주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone XS Taptic Engine Replacement
필요한 것
  1. iPhone XS Taptic Engine Replacement, Pentalobe Screws: 1 단계, 이미지 1개 중 1개
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone XS Taptic Engine Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement, Mark your opening picks: 2 단계, 이미지 3개 중 3개
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone XS Taptic Engine Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement, Tape over any cracks: 3 단계, 이미지 3개 중 3개
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone XS Taptic Engine Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement, Anti-Clamp instructions: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone XS Taptic Engine Replacement: 5 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 5 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone XS Taptic Engine Replacement: 6 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 6 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 6 단계, 이미지 3개 중 3개
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone XS Taptic Engine Replacement: 7 단계, 이미지 1개 중 1개
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  8. iPhone XS Taptic Engine Replacement: 8 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 8 단계, 이미지 2개 중 2개
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone XS Taptic Engine Replacement: 9 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 9 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 9 단계, 이미지 3개 중 3개
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone XS Taptic Engine Replacement: 10 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 10 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone XS Taptic Engine Replacement, Screen information: 11 단계, 이미지 1개 중 1개
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone XS Taptic Engine Replacement: 12 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 12 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 12 단계, 이미지 3개 중 3개
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone XS Taptic Engine Replacement: 13 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 13 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 13 단계, 이미지 3개 중 3개
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  14. iPhone XS Taptic Engine Replacement: 14 단계, 이미지 1개 중 1개
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone XS Taptic Engine Replacement: 15 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 15 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 15 단계, 이미지 3개 중 3개
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  16. iPhone XS Taptic Engine Replacement, Display Assembly: 16 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement, Display Assembly: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove five screws securing the logic board connector bracket, of the following lengths:
    • Three 1.0 mm Y000 screws
    • One 1.3 mm Y000 screw
    • One 3.7 mm Phillips screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  17. iPhone XS Taptic Engine Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone XS Taptic Engine Replacement: 18 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 18 단계, 이미지 2개 중 2개
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone XS Taptic Engine Replacement: 19 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 19 단계, 이미지 2개 중 2개
    • Use a spudger or a fingernail to pry up and disconnect the front panel sensor assembly connector.
  20. iPhone XS Taptic Engine Replacement: 20 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 20 단계, 이미지 2개 중 2개
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone XS Taptic Engine Replacement: 21 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 21 단계, 이미지 2개 중 2개
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  22. iPhone XS Taptic Engine Replacement: 22 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 22 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 22 단계, 이미지 3개 중 3개
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  23. iPhone XS Taptic Engine Replacement: 23 단계, 이미지 1개 중 1개
  24. iPhone XS Taptic Engine Replacement, Lower Speaker: 24 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement, Lower Speaker: 24 단계, 이미지 2개 중 2개
    • Remove the five screws securing the two brackets below the Taptic Engine and main speaker:
    • One 1.0 mm tri-point Y000 screw
    • Two 1.3 mm Phillips screws
    • One 1.7 mm Phillips screw
    • One 1.8 mm Phillips screw
  25. iPhone XS Taptic Engine Replacement: 25 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 25 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 25 단계, 이미지 3개 중 3개
    • The brackets are lightly adhered in place.
    • Gently lift to unstick and remove each bracket, being careful not to bend it.
    • If necessary, apply a little heat with a hair dryer or heat gun to soften the adhesive. (Putting an iOpener on the brackets is not recommended, as this may bend the spring contacts along the top.)
  26. iPhone XS Taptic Engine Replacement: 26 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 26 단계, 이미지 2개 중 2개
    • Remove the 1.9 mm Phillips screw securing the speaker connector cover.
  27. iPhone XS Taptic Engine Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the speaker connector cover.
  28. iPhone XS Taptic Engine Replacement: 28 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 28 단계, 이미지 2개 중 2개
    • Use the tip of a spudger to pry up and disconnect the speaker connector.
  29. iPhone XS Taptic Engine Replacement: 29 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 29 단계, 이미지 2개 중 2개
    • When prying up the speaker, take care not to damage the speaker flex cable you just disconnected. If necessary, bend the cable toward the battery so the speaker has room to come out.
    • Insert a spudger under the top edge of the speaker, near the edge of the iPhone's case.
    • Gently pry up and lift the top edge of the speaker slightly.
    • When reinstalling the speaker, check the position of the flex cable and make sure it doesn't get trapped underneath the speaker.
  30. iPhone XS Taptic Engine Replacement: 30 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 30 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • While prying up the speaker, use tweezers to peel away the plastic bumper strip from the top edge of the speaker.
    • If necessary, apply a little heat to soften the adhesive and make the bumper strip easier to separate.
  31. iPhone XS Taptic Engine Replacement: 31 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement: 31 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement: 31 단계, 이미지 3개 중 3개
    • Hold the speaker by its side edges and rock it side-to-side, separating the adhesive securing it to the bottom edge of the iPhone.
    • Pull the speaker away from the bottom edge of the iPhone until the adhesive gasket separates.
  32. iPhone XS Taptic Engine Replacement: 32 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 32 단계, 이미지 2개 중 2개
    • Remove the speaker.
    • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
    • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
  33. iPhone XS Taptic Engine Replacement, Taptic Engine Assembly: 33 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement, Taptic Engine Assembly: 33 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the Taptic Engine flex cable by prying it straight up from its socket.
  34. iPhone XS Taptic Engine Replacement: 34 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 34 단계, 이미지 2개 중 2개
    • Remove the two 1.9 mm Phillips screws securing the Taptic Engine.
  35. iPhone XS Taptic Engine Replacement: 35 단계, 이미지 2개 중 1개 iPhone XS Taptic Engine Replacement: 35 단계, 이미지 2개 중 2개
    • Grasp the plastic bumper strip and carefully lift it over the speaker connector.
  36. iPhone XS Taptic Engine Replacement: 36 단계, 이미지 1개 중 1개
    • Remove the Taptic Engine assembly.
  37. iPhone XS Taptic Engine Replacement, Taptic Engine: 37 단계, 이미지 3개 중 1개 iPhone XS Taptic Engine Replacement, Taptic Engine: 37 단계, 이미지 3개 중 2개 iPhone XS Taptic Engine Replacement, Taptic Engine: 37 단계, 이미지 3개 중 3개
    • Peel up and remove the plastic bumper strip from the Taptic Engine.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jeff Suovanen
회원 가입일: 08/06/13
452,425 평판
안내서 259개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,710개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 184
전체 시간: 17,456
