not taking a charge or powering on.
My PSVita will not take a charge or power on I bought it from a pawn shop a while back and it would not do anything and they would not take it back what might be the problem and how would I fix it.
좋은 질문입니까?
기기에 대한 안내서, 부품 및 답변에 신속히 접근할 수 있습니다
좋은 질문입니까?
@fatedengram this can be an issue with the charger, the charging port and/or the battery. Use a multimeter and check your charger to make sure that it has the proper voltage output (5V). If that is okay check the power port and change the battery while you are at it. Use these guides PlayStation Vita to work on it.
이 답변이 도움이 되었나요?
I will need to buy a multimeter then to test them.
i tested the battery and the charger the battery im getting 2.82 and i tested the charger connected to the motherboard and im getting.14 with the wall outet .02 with the usb plugged itno my laptop if i tested correcctly.
@fatedengram "the battery im getting 2.82" start with a new battery. Not sure where you tested for the voltage on your port but either one is to low.
I disconnected the battery from the motherboard and tested the connector
Try opening it and unplug battery and plug back in then charge it. Sometimes that can fix. If slim model the android style charging cables are junk and often go bad. So it maybe your charger.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,775
So I will get a new battery as soon as I get the money what is it like $15
Jake Romine 의
