 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 8 단계, 이미지 3/3
    • 흡입 컵을 확실하고 일정한 압력으로 위로 당겨 스크린과 프레임 사이에 약간의 틈을 만드세요.
    • 틈 사이로 여는 픽을 끼우세요.
    • 스크린을 제자리에 고정하는 방수 접착제는 매우 강력합니다; 이 초기 틈을 만들려면 상당한 힘이 들어갑니다. 틈을 여는데 어려움을 겪고 있다면 더 많은 열을 가하고 여는 도구를 넣을 수 있을 만큼 틈이 생길 때까지 스크린을 위아래로 부드럽게 들었다 놨다하여 접착제를 약하게 만들어주세요.
    The screen on my phone was so broken, a suction cup did not work, so I softened the adhesive with a blow dryer and used a Jimmy to carefully pry open the phone from the bottom just enough to slip a pick in.
    charguy - 답글
    Just completed a smashed screen replacement, this is probably the most time consuming part. Used packing tape to cover the screen to help create a suction surface (had to replace it a couple times because it pulls away after a purple good pulls ) Used consistent heat for about 5 minutes, then stuck a pick in the tiniest opening… and pry pry pry!
    Brian Gill - 답글
    I failed at this step. No amount of heating, pulling, and rocking opened up enough of a gap to slip in even a knife let alone the blue plastic tool. That's with a phone that has an undamaged screen - just trying to replace the battery. Apple won this round :(
    Michael Sherman - 답글
    Be really careful here. I placed a sucker to the front and rear to help lever off the screen. However, the whole thing came away much easier than I anticipated and I ripped the front part completely away from the rear, tearing all three connector cables. New iPhone required.
    Chris Wood - 답글
    Note that the opening pick they show here does not appear to come with the kit, which is a bummer! The plunger, the mini blue crowbar thing, these are too thick. I ended up using a really thin guitar pick.
    Johnny Emrica - 답글
    Following careful methods can mostly preserve the seal and reusable. Won’t be as water tight but probably still pretty good.
    Bottom edge is pull up with suction + separating tool. Use small precision scissor to cut any tape that gets overly stretched upon initial opening.
    - For the 2 long edges, use an exacto knife to separate the seal from the screen. This keeps the tape on the chassis. Go slow along the long sides. Becareful to avoid scratching the paint on underside of the screen’s edge.
    - Top corners have a thick sealed tape. Best to just use separating tool to twist it open.
    In summary, top and bottom edge use separating tool. Side long edges can use exacto knife to gradually gently separate the seal from underside of the screen’s edge.
    Howard - 답글
    4 picks and an exacto knife, plus 45 minutes later, I finally got it to open! Thanks tor the tip!
    Cat - 답글
    Intact screen, check. Tool kit, check. Hair dryer hot enough to make the phone too hot to touch, check. Following all instructions, check. Screen still in place and refusing to come off, check.
    I heated, reheated, pulled and pulled. I simply could not get it off. Worked at it for an hour and a half, and I’m not a small guy. Yes it is hard to hold, but could get a grip. Just could not get it to budge. Off to the iPhone repair shop tomorrow. Anybody want to buy a repair kit and replacement battery?
    Jim Meyers - 답글
    After struggling for 30m, I looked up some alternate methods and found this helpful:
    https://www.youtube.com/watch?v=25zAK5mG...
    - I used a utility knife and pried up right under the home button
    - the angle matters! I was trying to go too far down before going in. The top surface of the phone is rather thin, so you go in after barely getting under the chassis lip
    - tilt utility knife left to right once you’ve got it under to work it in
    - leave the utility knife in, and now add that pick
    Jared Wilk - 답글
    Pro-tip: don't be an idiot like me. Instead, remove the screen protector you have on the phone before applying the suction cups. Derp.
    hunter.geofizz - 답글
    I struggled with a hair dryer at first and a singular suction cup. However, I tried putting packing tape on the spot where I put the suction job (even though my screen isn't cracked) and I was able to do it first try with ease. Definitely recommend packing tape.
    Alessio Toniolo - 답글
    Suction cup pliers. Dead easy
    After successful screen replacement, returning to give my thanks here. Excellent tips from you all - if you’re using force, you’re doing it wrong. Heat, very very gentle exact-o knife barely down then fully under the screen below the home button … perfect. Slow and patient around the upper corners, and don’t forget to heat there as well! Thank you all!
    dantegd - 답글
    The problems with this step are (1) not having three hands and (2) managing to hold the phone in a way that doesn't put reverse pressure somewhere else on the screen. Exacto knife was the best tip. It's a little dangerous. On a misstep you may scratch the screen or jab yourself, but it's what got me in.
    thewrytstf - 답글
    sorry, could not lift off the display any nano-meter even after applying enough force I think and heating it up. need to visit a store.
    Andi Tony - 답글
    I used a razor blade and plenty of heat, and it somehow worked like a charm at the cost of me cutting myself. Definitely be careful when doing this, I used the razor blade on the left side of the iphone then wedged in a small screwdriver and then used the pick to cut the rest of the material away.
    Sharaf Kazi - 답글
  9. iPhone 8 LCD 및 디지타이저 교체: 9 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 9 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 9 단계, 이미지 3/3
    • 여는 픽을 휴대폰 왼편 하단 가장자리에서 가장자리를 따라 위로 밀어 음량 조절 버튼과 무음 스위치쪽으로 이동하여 디스플레이를 제자리에 고정하는 접착제를 갈라주세요.
    • 디스플레이 왼편 상단 가까이에서 멈추세요.
