주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Joy-Con 컨트롤러의 수리 안내서와 정보.
Joy con analog stick
My Left Joy-con analog stick is ghosting me forward. It physically works fine, but even after resetting the device and re-configuring the controller it still stays the same. Any tips on how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
가장 유용한 답변
@tigerjoshy you probably already solved your joystick problem, but for anyone else who comes across this question: this is now a widespread issue that has been acknowledged by Nintendo! You can contact them for a (potentially free) repair, or check out our left and right joystick replacement guides and our replacement joystick part.
Replace a Nintendo Switch joystick on the left or right Joycon controller. 이미지
제품
Nintendo Switch Joy-Con/Switch Lite Joystick
$14.99
Joy-Con 좌측 Joystick 이미지
안내서
좌측 Joy-Con Joystick 교체
난이도:
조정
30 minutes
Joy-Con 오른편 Joystick 이미지
안내서
오른편 Joy-Con Joystick 교체
난이도:
조정
30 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hey! I’ve had this problem and I’m happy to help! There’s two things you can do. You can get a new toothbrush and brush under the analog stick, doing this will remove any dust! If that doesn’t work contact Nintendo, if the joycons came with the console, and it’s been under a year since you’ve purchased the switch. You can call Nintendo, set up a repair, and they can repair it for you! (If you bought them separately you need to have your receipt for proof of purchase!) However you can also ask them to replace the joycon instead, so instead of fixing the old one, they just send you a new one! Hope this helps!!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I tried the toothbrush. It didn't work, in fact I think it made it worse
댓글 달기
답변을 추가하세요
Joshua ovalle 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 10,250
