주요 콘텐츠로 건너뛰기
재봉틀 수리 및 분해에 대한 정보는 다음 안내서를 참조하십시오.
92 질문 전체 보기
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 4개
I'm having trouble with the bobbin tension. Any suggestions?
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
댓글 달기
답변 3개
선택된 답변
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
iApple your first link and your second link are identical. Neither one of those is for the service manual
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
댓글 달기
가장 유용한 답변
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cheryl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 18
30일 전: 82
전체 시간: 17,732