    • 디스플레이의 상단 가장자리를 후면 케이스에서 들어 올리지 마세요, 디스플레이를 고정하고 있는 플라스틱 클립이 파손될 수 있습니다.
    My Plektrum worked ok, but the edges broke off a bit towards the end
    griffin.weber - 답글
  10. iPhone 8 LCD 및 디지타이저 교체, 스크린 정보: 10 단계, 이미지 1/1
    • iPhone왼편 가장자리를 따라서 민감한 케이블이 지나갑니다. 케이블을 손상할 수 있으므로 여기에 픽을 끼우지 마세요.
    I was trying to replace my battery, and accidentally cut one of the cords on my screen. I marked my pick, so i don't know how it happened.
    Gib Jeffries - 답글
  11. iPhone 8 LCD 및 디지타이저 교체: 11 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 11 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 11 단계, 이미지 3/3
    • iPhone의 하단 오른편 가장자리에 픽을 다시 넣고 가장자리를 따라 오른편 위로 밀어서 접착제를 분리하세요.
    • 디스플레이 케이블을 손상할 수 있으므로 픽을 3mm 이상 끼우지 마세요.
    No pick in the kit you sent me.
    Ted Cooper - 답글
  12. iPhone 8 LCD 및 디지타이저 교체: 12 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 12 단계, 이미지 2/2
    • 흡입 컵을 조심히 위로 당겨 디스플레이 아래쪽 가장자리를 들어 올리세요.
    • 디스플레이를 15º 이상 올리지 마세요. 디스플레이를 연결하는 리본 케이블에 압력이 가거나 찢어질 수 있습니다.
    • 흡입 컵의 작은 손잡이를 당겨 전면 패널에서 분리하세요.
  13. iPhone 8 LCD 및 디지타이저 교체: 13 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 13 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 13 단계, 이미지 3/3
    • 디스플레이 아래, 휴대폰 상단 가장자리를 따라 여는 픽을 밀어서 마지막 남은 접착제를 떼세요.
    I did end up using just a smidge of IFIXIT adhesive remover along the edge before opening and that seemed to really help
    Karen Flowers - 답글
    I have been using the pointed tweezers to pull the adhesive strands apart and out as the display comes off.
    Adam Yavner - 답글
    This bit was awkward as to get a good grip I kept inadvertently switching the %#*@ phone on!
    wendyhoward - 답글
  14. iPhone 8 LCD 및 디지타이저 교체: 14 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 14 단계, 이미지 2/2
    • 디스플레이 어셈블리를 약간 아래로 밀어서 (휴대폰 상단 가장자리에서 멀리) 후면 케이스에 고정하는 클립을 풀어주세요.
  15. iPhone 8 LCD 및 디지타이저 교체: 15 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 15 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 15 단계, 이미지 3/3
    • 책의 뒷 표지를 열듯이 디스플레이 왼편을 위로 펼쳐서 iPhone을 열어주세요.
    • 아직 디스플레이를 완전히 분리하지 마세요. 여전히 약한 리본 케이블 여럿이 iPhone 로직 보드에 연결되어 있습니다.
    • 휴대폰에 작업하는 동안 디스플레이를 다른 물건에 기대어 세워 놓으세요.
    Nach RECHTS klappen - nicht nach links!
    Manfred Wachtel - 답글
    Als ich das Flachbandkabel auf der rechten Seite sah, hab ich mich auch gefragt, ob die das mit nach Links klappen ernst meinen, und das „Buch“ lieber auf japanische Art nach rechts aufgeklappt. Das sollte dringend in der Anleitung korrigiert werden!
    Sebastian Plickert - 답글
    “Up from the left” means lift up the left side.
    Which is the same as folding to the right.
    “Like the back cover of a book” explains it even more clearly.
    Maybe it gets lost in translation?
    Nick Shtangey -
    Fold to THE RIGHT - not to the left!
    Jim Glenys - 답글
    When I saw the ribbon cable on the right side, I also wondered if they were serious about folding it to the left, and the "book" would rather be opened to the right in the Japanese way.This should be corrected urgently in the manual!
    Jim Glenys - 답글
    Hi Jim, the display opens from the left side, toward the right side. It should look like the back cover of a book. Hope this helps. Good luck with the repair!
    Adam O'Camb -
    DO NOT LAY THE TWO HALVES FLAT!!! There is a reason why the third photo shows the screen half leaning against a box! This really needs to be a warning in addition to the one about not separating the display.
    Mangled Jargon - 답글
    If you're skipping the screen and taptic engine removal like I did, I suggest you tape the back of the phone to the table, and also tape the screen to the vertical object it lays on, so it stays still. That way you will avoid having to constantly readjust it because of the sliding of the housing of the phone when you're working on it. Be careful where you're putting the tape on the screen though, if you're doing it on the internal components.
    Raziocinjo - 답글
  16. iPhone 8 LCD 및 디지타이저 교체, 배터리 분리: 16 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, 배터리 분리: 16 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • 하단 디스플레이 케이블 브래킷을 로직 보드에 고정하는 다음 길이의 Phillips/십자 나사 네 개를 분리하세요:
    • 1.3mm 나사 두 개
    • 2.8mm 나사 두 개
    • 이 안내서를 사용하는 동안 빼놓은 각각의 나사를 기억하여 재조립할 때 원래 자리로 정확히 돌려놓으세요. 잘못된 위치에 나사를 설치하면 영구적 손상을 입힐 수 있습니다.
    • 브래킷을 제거하세요.
    Not Y000 this time haha
    Easy Repair - 답글
    can same length screws mixed up?
    Brook布魯克 - 답글
    It is not ideal, but possible for these screws.
