주요 콘텐츠로 건너뛰기
˙pǝlqɯǝssɐ ǝq oʇ spǝǝu puɐ sǝɔǝıd uı sǝɯoɔ doʇdɐl ɹɐlnpoɯ sıɥʇ ǝɔuıs 'uʍopɹɐǝʇ ǝsɹǝʌǝɹ ɐ ɟo puıʞ op oʇ ƃuıoƃ ʎllɐnʇɔɐ ǝɹɐ ǝʍ ǝɯıʇ sıɥʇ
Wait a minute, lets flip this around:
This time we are actually going to do kind of a reverse teardown, since this modular laptop comes in pieces and needs to be assembled.
But this is iFixit - so we stick our nose in, wherever we can before we're going to set the pi-top up!
For more nosey news make sure to follow us on Facebook, Instagram, or Twitter for all of the necessary teardown and repair news.
필요한 것
도구
해당 분해도는 수리 안내서가 아닙니다. Pi-top 수리는 자사의 서비스 설명서를 사용하세요.
  1. Pi-top Teardown, Pi-top Teardown: 1 단계, 이미지 2개 중 1개 Pi-top Teardown, Pi-top Teardown: 1 단계, 이미지 2개 중 2개
    • The Pi-top is unpacked and ready to use assemble! When we're done the pi-top tries to seduce us with the following specs:
    • HD 13.3” anti-glare screen with 1920 x 1080 resolution and 256k colors (165.63 ppi)
    • Raspberry Pi 3 with 1.2GHz Quadcore ARM Cortex A53P
    • Two–wire smbus v2.0 interface
    • Programmable keyboard & trackpad with palmcheck
    • Modular rail for add-ons
    • Battery for up to 12hrs of usage
  2. Pi-top Teardown: 2 단계, 이미지 2개 중 1개 Pi-top Teardown: 2 단계, 이미지 2개 중 2개
    • The pi-top comes in a four layer box with foam separators to protect the valuable goods inside–which mostly consist of neon green plastic.
    • But before we assemble the pi-top we try to tear everything down we can find!
    • The teardown of the pi-top is more or less over after unpacking it. There are just a few more things we can stick our nose in and because this is iFixit, we will.
  3. Pi-top Teardown: 3 단계, 이미지 3개 중 1개 Pi-top Teardown: 3 단계, 이미지 3개 중 2개 Pi-top Teardown: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    • Starting with the bottom end, there are eleven hex screws with ball heads which are holding down the metal plate on top of the battery block and the keyboard unit will snap on to.
    • With the help of our 64 Bit Driver Kit we get a glimpse on the battery pack which consist out of four separate batteries cuddling under a black adhesive strip.
    1. Start with familiarizing yourself with the safety aspects of handling Lithium Ion battery cells by studying the FAQ page of Honcell (http://www.honcell.com/faq/).
    2. Refrain from going further than Step 3 if you feel uncomfortable. Fire or an explosion are nearer than you might think.
    3. iFix is not responsible for any damage or injury. (see …).
    Ivo Van Ursel - 답글
  4. Pi-top Teardown: 4 단계, 이미지 2개 중 1개 Pi-top Teardown: 4 단계, 이미지 2개 중 2개
    • Finally one of the secret circuit boards of the pi-top! Sadly the most exciting thing to find is the easy to release pin connector. Nothing to find here for the adhesive and soldering police!
    • Responsible for the battery management is the Texas Instruments BQ40Z60 chip.
    • Texas Instruments MOSFETs
    • 12 A Fuse
    • Each of the four batteries claims an 10.73 Wh capacity. All together they shall guarantee you 12hrs of work without charging the pi-top, which is enough to fly from Hollywood to Barcelona.
    4. Do not disconnect the Smart Battery Module from the Cell Linker as re-uniting these two printed circuit boards easily results in a short-circuit.
    5. When your pi-top no longer starts-up on battery power, or stops immediately when you pull the mains plug, you might try the following procedure for which you need a pi-topPROTO board and a a Texas Instruments EV2400 i2c-USB converter. (http://www.ti.com/tool/EV2400). The i2c-USB costs about $ 200.
    6. You also need the "Battery Management Studio" (free) software package and a recent Windows PC.
    7. Last but not least, you need the the keys to unlock the Texas Instruments. (http://www.ti.com/product/BQ40Z60).
    Ivo Van Ursel - 답글
  5. Pi-top Teardown: 5 단계, 이미지 3개 중 1개 Pi-top Teardown: 5 단계, 이미지 3개 중 2개 Pi-top Teardown: 5 단계, 이미지 3개 중 3개
    • The 13,3" HD Screen is surrounded by a green plastic frame. We can remove it by pulling off the rubber spacers which protect the display from getting scratched by the raspy keyboard when the pi-top is closed.
