주요 콘텐츠로 건너뛰기
We took apart the iPod shuffle Special Edition on September 11, 2009. This iPod features an incredibly shiny stainless steel enclosure. According to Apple's marketing-speak, "It's as brilliant as your taste in music."
필요한 것
도구
더보기...
해당 분해도는 수리 안내서가 아닙니다. iPod shuffle 3rd Generation 수리는 자사의 서비스 설명서를 사용하세요.
  1. iPod shuffle 3rd Generation Special Edition Teardown, iPod shuffle 3rd Generation Special Edition Teardown: 1 단계, 이미지 3개 중 1개 iPod shuffle 3rd Generation Special Edition Teardown, iPod shuffle 3rd Generation Special Edition Teardown: 1 단계, 이미지 3개 중 2개 iPod shuffle 3rd Generation Special Edition Teardown, iPod shuffle 3rd Generation Special Edition Teardown: 1 단계, 이미지 3개 중 3개
    • If you like shiny things, Apple has an iPod for you. It's like getting a free mirror! And it's only $20 extra.
    • Sadly, the shuffle doesn't come with matching shiny headphones.
    • Contrary to Apple's typical claims of "smaller packaging to save the environment," this iPod's packaging is 65% larger than the original 3rd Gen shuffle.
  2. iPod shuffle 3rd Generation Special Edition Teardown: 2 단계, 이미지 2개 중 1개 iPod shuffle 3rd Generation Special Edition Teardown: 2 단계, 이미지 2개 중 2개
    • We've already taken apart one of these little guys, but we wanted to see what makes the special edition so special.
    • At least until we use it, the mirror-finish reflects beautifully. With the help of the new shuffle, our camera can do a self-portrait.
  3. iPod shuffle 3rd Generation Special Edition Teardown: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    1.5" Thin Putty Knife
    $6.99
    • This picture makes things look easy. The picture is a lie. This picture comes after about an hour of frustration trying to open this iPod.
    • We finally used a putty knife and an excessive amount of force to pry the iPod open.
    • The new shuffle weighs in at 17.2 grams, nearly 61% more than the 10.7 gram aluminum shuffle.
    • That means you can buy special edition shuffles for only $2,613 per pound, while the regular shuffle will set you back $3,352 per pound.
  4. iPod shuffle 3rd Generation Special Edition Teardown: 4 단계, 이미지 1개 중 1개
    • Here are the normal (left) and special edition shuffles. Not a surprise, but not much new to see here.
    • This shouldn't come as a surprise, but the new shuffle is a lot heavier. It is steel after all.
  5. iPod shuffle 3rd Generation Special Edition Teardown: 5 단계, 이미지 1개 중 1개
    • The most daunting task of this procedure....removing the one single screw.
    • The black 3rd generation had a black screw, while our silver special edition had a silver screw. It looks like Apple gives you matching screws.
  6. iPod shuffle 3rd Generation Special Edition Teardown: 6 단계, 이미지 2개 중 1개 iPod shuffle 3rd Generation Special Edition Teardown: 6 단계, 이미지 2개 중 2개
    • Prying the logic board and battery out with the flat end of a spudger.
    • Things don't appear different here. The battery is still a tiny 0.27 watt-hours.
  7. iPod shuffle 3rd Generation Special Edition Teardown: 7 단계, 이미지 1개 중 1개
    • The internal parts and the stainless steel case seperated.
    • After removing the internals, the stainless steel casing weighs 12 grams. That doesn't seem like much, except that the iPod itself only weighs 5 grams. Over 70% of this iPod's weight comes from its shell!
작성자
4다른 기여자 명과 함께
Walter Galan
701,292 평판
안내서 1,203개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 34
지난 30일: 100
전체 시간: 41,021