    Arthur Shi -
    using the repair kit i purchased with my screen replacement, i am currently having issues removing these screws with the PH000. please help
    Mark Ordaz - 답글
    I was too, thankfully I had another set that contained the PH00 bit, that worked great for me.
    William Mitchell -
    Ok. My screw is stuck. How do I remove it? Philips head is stripped.
    Kristina Graham - 답글
    Solved it myself. Firm pressure did the trick.
    Kristina Graham -
    Takes a little pressure with the Philips head
    John Toth - 답글
    Upon this step, I noticed I had no bracket or screws. I had my screen replaced previously and I’m disappointed to find out the repairperson made no effort to replace these parts. I’ll start trusting myself more to do my own repairs.
    O D - 답글
    took me awhile to figure out I needed to use PHOO bit for the 2 -1.3 screws
    Karen Flowers - 답글
    It is important to keep careful track of the screws' position. Have a tidy workplace -- a few times when I tried to re-attach the very tiny screws with the tweezer, they slipped and flew away and I almost lost them.
    Matti Haveri - 답글
    can you strip the screws / how can you tell if its strip or not
    antonio - 답글
  17. iPhone 8 LCD 및 디지타이저 교체: 17 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 17 단계, 이미지 2/2
    • Spudger/스퍼저 끝을 사용하여 배터리 커넥터를 로직 보드의 커넥터 소켓에서 들어올리세요.
    • 수리 중에 실수로 소켓에 닿아 휴대폰에 전원이 공급되지 않도록 배터리 커넥터 케이블을 위로 약간 구부려 주세요.
    Make sure you pry the battery connector off from the right hand side as shown in the picture. Theres a delicate component on the logicboard near the battery connector called a Mosfet which is linked to the battery charging software. If you knock it off accidently you’ll loose battery charging and the phone will boot loop and youll need to have it re-soldered back on.
    Gareth - 답글
    I can confirm this as I learned my lesson by unknowingly prying the mosfet off. The phone will not charge now and is useless. I really wish they would add a note about this on Step 12 as a warning.
    Jeff -
    So this is it. You don’t have to go any further removing the screen. You can replace the battery right from this point.
    John M - 답글
    I wish I saw this comment 2 hours ago
    Kenneth Moore -
    If I have to repeat this, I'd also consider removing replacing the battery at this point. The loose display must be then carefully fixed so the connectors don't break. And then it is not possible to re-attach the waterproof seal.
    The waterproof seal was included in the kit, but there were no instructions for it so I now skipped that. I later found YouTube video which seems to describe it (starting at 7:40):
    https://www.youtube.com/watch?v=RcgGRhaX...
    Matti Haveri -
    This is where I broke my phone, a phone that was working quite well, paid for in full. Just because I had a cracked screen. Be super careful when connecting the cables. I was in a hurry and not paying attention, used too much force when re-connecting and broke those teeny little pins that could not be repaired. A tech tried for an hour to no avail. cautionary tale. Good luck
    Karen Flowers - 답글
    The display ribbon is a certain length and allows for some give, but behind it is hidden the Home button/TouchID ribbon, which sits against what amounts to a razor blade. This ribbon is much more taut than the display one, and therefore you have far less freedom of movement than you think you do. This is absolutely an intentional trap to discourage replacing your own battery. Quite frankly, it’s despicable.
    Anyway, so beware of that, because although I was very careful and did not even swing the screen very far (not more than 90°), the Home button ribbon tore and now needs to be serviced. Home button is disabled now.
    Apple should be ashamed of themselves for this. Please do look at the legislation effort that people are doing to try to get this kind of sabotage illegal, as well as all sorts of other gimmicks they pull. For a company that makes phenomenal products, they’re controlling like an abusive spouse.
    Dan Knight
    daniel - 답글
    That happened to me and I could not figure out how it got broken. It's the home button and fingerprint reader.
    But I'm not bothering to get it fixed and I'm not replacing the entire screen. I went into system prefs/accessibility and activated the on-screen home button. Oh, well.
    Mangled Jargon -
    I cannot get the new battery reconnected to the connection port. Any tips/tricks? New and old battery connections appear similar. It wasn't difficult to disconnect to old battery.
    Robert Ast - 답글
    Some reports here seem to indicate that the battery must be the very last connector to re-connect because otherwise there might be malfunction in some display components?
    It wasn't difficult to disconnect to old battery. But the most difficult part for me was to get the new battery reconnected to the connection port. I tried many times to carefully position and press it down with my fingertip or the flat end of the spudger but it did not hold its position. Maybe I pressed too weak because I was afraid breaking the connector and the mosfet above (?) it. But finally to my surprise it connected (at that point I temporarily booted the iPhone with the loose display to verify that the battery was connected). Whew, it succeeded!
    Matti Haveri - 답글
    The connectors have very little "click" to them when they do seat properly, and are covered with soft foam. Very challenging to attach them by feel, and having the screen propped up, blocks light from exactly where you need it.
    Steve Trotman - 답글
    Make sure the new battery connector cable has similar length and width to the one of the original battery. I got a third party battery and the cable was longer and not folded in a "U" way near the connector, like the one in the genuine battery was, only folded at a 90 degree angle. That "U" actually perfectly fits in the small space between battery and connector port, so the cable doesn't stick up thus making connecting it or closing the screen impossible. So fold the cable, connect it, and while holding it to prevent it from disconnecting, stick the battery so the "U" curve of the cable sits down just between battery and connector port.
