주요 콘텐츠로 건너뛰기
iFixit은 쿠키를 사용하여 사이트 기능을 개선하고 트래픽을 분석하며 광고를 개인화합니다. 당사 사이트를 사용함으로써 귀하는 당사의 쿠키 사용 및 개인정보 취급방침에 동의하게 됩니다.
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
20 질문 전체 보기
unexpected sounds from board
Hi all ,
I hope find you well.
I have the above macbook 2008 and i am notice unexpected sounds from the logic board. this is not cooling fan noise and not hdd noice . I am notice that when I upgrade the logicboard of the laptop and ram to 5 gb ram and 60 gb ssd samsung. the question is if the sound is produced from ssd or ram modules or power mangment on logic board or from nvidia gpu or from wifi dongle. if ram module is not sit proberly can this make sound ? the laptop is fully functional and no problems at all ... Te person that sell me the board tellme that check it before sent out the board and no problems found but he didnt chek the charging ability because he dont have battery but i manage to charge the battery with out any problem... The sound is very low like sh electric sh but is low. Also the old logic board make a small amound of sound but i hope that was because the board is faulty,but now the new one also make sounds but is in lower level.
Any advice is accepted . Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
This is why most techs only upgrade one thing at a time. Take it back to the original configuration and see if the issue persists. Then do one upgrade at a time to see exactly what causes the issue.
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
The strange situation is that that the laptop is belongs to my uncle and i dont have it before . But with the old logic board make again the same sound . Is this sound may be a common fault on this model ? I also try to check it with out the ssd because is old., to check if the ssd can make sounds.
Check the backward compatibility of the SSD drive. Your machine has a SATA I BUS running at 1.5GHz.
The ssd I am install is samsung sata 2 is 1.8 ssd with bracket for 2.5. Direct sata connector without any converters. I am enable trim. Also I am clean the ram modules and insert it back. I also notice that the sound when i am charging becomes different. I am try to reset both smc and prom but still the same. Is not too loud but i can here it...
This SSD is PM810 TH 64GB sata2 it was originally on dell computer . I hava the aluminium macbook unibody 2008 which i check and tell that support sata 2 so that shuld be compatible.... Also all the stuff seems to work...
댓글 달기
답변을 추가하세요
ssavva05 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 122
