주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1418 / 2012년 후반 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
Change Front Glass Panel
Hello, i have broken the Front Glass from my iMac. Not the LCD. The LCD is ok.
Can i change only the Glas? It is possible to take off the LCD from the old Glas and make it on the new Glas?
And where can i buy the Glas?
Thank you very much.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
What is the right Glas Panel for my iMac 2012 Late. It is the 13,1 iMac. EMC 2544.
Thank you.
의
댓글 달기
답변 2개
선택된 해법
Hans, I do not share the opinion on the ability to replace the glass by a DIY'er with my colleague. "To save space and eliminate the gap between the glass and the pixels, Apple opted to fuse the front glass and the LCD. This means that if you want to replace one, you'll have to replace both." and "cutting open the display destroys the foam adhesive securing it shut. Putting things back together will require peeling off and replacing all of the original adhesive, which will be a major pain for repairers." So is it possible? Certainly by people that have the right equipment and plenty of experience. If the ifixit team with all their resources and experiences in teardown have problems with this, I am convinced that the occasional fixer will have great trouble doing it. Just because the part is available does not mean that it is a task we can do. I'd suggest to replace the complete assembly. Part number for the assembly is 661-7109
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
I have the same model and the same problem (cracked glass, LCD fine). I had seen several guides showing replacement glass installation good for "2009 to 2012" 21.5 inch imacs that looked pretty straightforward. I was close to buying the glass and suction cup combo (assuming I'd only have magnets to contend with), but it sounds like that simple approach won't work for this model.
Am I correct in inferring that the procedure described at iMac Intel 21.5" EMC 2544 디스플레이 교체 is the appropriate one? Why doesn't ifixit offer the replacement display/glass assembly?
의
You'll need to cut the foam tape that glues the cover glass to the LCD panel without damaging the LCD and cutting your self in the process. Even our replacement didn't hold up well and was dirty afterwards (we ended up replacing both with new display assemblies). The next problem is locating the cover glass. I don't know of any source to get the glass alone any more, now that there are spares available (full assemblies). I wouldn't waste the time or risk getting hurt here. Just get the complete display assembly. The Apple P/N is: 661-7109 - Display Assembly. Heres one source: PowerBookMedic
의
댓글 달기
Thank you for your answer. It is not good but what happens?
Are there only Displays from LG or can i get a Display from Samsung for this iMac?
Is this the right? It is so cheap. It is Okay?
http://www.elecok.com/de/lm215wf3-sdd1-l...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Hans 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 41
전체 시간: 16,493
