PC2-5300 2 GB RAM Chip
  • PC2-5300 2 GB RAM Chip
US$14.99
US$14.99
제품 재입고 메시지를 보내드리겠습니다.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
제품 정보
설명
설명
A fast 2 GB RAM Chip for laptops
  • RAM is the cheapest and most effective speed upgrade you can do for your computer
  • Faster file save/loading, web browsing, gaming, and more.
  • Check our list of Macs, or your manual to get the right chip style.
호환성
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac Mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.5 GHz (Penryn)
2.6 GHz (Penryn)
기기 6개 더 보기
수리 경험담
사용자 아바타
내 문제
Macbook was slow.
나의 수리
Couldn’t have been easier!
내 조언
The screws are really small and easy to loose. I used a small magnet to keep them in place.
사용자 아바타
내 문제
The iMac needed a RAM upgrade before it could get Mac OSX 10.11 installed.
나의 수리
The repair went well. A simple screwdriver to remove the cover and then I inserted RAM into the empty slot.
내 조언
Removing the memory that was in the computer was difficult. This required a needle-nose pliers or something that can gr . . .
사용자 아바타
내 문제
Changement de la RAM pour accélération des performances
나의 수리
Très bien.
내 조언
Prendre garde pour l'iMac blanc de bien remettre les clapets latéraux des barattes de RAM, avant de remettre les barrettes de RAM en position. Sinon vous ne pourrez plus les ressortir !
사용자 아바타
내 문제
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at ho . . .
사용자 아바타
내 문제
The machine only had 1 GB Ram installed
나의 수리
Easy : just follow the guide step by step
내 조언
Don't worry, just take your time to follow each step.
사용자 아바타
내 문제
My harddrive broke so I had to change it.
나의 수리
The repair was REALLY easy and fast! No problems and now my computer is working better than ever because I put more memory in. I also got all my files and programs back because I had made backup with time machine. It was almost too easy:)
내 조언
I was taking the comp . . .
사용자 아바타
내 문제
Old macmini on my shelf
나의 수리
Good repair except I didnt insert the RAM far enough. I just needed to push a bit harder to get it inserted properly.
My suggestion is to recommend to buyers of RAM is to buy two sticks. I had two slots in my mac mini and I only purchased one stick. Now that it's over I wish . . .
사용자 아바타
내 문제
I had 2 gigs of RAM and needed more speed for my 2008 Mac desktop. A friend of mine that's a whiz with Macs sent me your link. I ordered 2 2GB RAM chips, printed out your directions for installation and it was a snap.
나의 수리
It went without a hitch. It was extremely easy. Thank you!!!!!! Now my computer . . .
사용자 아바타
내 문제
First time replacing the RAM in a Macbook and thank god! It need it!
나의 수리
It was smooth and simple! Take the battery off then punch out the old and swap with the new.
내 조언
Just the usual: discharge any electric charge, disconnect the battery and power source, get to work and get back at it!
사용자 아바타
내 문제
Yes
나의 수리
Good
내 조언
No
더 보기
