주요 콘텐츠로 건너뛰기
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 질문 전체 보기
stuck on start up
it starts and gets stuck on start up screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Hi,
What OS is installed?
Have you tried starting in 'safe mode' to see if it boots all the way to the Windows desktop?
Have you tried booting using the 'last known good configuration option'?
Have you tried a system restore to a previous restore point?
hello it doesnt load past the dell logo and the slide bar stops about a quarter of the bar and its running vista home premium
Hi,
Can you get into BIOS?
Press F2 soon after startup.
If you can check that there is a HDD being detected in BIOS.
try pressing F12 soon after startup and see if you get into Dell's Diagnostic partition to test a custom test on the HDD to see if it is failing.
댓글 달기
답변 1개
With the power off, try removing all the memory sticks and see if you get a beep error or blinking LEDs (Power, Hard Drive and Wireless). If nothing happens then the processor is bad, if you get a beep or blink code it is probably the memory, you can go to the Dell site to get the information on the beep/blink codes.
The current Dell computers now use the LEDs for start up errors.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dave_ruse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 195