    Raziocinjo - 답글
  18. iPhone 8 LCD 및 디지타이저 교체, 디스플레이 및 디지타이저 분리: 18 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, 디스플레이 및 디지타이저 분리: 18 단계, 이미지 2/2
    • Spudger/스퍼저 끝을 사용하여 하단 디스플레이 커넥터를 소켓에서 들어올리세요.
    • 이와 같은 프레스 커넥터를 다시 붙이려면 한쪽을 제대로 들어맞을 때까지 아래로 누른 다음 다른 쪽도 반복하세요. 가운데 부분은 누르지 마세요. 커넥터가 조금이라도 잘못 정렬되어 있을 경우 커넥터가 구부러져 영구적인 손상을 입을 수 있습니다.
    I broke the lower display connector. Is it possible to replace that part separately or do I need to buy a full screen replacement?
    Ross Mckellar - 답글
    You need to buy a new screen
    conrad veldhouse -
    이렇게 친절하게 정성스럽게 분해도 올리신 분은 처음이네요 진정 프로/ 기타 나머지 잡것들은 대충 올려 돈이나 벌어보자는 업자num들/ 배터리 교체하는 유툽 영상보다...업자가 올린 ...배터리 교체는 따라했으나 그후 배터리 교체와는 전혀 상관 없는 액정 뒤판을 jo빤다고 설명도 없이 뜯어 그것까지 따라하다 액정이 나가버려 지금 무주공산에서 홀로 검색하다 이걸 보게됨
    평생놀아난다 - 답글
  19. iPhone 8 LCD 및 디지타이저 교체: 19 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 19 단계, 이미지 2/2
    • Spudger/스퍼저 끝을 사용하여 두 번째 하단 디스플레이 케이블을 분리하세요.
  20. iPhone 8 LCD 및 디지타이저 교체: 20 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 20 단계, 이미지 2/2
    • 전면 패널 센서 어셈블리 커넥터 위로 브래킷을 고정하는 1.3mm Phillips/십자 나사 세 개를 풀어주세요:
    • 브래킷을 분리하세요.
    If you are replacing the adhesive liner, the remaining release liner strips will interfere with the two outer screws. I had to cut a working section out of the liner at each location and move it aside with the spudger.
    Thomas Tritt - 답글
    This part is throwing me for a loop. Having difficulty finding the read head for these screws. Is it the same size as the two small 1.3mm screws in step 12?
    Jared Hensley - 답글
    These are the same size screws mentioned in Step 17.
    Douglas Walker -
    ended up getting it with the PH000, I must of just been rushing it.
    Jared Hensley - 답글
    My bracket looks different and none of the screw heads I have fits.
    Ray Rushing - 답글
    Mine too? Any help?
    George Waller -
    These screws did not stick to the magnetic screwdriver. Extremely difficult to get them back in place - but with some patience i succeeded :)
    Niklas Brammer - 답글
  21. iPhone 8 LCD 및 디지타이저 교체: 21 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 21 단계, 이미지 2/2
    • Spudger/스퍼저 끝을 사용하여 전면 패널 센서 어셈블리 커넥터를 분리하세요.
    Do you have a link for the flex cord shown in the pictures so I can purchase it? Having a hard time locating that exact assembly
    Regal Carveiro - 답글
    It’s of a piece with the front camera.
    xint - 답글
  22. iPhone 8 LCD 및 디지타이저 교체, 디스플레이 어셈블리 분리: 22 단계, 이미지 1/1
    Hi ifixit, if you find my method dangerous, please remove it.
    After Step 17, I skipped Step 18 to Step 28.
    At Step 29, I lifted up the four adhesive black pull-tabs to expose the white adhesive side. Next, I use hot air gun and blow on the back cover of the iphone for about a minute (maybe a hairdryer will work too) .
    Warning: Don't overheat the iPhone, or you may accidentally ignite the battery.
    I think the temperature was around 60 DegC.
    Extreme Caution: Do Not overheat. I use my hand to gauge the hotness. Careful not to burn yourself or the board.
    I was able to pull out all the white adhesive tapes easily as the adhesive soften.
    DO NOT TRY this method if you are a novice or inexperience! I am not responsible if you hurt yourself or damage your iphone!
    John - 답글
    Hey John! I’m glad the repair worked out for you!
    From our research, applying heat does soften the adhesive strips, but it also causes them to lose structural integrity and break more easily. That’s why we normally suggest using heat after the strips are already broken. Removing the Taptic Engine definitely takes a few extra steps, but we feel that it gives fixers the best chance of pulling out the adhesive strips intact.
    Arthur Shi -
    I agree with John, skip 18 through 27. These are to make it easier to remove the battery adhesive. I replaced the batteries on two IPhone 8s. The first one I did all that stuff and the adhesive still broken and I had to carefully pry the battery out anyway. When I reassembled the phone the Home button no longer worked. Looking it up, this is apparently fairly common due to all the fragile wires involved in these steps. The second I skipped these steps and when I reassembled it everything worked fine. Not one of the eight (both phones) adhesive strips came out properly. I fully drained the batteries before doing the repairs. By the way, I use the virtual home button on the one phone, it’s a little annoying, but the phone is still usable if you’re not ready to shell out for a new phone.
    Gary Berman -
    I also skipped removing the Taptic Engine. I could only half-way pull the lower battery tapes and completely the upper tapes after carefully prying them loose with the tweezer. I then used a hair-dryer for a minute to warm the battery and the other side of the phone (I used my other hand to make sure I did not apply too much heat. Make sure you do not blow the tiny loose screws away with the hair dryer!) and then slowly lifted the upper battery somewhat with the Opening pics tool, then re-heated the lower remaining tapes and quite easily lifted the battery out.
