주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mavic Pro는 2016년 11월에 처음 출시된 4K 비디오 촬영 기능을 갖춘 접이식 소형 드론입니다. 모델 번호는 M1P이며, 컨트롤러 모델은 GL200A입니다.
camera has water inside
hi there,
i was flying sideways and drowned my mavic pro in a tree which fall then in a river (sweet water). Found it again 24 hours later in about 4 meters under water -
everything works fine but it got water inside the camera which is now stuck on the glass in front of the lens and obviously can not disappear by itself. I opend the little screws but did not dare to go further as the parts did not want to get loose. I also see a golden ring near the lens cover which could hold it in place...?
any help?
Thanks anyway!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Do not charge it! Follow these guides to clean all the parts to help prevent water from corroding it. Do it ASAP!
Read this: Electronics Water Damage
Disassembly: DJI Mavic Pro 분해도
Proper cleaning demonstration: iPhone 액체 침수 손상 수리
As for the camera, there is no hope. You'll need to replace it. Use the teardown to replace it and any other non-functioning part. I recommend taking it low and easy the first few flights to make sure everything's working.
Hope this helps!
iPhone 이미지
안내서
iPhone 액체 침수 손상 수리
난이도:
어려움
1 - 2 hours
DJI Mavic Pro 이미지
안내서
DJI Mavic Pro 분해도
난이도:
조정
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
In that case that the camera can not be opened I try to remove the glass and find something to replace it (because the camera is working fine, it is only a waterdrop behind the glass which is in the view,..), if i kill it i have to excange it anyway...
Thank you!
의 공유
actually maybe just exchange open the glas, release the moisture and put on a ND filterlens would solve the problem :)
의 공유
Jeronimo I do not recommend that. You should replace it. 24Hr underwater also penetrated the sensor, which you can not fix. Have you cleaned the drone using the instructions above? This is something you should have done days ago. If you haven't done it yet, then the corrosion has probably already caused irreversible damage.
의 공유
댓글 달기
답변을 추가하세요
jeronimo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 35
전체 시간: 2,189
