주요 콘텐츠로 건너뛰기
iPhone 8 Plus Earpiece Speaker Replacement
필요한 것
  1. iPhone 8 Plus Earpiece Speaker Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 8 Plus Earpiece Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  3. iPhone 8 Plus Earpiece Speaker Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Earpiece Speaker Replacement: 5 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 5 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 Plus Earpiece Speaker Replacement: 6 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Earpiece Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
  8. iPhone 8 Plus Earpiece Speaker Replacement: 8 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  9. iPhone 8 Plus Earpiece Speaker Replacement: 9 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 9 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 9 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 8 Plus Earpiece Speaker Replacement: 10 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 10 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 10 단계, 이미지 3개 중 3개
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
  11. iPhone 8 Plus Earpiece Speaker Replacement, Screen information: 11 단계, 이미지 1개 중 1개
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Earpiece Speaker Replacement: 12 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 12 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 12 단계, 이미지 3개 중 3개
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 8 Plus Earpiece Speaker Replacement: 13 단계, 이미지 1개 중 1개
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Earpiece Speaker Replacement: 14 단계, 이미지 1개 중 1개
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Earpiece Speaker Replacement: 15 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 15 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 15 단계, 이미지 3개 중 3개
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  16. iPhone 8 Plus Earpiece Speaker Replacement: 16 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Earpiece Speaker Replacement: 17 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 17 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 17 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  18. iPhone 8 Plus Earpiece Speaker Replacement, Battery Disconnection: 18 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement, Battery Disconnection: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $16.96
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  19. iPhone 8 Plus Earpiece Speaker Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the lower display cable bracket.
  20. iPhone 8 Plus Earpiece Speaker Replacement: 20 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 20 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  21. iPhone 8 Plus Earpiece Speaker Replacement, Display Assembly: 21 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement, Display Assembly: 21 단계, 이미지 2개 중 2개
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  22. iPhone 8 Plus Earpiece Speaker Replacement: 22 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 22 단계, 이미지 2개 중 2개
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  23. iPhone 8 Plus Earpiece Speaker Replacement: 23 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 23 단계, 이미지 2개 중 2개
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  24. iPhone 8 Plus Earpiece Speaker Replacement: 24 단계, 이미지 1개 중 1개
    • Remove the bracket covering the front panel sensor assembly connector.
  25. iPhone 8 Plus Earpiece Speaker Replacement: 25 단계, 이미지 2개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 25 단계, 이미지 2개 중 2개
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  26. iPhone 8 Plus Earpiece Speaker Replacement: 26 단계, 이미지 1개 중 1개
  27. iPhone 8 Plus Earpiece Speaker Replacement, Earpiece Speaker: 27 단계, 이미지 1개 중 1개
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
  28. iPhone 8 Plus Earpiece Speaker Replacement: 28 단계, 이미지 1개 중 1개
    • Remove the earpiece speaker bracket.
  29. iPhone 8 Plus Earpiece Speaker Replacement: 29 단계, 이미지 3개 중 1개 iPhone 8 Plus Earpiece Speaker Replacement: 29 단계, 이미지 3개 중 2개 iPhone 8 Plus Earpiece Speaker Replacement: 29 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
  30. iPhone 8 Plus Earpiece Speaker Replacement: 30 단계, 이미지 1개 중 1개
    • Remove the earpiece speaker.
결론
다른 37명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jeff Suovanen
회원 가입일: 08/06/13
447,069 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
3가이드 댓글
To replace the earpiece speaker, is the 6plus kit you sell compatible?
marigranadillo - 답글
I couldn’t find this part to buy, do you not sell it?
swyatt22 - 답글
I'm sure if you kept looking at the cell phone repair shops, or cell phone repair parts you'll find the earpiece part. The iPhone 8 is very popular. I found mine for like $4-$5 in Saudi Arabia. otherwise you can look at amazon or eBay. good luck.
iAziz -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 109
지난 30일: 476
전체 시간: 52,343
