How to change headlights bulb
How to change headlight bulb
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
@bexon59 open the front portion of the wheel liner. You should see a white cap with ridges and a tab, open that. Next there should be a silver connector socket with a lighting bolt symbol, pull that off. You should now see the back of the bulb and its clip. Squeeze the clip and pull it back to remove the bulb. This video also not the best, should help you with that.
이 답변이 도움이 되었나요?
IF you open the hood of your car there should be a big black screw (somtimes plastic) if you unscrew that you can pull you head light out and disconect the wires. Then you can take off the back cover to the headlight and change the bulb.
이 답변이 도움이 되었나요?
You can get to it from the inner fender, removing the front wheel well weather protector.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 10
지난 30일: 33
전체 시간: 16,819
