주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
재봉틀 수리 및 분해에 관한 정보를 얻으려면 이 가이드들을 확인해 보세요.
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 4개
I'm having trouble with the bobbin tension. Any suggestions?
의 공유
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
의 공유
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
의 공유
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
의 공유
댓글 달기
답변 3개
선택된 해법
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
iApple your first link and your second link are identical. Neither one of those is for the service manual
의 공유
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
의 공유
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
의 공유
댓글 달기
가장 유용한 답변
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Cheryl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 60
전체 시간: 20,105