    I had bought two-sided tape to reconnect the battery but it had the tapes pre-installed (I wonder if it is necessary to tape the battery at all?).
    Matti Haveri -
    I also skipped these steps. I won’t say it was entirely successful - two of the four adhesive strips broke and could not be grabbed with tweezers. But I had gotten most of the adhesive out already and the battery was quite loose, so I used a warmer under the phone, then gently slid a flat plastic blade under one end of the battery and slowly worked it up the phone. (Dental floss would have been safer-don’t do what I did, kids!)
    Matt D - 답글
    Likely can skip step 18-28 and all the risks. Battery tape is relatively removable by the following method
    - use a tweezer to pull up a corner of each tape. Then use fingers to peel back all the black tab on top of battery
    - use 2 hands. Index and thumb on both. Pull about 1/4” with one hand, hold the tension and pull 1/4” with the other hand. Alternate, go slow. Pull out all 4 tape completely. I think the pause after each 1/4” while holding the stretched tape firmly prevents the tape from over stretching to become too thin and break.
    - Don’t apply heat, I would guess that makes tape softer and break easier.
    Have tried other methods and failed in the past. Pulling too fast (tape will snap) or use a tweezer to twist/roll (sharp edges will cut tape) Anyway, just use index/thumb on both hands and alternately pull slowly
    I did do 2 iPhone 8 battery change this way. One removed all tape without breaking. Another broken all 4 tape after about 1/3 pulled so likely some factory assembly differeces.
    Howard - 답글
    I second this, this method works well in most cases. Removing the haptics helps to keep the angle low and pulling the tape as straight as possible
    Hein Blöd -
    Howards method for removing the adhesive works like a charm. The only addition I made was to slightly warm the back of the iphone on a rice pack (used for sore neck muscles—haha). Going back and forth between hands is really crucial. While on hand gives a gentle pull, the other holds the phone from moving. Slow back and forth. Thanks.
    Lynn Thomas - 답글
    Struggling with the glued down display, then properly cleaning all the remains of the old seal, then positioning the new seal is 95% of this job. I purchased my phone refurbished and it clearly had already been serviced once, there were remnants of an old seal below the current seal due to improper cleaning and prep that made getting the phone open harder than it needed to be.
    Steve Trotman - 답글
    For my 2nd iPhone 8 battery replacement, I chose not to remove the display completely, or the Taptic Engine and I was successful. You have to pay extra attention and it is a bit trickier to keep the display from moving around too much, but I think minimizing the amount of screws and connections to take out, the better. You can easily lose the screws and you have to mind which ones go where, as there are so many different lengths. YMMV.
    tripmusic - 답글
    In retrospect, I also would have skipped ahead to step 33. I didn't, but my efforts at removing the adhesive tape were also unsuccessful so steps 23-33 were for naught. Ended up applying isopropyl alcohol, then warming the back, and finally just physically levered the battery out. Battery was slightly deformed and became slightly warm, so as soon as I got it out I just put it outside on a brick.
    But the replacement worked.
    Peter Benson - 답글
  23. iPhone 8 LCD 및 디지타이저 교체, 홈/Touch ID 센서 브래킷 분리: 23 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, 홈/Touch ID 센서 브래킷 분리: 23 단계, 이미지 2/2
    • 홈/Touch ID 센서 위로 브래킷을 고정하는 Y000 나사 네 개를 풀어주세요:
    • 1.2mm 나사 한 개
    • 1.3mm 나사 세 개
    • 브래킷을 분리하세요.
    • 재조립 도중 나사를 너무 세게 조이지 마세요 홈 버튼이 작동하지 않을 수 있습니다.
    Bei meinem iPhone waren das Y00 Schrauben, nicht Y000
    Andreas Veeser - 답글
    If the screw on the home button is broken, you can bend the metal sides upwards and pull down out of the phone and push and refold into the new display. Example: https://www.youtube.com/watch?v=DTCQA-jn...
    Andy Knapp - 답글
    Andy Knapp - wherever you are - you saved me. NOTE: the iphone 8 has four tri-wing screws - that means you need a tri-wing screwdriver. I ordered an entire replacement set and mine had one in there, but it does not mention anything about tri-wing in these instructions… so. Hope that helps someone.
    Paula Lofland -
    On my iPhone, these were Y00 screws, not Y000
    Jim Glenys - 답글
    Dutch version speaks of one 1,3 mm screw, but has 3 of those screws.
    Fonne Van Gils - 답글
    There is a difference between Y00 and Y000. I realized this after unknowingly trying the Y000 and damaging the tip of the screwdriver, as the metal is apparently softer than the screw. I was able to use the corner of a flat metal file to make the cheap Y0000 work (which came with the replacement kit) by making 3 adjustments: 10 filing down the tip, 2) filing the shoulders to make the tips more pointed, and 3) cleaning out the 3 channels to remove burrs from the tip edges.
    Robert Lanzafame - 답글
  24. iPhone 8 LCD 및 디지타이저 교체, Touch ID 센서 분리: 24 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체, Touch ID 센서 분리: 24 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체, Touch ID 센서 분리: 24 단계, 이미지 3/3
    • 여는 도구를 사용하여 홈 버튼 케이블 커넥터 왼쪽 가장자리 밑을 들어 올려 소켓으로 부터 분리하세요.
    • 커넥터 전체가 분리되지 않고 뒤집히기 시작하면, 커넥터 왼쪽 가장자리를 들어 올리면서 동시에 spudger/스퍼저의 평평한 끝 부분으로 커넥터 상단 가장자리의 케이블을 누르세요. 케이블 또는 커넥터가 손상되지 않도록 매우 조심하세요. 센서가 영구적으로 비활성화 될 수 있습니다.
