주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
20 질문 전체 보기
Display works but touchscreen broken LG G2
Phone information: LG G2 4G LTE VS980
I accidentally dropped my phone today and when I picked it up, it seemed as if I hammered it. I can be sure that I dropped it on the back but there was a huge crack in the upper mid section right below the speaker. I have been dropping my phone quite a lot but I had a case on it (it was a weak thin silicone case covering just the back part). Anyways, the buttons on the back worked just fine and the device was completely functional except for the touchscreen. Even the home button, back button, and the menu button on the front was part of the touchscreen as well, so the device is pretty much useless.
Overall, I dropped my phone, there was a huge crack, touch screen does not work, but the display shows up just fine.
Question: What is broken? the digitizer or the LCD?
If I replace it, would i need to buy the digitizer, the LCD, or both?
Can I replace just the parts by getting the parts from amazon? or can you suggest me where else?
Is it better to get it fixed, buy a new one, or just replace it myself?
Please reply ASAP
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 22
댓글 1개
I never dropped my phone, but one day I had to turn my phone on its side or upside down to use the keyboard...how did this happen and how can I fix it without buying a new spend phone???
댓글 달기
답변 8개
가장 유용한 답변
Lina Kang, what broke is the digitizer. The digitizer and LCD are fused together. Unless you have an LCD separator machine, a bunch of (L)OCA and some sort of curing station, I suggest that you purchase the complete assembly. Follow this guide for your repair. Hope this helps, good lcuk
이 답변이 도움이 되었나요?
점수 4
댓글 6개:
would the lg g2 lcd replacement used in the guide fit my phone? what is GSM and CDMA?
Plus would I be able to fix it myself? I have seen many tutorials about it and I might be able to try it but Im afraid that I might break something.
Can I buy this one? I dont have the specific tools to disassemble my phone and this one comes with tools as well as adhesive. Will this one fit my phone?
send a link of the one you are looking at:-)
댓글 1개 더보기
댓글 달기
Hi!
I have the same problem with mine right now. I've been looking around online and it seems like the LCD and digitizer are glued together so you'd want to buy them together. I typically buy phone parts from Amazon because it seems to be the most reliable with the most reasonable prices, but you could get them anywhere, really. I wouldn't suggest getting something cheap, but there's no need to get an expensive name-brand. If your phone is under warranty fixing it yourself will probably break it, so just make sure you're prepared for that.
I hope that helped :)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
ive smashed my lg g2 not badly but its at the bottom left, is there a way of getting the touch screen to work or will i meed to replace ot?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have a worst case, my LG VERIZON 4G LTE wont turn on when charging. When we were camping unfortunately slipped through a rock and smash my phone so hard. I tried turning it on but it wont work, i tried charging but no blue light blinking - still wont work. The lcd was broken bad and since it wont turn on i cant figure it out if the digitizer is broken as well. Is there any chance that my phone can be fix? I havn't used it for a month now but since it has a sentimental value I want to revive it. :(
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i had dropped my lg g2 and the whole screen is messed up but it still can be cut-on i need to know how much will it be to get both the LCD and the digitizer so i can get the cheatest one so if anyone can help me that will be helpful thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
mere mobile lg g2 ki half screen pe touch kam karaha or above portion pe ni karaha or display b thk ha please tell me solution
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Ayesha, solution ye hain ki apko digitizer jo main lcd screen ke upar hota hain usse change karna padega, jo ek professional repairer ka kaam hain, if you are not confident, dont try it yourself, if you need further technical assistance please email on rohitt21@gmail.com, I can provide you tech support number to talk to , thanks.
댓글 달기
Can lg g2 display and touch can be separated
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
댓글 달기
Digitizer tbdell krwao g
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lina Kang 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 18
전체 시간: 37,249
