주요 콘텐츠로 건너뛰기
The Acer Aspire E 14 Touch can be identified by its model number: E5-471-5456. The device was released in late 2014 and has a 14 inch HD LED-backlit TFT LCD display, a NVIDIA GeForce 940M GPU with 2GB DDR3 VRAM,  as well as an intel core i5 processor with 2.2GHz.
7 질문 전체 보기
acer aspire e5 471-35sl no power
my laptop acer aspire e5-471-35sl bios flash and now power is not open .not charging
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
First of all, try removing the battery and turning it on with only the powersupply plugged in.
If that doesn't work try to insert the powersupply and wiggle it a bit, if it feels like the part that the powersupply is plugged into (the dc connector) is loose or follows the power plug without resistance to the wiggle, it will probably need to be replaced or resoldered onto the motherboard.
If neither is an issue you might have to open up the laptop and take out any removable hardware and periodically try to power it on. if you get to a barebones motherboard with not poweron then it is probably the laptops motherboard that is defective.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ko latt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 658