    To have a better view on this connection I have removed the metal plate covering the back of the glass. Its a thin piece of metal held by 9 screws. To unscrew the 8 screws you need the screwdriver head with 3 sides like the Mercedes Benz symbole. The last is with a phillips near the camera.
    forhereyesonly - 답글
    I thought I was going to tear the cable doing it the way it’s suggested in the guide. After examining the cable on the replacement screen, I found it easier to hold the bottom connector pressed against the screen with one leg of needle nose tweezers whilst gently prying off the top connector with an opening tool.
    Cool_Breeze - 답글
    See step 22 to get a clearer picture of what the connector looks like when it is separated from its socket. Your replacement screen will have a new socket (i.e., the bottom piece of the connector). My replacement screen had a new socket attached to the unit by a thin piece of plastic. For reassembly, when working the Home Button/Touch ID assembly back into the new screen, I had to work the connector cable under the socket in order to get the connector re-attached.
    Be extra careful with this step: it wasn’t clear to me from the description that the connector wrapped from underneath to connect, nor did my set come with picks. I used a blade from the wrong side, inadvertently (but way too easily) severing the connector and destroying the function of the home button and thus the entire phone.
    Jennifer Indeliclae - 답글
    Be careful, I initially didn’t found the connector and nearly ripped the cable. The connector leads to a cable that goes under the metal plate. Found a YouTube video with very good close ups for this part (go cell phone repair detailed version)
    Svenja Büsing - 답글
    I initially didn’t found the connector and cable and nearly broke it. The connector leads to a cable that goes under the metal plate, I needed YouTube video with good close ups to understand the setup.
    Svenja Büsing - 답글
  25. iPhone 8 LCD 및 디지타이저 교체, Touch ID 센서 분리: 25 단계, 이미지 1/1
    • 홈/Touch ID 센서 주변을 가열하면 정교한 케이블을 제자리에 고정하는 접착제를 부드럽게 만들어 안전하게 분리할 수 있습니다.
    • 디스플레이 어셈블리를 뒤집으세요. 헤어 드라이어를 사용하거나 iOpener를 준비하여 디스플레이 하단 가장자리를 약 90초 동안 가열하여 디스플레이 밑의 접착제를 부드럽게 만드세요.
    • 디스플레이를 과열하지 마세요. 편안하게 만질 수 없을 정도로 약간 뜨거워야 합니다.
    The stove top works well also. Remember, as the main instructions say, it should be slightly too hot to touch comfortably.
    forhereyesonly - 답글
  26. iPhone 8 LCD 및 디지타이저 교체: 26 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 26 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 26 단계, 이미지 3/3
    • 여는 픽을 사용하여 홈/Touch ID 센서 케이블을 디스플레이 패널 후면에 고정하는 접착제를 조심히 분리하세요.
    My original assembly broke trying to follow this step carefully. :(
    Ann - 답글
    This one’s kind of hard to reconnect. Just remember to be gentle, take your time, and use your hands so that you can really feel it out.
    Johnny Emrica - 답글
    Keep in mind, there’s a tiny rubber ring gasket between the Touch ID button and the display. In my experience when removing the button, the gasket stuck partly to the the button and partly to the display. I gently removed the part that was sticking to the display and guided it back on the button. If you’re missing that gasket it won’t be waterproof.
    Sam Tropper - 답글
    I used a heat gun set at 300*F to heat up the glass side for about 20 seconds and on connector side for about 10 seconds (touchscreen was a little too hot to the touch). Pulled connector with fingers and pried off with plastic tool.
    anonymous 6745 - 답글
  27. iPhone 8 LCD 및 디지타이저 교체: 27 단계, 이미지 1/1
    • 디스플레이 전면을 통해서 홈/Touch ID 센서 어셈블리를 들어 올려 분리하세요.
    • 재설치하려면 먼저 사진 처럼 디스플레이 전면 구멍을 통해 케이블을 넣으세요.
    • 교체 부품 홈 버튼 근처에 여분의 Y000 나사가 이미 설치되어 있을 수 있습니다. 홈 버튼 브래킷을 다시 설치할 수 있도록 불필요한 나사를 풀어주세요.
    Instructions were great. Putting the connections back is a bit of a hassle, but patience is your friend. Phone is up and running. Thanks iFixit.
    pwpfef01 - 답글
    Couldn’t get the Home Button (original one I was transferring) to work. I know the instructions said something about not tightening down the 4 screws around the Home Button too much, but how much is too much. Also, a day later, the screen I bought starting having green vertical lines. Took everything back apart and started from scratch the next day and still had the same 2 problems. Just for the heck of it, I put the old cracked screen back on the phone and everything started working again. Figured I wasted about 6-8 hours total on this rather small project and I’m right back where I started again. Something definitely wrong with the screen I ordered and I’m very disappointed. I’ve bought products from ifixit before and they worked, but no such luck this time. Anyone know how I get my 70 bucks back?
    Todd Skobjak - 답글
    Hi Todd!
    I’m sorry to hear about your experience! Please contact our customer support and we will get the issue resolved!
    Arthur Shi -
    They charged you $70 bucks for a new replacement screen for an iphone8 and it didn't even work right that's crazy they are over charging people considering my wife only payed $23 for a new replacement screen kit that comes with the new screen and everything else you need to change it out plus a extra screen protector and I just finished replacing the screen and so far so good no green vertical lines running down my screen. I like ifixit because they show me how to fix what I need to fix but I don't think I will be buying anything from them anytime soon.
