주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod nano 6세대를 위한 수리 정보. 2010년 9월 출시. 모델 번호: A1366.
Please help me! WATER DAMAGE
I accidentally washed My iPod in the washing machine and it wouldn't turn on. I put it in a bag of rice for 24 hours but nothing happened. when I took it apart the lcd fell apart. Please tell my how to fix it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
chanan, It seems this happens a lot. Here is my answer to the same question from a different person "The first step you should do is to disassemble your iPod. Use this guide to help you out. After that clean the iPod thouroughly by following this general guide. You a high grade isopropyl alcohol. Once you are sure the logic board, connectors (do not forget the dock connector), and cables are clean replace the battery. You can get it at places like this. Once you have all this accomplished, reevaluate for any residual (if any ) damage. In your case, you may have to replace the LCD as well. Follow this guide for that. Remember that this model is a PITA to work on but not impossible to fix. Hope this helps, good Luck.
here and here and one more here
iPod Nano 6th Generation 전면 패널 어셈블리 이미지
안내서
iPod Nano 6세대 전면 패널 어셈블리 교체
난이도:
조정
35 minutes - 1 hour
iPod Nano 6th Generation 로직 보드 어셈블리 이미지
안내서
iPod Nano 6세대 로직 보드 어셈블리 교체
난이도:
조정
30 minutes - 1 hour
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
chanan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 9,656