    • After we removed "18 screws", we can skip our finger gymnastic lesson for today. But fair enough–the rim removes quiet easily after we got rid of the screws.
  6. Pi-top Teardown: 6 단계, 이미지 2개 중 1개 Pi-top Teardown: 6 단계, 이미지 2개 중 2개
    • There is one last cable which connects the display to the computing unit. On both ends it has a simple plug-in connection.
    • Under a strip of protective film we can find the control board, with:
    • a HIMAX HX8876 timing controller
    • a NovaTek NT50169G power management (likely)
    • a Richtek RT8532GQW backlight white LED driver w/ boost converter
  7. Pi-top Teardown: 7 단계, 이미지 2개 중 1개 Pi-top Teardown: 7 단계, 이미지 2개 중 2개
    • We experience some kind of deja vu opening the plastic coverage of the keyboard. Not 18 but 23 Phillips screws want to be removed until we can get a glimpse on the inside.
    • Our childish recklessness to separate the two plastic pieces is stopped by two ribbon cables. Luckily they are opened with just a few movements.
  8. Pi-top Teardown: 8 단계, 이미지 3개 중 1개 Pi-top Teardown: 8 단계, 이미지 3개 중 2개 Pi-top Teardown: 8 단계, 이미지 3개 중 3개
    • After removing one side of the green plastic frame the whole interior falls in our arms.
    • Well, not the whole interior. While everything of the pi-top was easy to remove so far, the keyboard itself is stamped to the plastic frame.
    • All we can go with on our foray is the touchpad and its frame, the power button and the circuit board with the buttons for left and right click that features a SinoWealth SH68F83 low speed USB microcontroller.
  9. Pi-top Teardown: 9 단계, 이미지 3개 중 1개 Pi-top Teardown: 9 단계, 이미지 3개 중 2개 Pi-top Teardown: 9 단계, 이미지 3개 중 3개
    • At this point the actual teardown is over–time to reassemble!
    • Hidden in the padding of the box we find tools, an assembly instruction and heaps of screws to build a pi-top!
    • The heart of the pi-top which is rather small than big to be fair, comprises only two circuit boards connected with a few cables and placed above the battery.
  10. Pi-top Teardown: 10 단계, 이미지 1개 중 1개
    • Finally the pi-top is torn down assembled!
    • Verdict: The pi-top is not a real Laptop. There isn't much inside that could be bathed in glue. It's a miniature computer on a circuit board with a shell of a gnomish green notebook. Its made for programming and coding fans filled with everything they need. As the raspberry pi itself, the pi-top is simple, easy to tear down and easy to assemble.
    • There are a few small things we want to mention here:
    • The opening in the body for USB and Ethernet is too small in our opinion and you will end up in cable tangle.
    • The headphone jack on the raspberry is facing the keyboard and barely accessible with an angled plug.
  11. 최종 의견
    • The design allows access to all components with only little to medium work to get to them.
    • No glue but only screws for a relatively simple opening procedure.
    • The tools you need to assemble the pi-top are included.
    • The tools you need to reach deeper are standard and probably already in your toolbox.
    • The plastic housing doesn't feel too sturdy and might suffer damage being a portable device and experiencing some rough handling from time to time.
    수리 용이성 점수
    8
    수리 용이성 10점 중 8점
    (10은 가장 쉬운 수리를 뚯함)
작성자
5다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
124,137 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,131개를 작성함
댓글 5개
How is “The tools you need to reach deeper are standard and probably already in your toolbox” not a positive?
Jake Rose - 답글
If you are equipped with our toolsets, you are ready to go ;) But not everyone has the right sized Torx driver at home. They could have continued with the same allen sized screws as they provide the tools for.
Tobias Isakeit -
Mine stopped turning on, what can I do?
Klein Kravis - 답글
Can you get a replacement display to hub lead? If so where from?
john pulham - 답글
I think it has to be mentioned that the board is very poor design, it drains a full charge in about a week, has very high off energy usage, and if left 2 weeks in that state, it bricks itself. You have to run a script to run a firmware update that don't even fix the problem, is just a patch that let the problem occur each time you forget it for 2 weeks.
The display input doesn't even seem to comply with the HDMI standard since it don't want to work with other sbcs or even a normal desktop PC. So yes is like waste, useless since you can not use it in other projects, or recycle it
I can only recommend if you hate yourself or the world, wana throw away money or like to endurance your tolerance
Alexander Paniagua Spindler - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 46
전체 시간: 9,894