    Lincoln -
    I greatly support Ifixit… but.. for me the same story as Todd Skobjak. Put in the new screen. Touch button is not found. Retried with screws loosened and refitting the plug. Nothing. Put the old screen back and the touch button worked again. So.. something with the new provided screen from Ifixed must be the case. I'll also get in touch with customer support.
    Ifixed: not only check the screen but also the cable to the touch button!
    Ton Vaes - 답글
    What’s the trick here?
    Getting an “unable to activate Touch ID” after replacing the home button and a new screen - somewhat similar to that above. Any troubleshooting steps/resolution? I loosened, tightened screws holding the assembly, no effect.
    schaferjon - 답글
    The button is paired with the motherboard. if you change the screen, always attempt to retrieve the original button.. otherwise touchid will not be available
    Bill McNamara -
    The instructions for this home/touch button repair were spot on! The special tip in red for Step 19 was extremely useful because that was exactly what I encountered while attempting to remove the original home/touch button from the original front screen. Step 21 and accompanying photos were a life saver as well, but this process did require heating the screen with my wife’s hair dryer several times to be able to gently pry up the adhesive for the home/touch button ribbon without ripping it to pieces. And yes my phone worked great after completing this repair. Time spent meant money saved and a personal satisfaction and pride in a job well done. Thank you Team iFixit!
    Jeffery Anderson - 답글
    the steps to move the front camera and speaker to the new screen are missing, right?
    martijn.klabbers - 답글
    do you really neec to replace the home button?
    ineedtoreplacemyphonescreen - 답글
  28. iPhone 8 LCD 및 디지타이저 교체, 이어피스 브래킷 분리: 28 단계, 이미지 1/1
    • 이어피스 스피커 브래킷을 전면 패널에 고정하는 Phillips/십자 나사 세 개를 풀어주세요:
    • 2.6mm 나사 두 개
    • 1.8mm 나사 한 개
    I updated the step to clarify that!
    Arthur Shi -
  29. iPhone 8 LCD 및 디지타이저 교체: 29 단계, 이미지 1/1
    • 이어피스 스피커 브래킷을 분리하세요.
  30. iPhone 8 LCD 및 디지타이저 교체, 전면 카메라 옮기기: 30 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, 전면 카메라 옮기기: 30 단계, 이미지 2/2
    • 전면 카메라를 소켓에서 들어올리고 빙 돌려 젖히세요.
  31. iPhone 8 LCD 및 디지타이저 교체, 이어피스 스피커 분리: 31 단계, 이미지 1/1
    • 이어피스 스피커를 전면 패널에 고정하는 Phillips/십자 나사 두 개를 풀어주세요:
    • 1.8mm 나사 한 개
    • 2.3mm 나사 한 개
  32. iPhone 8 LCD 및 디지타이저 교체: 32 단계, 이미지 1/1
    • 이어피스 스피커를 분리하세요.
    The metal faceplate that you can see in the image on my speaker has been scratched an scored from a previous repair by someone else. Could this affect the speaker in any way?
    Kyle Webb - 답글
    Hi Kyle,
    The metal shield should have no effect on the speaker. Granted, it may hint that damage was done around the area, which may have damaged the speaker module.
    Arthur Shi -
    Hi , I have Changed with success the camera piece but after reassembling, the speaker does Not work.A weird fact ist that Wireless Headphones will now reproduce músic but Not Phone Sounds(voices)! Have you Got any idea about this ? I am quite Sure I didn t damage the speaker but before changing It(as a posible Next step)I world like to ask you for any comment ! Thanks
    enbernat - 답글
  33. iPhone 8 LCD 및 디지타이저 교체, 전면 카메라 및 센서 케이블 분리: 33 단계, 이미지 1/1
    • iOpener를 가열하여 디스플레이 상단 가장자리에 적용하여 전면 카메라 및 센서 어셈블리를 제자리에 고정하는 접착제를 부드럽게 하세요.
    • 다음 단계로 넘어가기 전에 접착제를 적당히 부드럽게 하기 위해 약 2분 동안 기다리세요.
  34. iPhone 8 LCD 및 디지타이저 교체: 34 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 34 단계, 이미지 2/2
    • Spudger/스퍼저의 뾰족한 끝을 사용하여 근접 센서를 전면 패널 홈에서 들어 올리세요.
    • 투명한 플라스틱 아랫면에서 들어올릴 수 있도록 도구를 센서 밑 깊숙히 넣으세요. 케이블만 들어올리면 센서가 케이블에서 떨어져 교체해야 할 수 있습니다. 센서/케이블 어셈블리를 교체하는 경우에는 상관이 없습니다.
    Achtung: sehr kritische Operation !!! Kabel löst sich sehr schnell vom Sensor…nur am Sensor arbeiten, nicht am Kabel ziehen…gut wärmen und Geduld !
    ubrunner - 답글
    Attention: very critical operation !!! Cable detaches very quickly from the sensor... only work on the sensor, do not pull the cable... warm well and patience !
    Jim Glenys - 답글
  35. iPhone 8 LCD 및 디지타이저 교체: 35 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 35 단계, 이미지 2/2
    • Spudger/스퍼저를 주변 광 센서 플렉스 케이블 밑에 넣어 센서를 홈에서 들어 올리세요.
  36. iPhone 8 LCD 및 디지타이저 교체: 36 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 36 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 36 단계, 이미지 3/3
    • 카메라 밑 센서 케이블을 고정하는 접착제를 분리하도록 전면 카메라 케이블 어셈블리 밑으로 여는 픽을 미세요.
  37. iPhone 8 LCD 및 디지타이저 교체: 37 단계, 이미지 1/1
    • 전면 카메라 및 센서 케이블을 분리하세요.
