주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Jaguar가 제조한 자동차 수리 안내서 및 지원.
How to replace thermostat housing?
I have a 2009 Jaguar XF and I went to replace thermostat and when I removed I noticed a piece was broke in the housing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I'm also having the same issue with my 2009 Jaguar XF Luxury. Its a 4.2L no Supercharger. When I took the thermostat out I noticed it was broken on the inside were the thermostat slides Into. Is there a guide for the replacement of that part? Thank you.
의 공유
댓글 달기
답변 1개
가장 유용한 답변
@mikesmith2005 since we do not know where and how it is broken nor do we know what engine size this is, use the coolant part from the workshop manual and see if that will help you out. Jag-Cooling.pdf If that does not work for you provide more information about your vehicle and post some pictures about where and how the housing is damaged. Use this guide 기존 질문에 이미지 추가하기 for that.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Great link to the pdf. Very informative. Thank you @oldturkey03
의 공유
댓글 달기
답변을 추가하세요
Mike Smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 25
전체 시간: 1,331