    Thank you, what about removing the camera support or the little plastic squares to hold the sensor?
    Francisco O - 답글
    Why is there a screw still left on the frame, should I remove that too. When I connect the front camera flex cable to the motherboard it gets super hot and smells like burn rubber.⏎
    Could it be because I did not remove the last screw and connector flex cable? As shown in the iFixit photo they left one screw and flex cable behind.
    Inino - 답글
  38. iPhone 8 LCD 및 디지타이저 교체, LCD 및 디지타이저 분리: 38 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체, LCD 및 디지타이저 분리: 38 단계, 이미지 2/2
    • 디스플레이 양 옆에 위치한 1.22mm Y000 나사 세 개를 (전체 여섯) 풀어주세요.
    Bei meinem iPhone 8 handelt es sich hierbei um Y00 Schrauben, der Y000 Bit greift nicht richtig
    Andreas Veeser - 답글
  39. iPhone 8 LCD 및 디지타이저 교체: 39 단계, 이미지 1/1
    • iOpener를 가열하여 홈 버튼에 가장 가까운 쉴드 가장자리에 올려 LCD 및 디지타이저를 제자리에 고정하는 접착제를 부드럽게 하세요.
  40. iPhone 8 LCD 및 디지타이저 교체: 40 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 40 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 40 단계, 이미지 3/3
    • 여는 피크를 사용하여 평면 디스플레이 케이블을 LCD 쉴드 플레이트에 고정하는 홈 버튼 근처 접착제를 분리하세요.
  41. iPhone 8 LCD 및 디지타이저 교체: 41 단계, 이미지 1/3 iPhone 8 LCD 및 디지타이저 교체: 41 단계, 이미지 2/3 iPhone 8 LCD 및 디지타이저 교체: 41 단계, 이미지 3/3
    • 오른쪽 하단 모서리에 여는 피크를 넣어 디스플레이 케이블을 LCD 쉴드 판에서 계속 분리하세요.
  42. iPhone 8 LCD 및 디지타이저 교체: 42 단계, 이미지 1/2 iPhone 8 LCD 및 디지타이저 교체: 42 단계, 이미지 2/2
    • 디스플레이 어셈블리에서 LCD 쉴드 플레이트를 조심히 들어 올리세요.
    • LCD 쉴드 플레이트를 분리할 때 디스플레이 데이터 케이블이 걸리지 않도록 주의하세요.
  43. iPhone 8 LCD 및 디지타이저 교체: 43 단계, 이미지 1/1
    • LCD 및 디지타이저만 남습니다.
결론
새 교체 부품을 원래 부품과 비교하세요. 설치하기 전에 남아있는 부품을 옮기거나 새 부품에서 접착 백킹을 제거해야할 수 있습니다.
기기를 재조립하려면 이 지침을 역순으로 따르세요.
전자 폐기물을 R2 또는 e-Stewards 인증 재활용 센터로 가져가세요.
수리가 계획대로 진행되지 않았습니까? 자사의 iPhone 8 Answers 커뮤니티에서 문제 해결 도움을 받으세요.
다른 79명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en ko
90%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Arthur Shi
회원 가입일: 01/03/18
252,821 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 17개
So I’m pretty sure I know the answer to this - but can I test out the screen replacement without hooking up the camera, home button, etc? Can I just attach the three cables to the phone to make sure the screen works, or would it brick the phone?
Sarah Ybarra - 답글
Hi Sarah,
You can test the display without bricking your phone. It may boot-loop when the front sensor/camera assembly isn’t connected though. Be careful while you work with an opened phone with the battery connected…it is easy to accidentally short things out!
Arthur Shi -
After replacing the iPhone 8 LCD Screen and Digitizer, it seems that the battery is draining faster. I just wanted to see if this is a normal problem or was there something I missed during the install process?
Jason Adams - 답글
My daughters phone was repaired and the same thing is happening to her
tiffinycook -
Do you have to remove the plastic holder for the camera?
Diego Cisneros - 답글
Hi Diego,
If your replacement part did not come with the plastic holder, you will have to transfer the old one onto the new frame.
Arthur Shi -
Between step 30 and 31, a screw is removed that’s not mentioned in the guide. Should probably add what screw that was. And why.
Brage Boman - 답글
Hi Brage,
Good catch! The screw holds the earpiece speaker flex cable in place. You do not need to remove that screw (it actually shows up again in step 33). In the meantime, I will look into correcting the step.
Arthur Shi -
Is it safe to place the coins and heavy books on the iPhone 8 as it has the glass back?
Archie Cottam - 답글
Any reason my earpiece doesn’t work after my install? Everything worked before, I wonder if its a cheap digitizer, or if i didn’t attach the speaker back flush
G S - 답글
maybe you have damaged the flat or the earpiece isn’t correctly connected.
neax -
Thanks for a great guide, I’ve used it a few times now. Also, great tips along the way.
Jamie Oyakawa - 답글
The screen blinks on some places if I push it.
How is this possible ?
Simon Rutten - 답글
after replacing the complete display, my touch id no longer works on the new display.
instead on the old display it works fine.
what can be the problem!?
kamal - 답글
You must transfer the tuch id sensor from the old screen to the new: it is paired to your specific motherboard and won’t work even if you install another original sensor, because… Apple.
Daniele Carminati -
Great guide, easy to understand, had no problems. Thank you.
Mark Robart - 답글
OK, but what about the adhesive screen? How do you position it?
RobertAncet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 35
7일 전: 328
30일 전: 1,177
전체 시간: 108,022
